Old March 28th, 2013, 08:43 PM   #1
mfresh
Knee-dragger in Training
mfresh's Avatar
Motorcycle(s): '09 Ninja 250R (Sunbeam Red)
Four Stages Of Body Position
Thought this was a great vid.
In this video, Thomas Delaney discusses the 4 stages of body position when riding: Straights, Setting up for a Corner, Cornering and Corner Exit.
North GA Riders
mfresh is offline   Reply With Quote
5 out of 5 members found this post helpful.
Old March 29th, 2013, 05:18 AM   #2
Very good find, Manny !
Thanks for sharing it
Caveat: Absolute no need for using this technique in street riding.
Old March 29th, 2013, 07:44 AM   #3
mfresh
mfresh's Avatar
Thanks Hernan!
I agree! Many of the techniques are a bit "overkill" for the street; however, I found some of the little things can make a big difference even for street riding.
For example, keeping the ball of your foot on the pegs instead of hooking your heels on the peg. This allows for better distribution/control of weight on the bike.
Another interesting thing was your body/head position relative to the center-line of the bike in a turn. It doesn't have to be super exaggerated, like it's done on the track, but I think shifting your body, properly, even a little bit towards the inside of a turn could works towards adding stability and control.
As I watch these videos that are geared towards track riding, I think to myself how I can implement the "spirit" of what is being said, by understanding the purpose of why they are being done, into my street riding.
Truth be said, another reason why full-blown track riding body positioning is overkill is that the Ninja 250 is so small it simply doesn't require the same amount of effort to lean over the bike, and thus requires much less re-positioning of the body IMO.
From my understanding, one of the main purposes of "hanging off" a bike is to pull the bike inwards, against the gyroscopic forces, during a turn. Even on the track I don't think you'll need to hang off the 250 much simply because of its weight and lower potential speed (less gyroscopic forces pulling the bike to the outside).
Then again, I may be over (or under) analyzing things like I tend to do.
North GA Riders
Old March 29th, 2013, 08:06 AM   #4
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I completely disagree.
If you are to hot into a corner it is much safer to hang off more than to apply more brake. I don't drag a knee on the street but I use all these methods even for street riding. It's just second nature and I feel more comfortable using my body while riding than just sitting there along for the ride.
I've been riding like this since the early 80's and haven't crashed on the street using these technics (knock on asphalt).
Old March 29th, 2013, 09:35 AM   #5
Originally Posted by mfresh View Post
Thanks Hernan!
From my understanding, one of the main purposes of "hanging off" a bike is to pull the bike inwards, against the gyroscopic forces, during a turn. Even on the track I don't think you'll need to hang off the 250 much simply because of its weight and lower potential speed (less gyroscopic forces pulling the bike to the outside).......
You are welcome, Manny
I find the content in the video excellent; it just occurred to me that new riders reading this thread (now and in the future) may understand that this is a "universally applied" body position, which in my opinion is great for the track and for saving a riding mistake on public roads, but is not practical for street riding. Speed limits also limit the lean angle and this technique was designed for big lean angles.
Now, as for the purposes of the technique, I don't think that it is pulling heavier bikes inwards the turn.
The main idea is to lean the weight of the rider more, so the weight of the bike doesn't have to lean as much as it would in a centered-body position.
By doing that, a few degrees of lean can be saved for the frame of the bike, helping the suspension work a little better and keep a little more constant vertical pressure on both contact patches. The available traction of the tires very much depends on that vertical pressure on both contact patches: more is good, less is bad. The lateral loads (trying to skid the tires) on the contact patches remain the same (regardless of the lean angle of the frame and suspension) as long as the turning radius and speed don't change.
As the lean angle increases, so does the angle at which the suspension "feels" and react to the vertical forces of the road's crests and valleys.
The bike and rider become dynamically heavier to the suspension in that same direction. Both results of dramatic lean angles and turning forces make the best suspension just marginal.
Another purpose of the technique is to increase the speed in a turn beyond the speed to which the dragging hard parts of your bike allow you turn. Let's say your bike max physical lean angle under the dynamic loads (bike and rider are heavier to the suspension while turning) of a turn is 45 degrees (measured between a vertical line and the middle line of your frame); so, 46 degrees = sparks and tires pivoting up = less vertical pressure = no good). If the radius of that turn is 200 feet and you have reached that point in a straight riding position, you can only go 56 mph. If you, instead, hang-off properly, you could go 59 mph. The reason is that, by hanging-off, the rider-bike combined center of mass is off center several inches, which allows a combined lean angle of 49 degrees, while the angle of the frame remains at 45.
Counter-steering is the only really effective technique to bring the bike in and out a leaned attitude; weighting the pegs and leaning the body helps, but just a little fraction: hanging-off while braking before the turn doesn't induce a circular trajectory.
Check this related thread:
http://www.ninjette.org/forums/showthread.php?t=119958
Sorry for the length of the response
Old March 29th, 2013, 10:12 AM   #6
good video. i really enjoy when people explain the details... like "push your outside heel forward against the peg with your knee against the tank to keep from sliding forward under heavy braking since you will be off the bike already setup BP wise" and the rest of the details he gives... these are little things that are really hard to notice by yourself but make a huge difference
Old March 29th, 2013, 11:14 AM   #7
bfpower
ninjette.org mafioso
bfpower's Avatar
This. I use these techniques to some degree and it can really give you a lot more breathing room when you find yourself in a decreasing radius turn or just anytime you don't want to end up on the side of the road. Honestly, there's no excuse for sloppy street technique when such great resources are freely available.
bfpower is offline   Reply With Quote
Old March 29th, 2013, 03:17 PM   #8
mfresh
mfresh's Avatar
Exactly. The little tidbits of really specific information that can make really big differences are awesome-- all from the comfort of my chair at home!
The information about keeping your foot towards the outside of the pegs was also something that would've taken me a while to pickup on by myself. I typically kept em close to the bike, but it makes sense to keep them on the outside so you can position your knee towards the tank and such prior to a turn.
North GA Riders
Old March 29th, 2013, 03:36 PM   #9
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
This!
Too often when watching videos, I notice that either the narrator or those talking about the video keep mentioning things that I never saw. I like seeing instructions that actually spell out what they are talking about and identify them on pictures/videos so you can see the technique in use.
Thanks for the video!
<-- Linky
Old March 29th, 2013, 04:48 PM   #10
JELY1990
Boring is my middle name.
JELY1990's Avatar
Motorcycle(s): '09 Ninja 250r
Very helpful video, thanks for sharing!
JELY1990 is offline   Reply With Quote
Old March 30th, 2013, 08:30 PM   #11
Gurk
Done here.
Motorcycle(s): -
Yaeh I pretty much watched all their videos few months ago.
They have a nice series in their youtube channel. I suggest people to check all the vids on their channel. Most of the info goes hand in hand with what Yamaha Champion school teaches.
Gurk is offline   Reply With Quote
Old March 30th, 2013, 08:31 PM   #12
Snake
Snake's Avatar
Great video!
Old March 31st, 2013, 07:10 AM   #13
CC Cowboy
CC Cowboy's Avatar
Do you have to ride a Yamaha to watch?
Old March 31st, 2013, 09:25 AM   #14
Gurk
Done here.
Motorcycle(s): -
Yes. That's the only way to access secret yamaha files. Each R6 and R1 comes with a WIN number instead of VIN. you enter that and get full access.
Quick transition and body position. Worldtraveller Ninjettes At Speed 3 September 16th, 2014 09:15 AM
Observations about aggressive body position adouglas Riding Skills 63 October 1st, 2013 03:01 PM
Body Position review/help/comments, please NevadaWolf Ninjettes At Speed 71 June 13th, 2013 11:11 AM
Body Position Critique Trailerboy531 Ninjettes At Speed 17 December 22nd, 2011 02:55 PM
Newb thoughts on body position adouglas Ninjettes At Speed 22 June 11th, 2009 04:12 PM
