Old September 30th, 2012, 10:06 AM   #1
n4mwd
n4mwd's Avatar
Intermittent Headlight Problem
I don't ride at night that much so I don't know how long this has been going on, but I noticed while riding last night that the headlight was intermittently going dim - about half intensity. Then it would come back to full intensity. I switched to high bean and had the same thing happening. Eventually, as the ride progressed, it stayed the normal intensity.
Anyone know if this is a common problem with the pregen? The bike has about 20K miles on it.
Does the headlight relay fail in this manner?
I did not notice any dimming of the dash or turn signal lights. In fact, when the headlights were in their dim mode, the turn signals were actually brighter.
My Ninja Blog
Old September 30th, 2012, 10:36 AM   #2
Battery ground
Old September 30th, 2012, 04:11 PM   #3
n4mwd
n4mwd's Avatar
Thanks, I will take a closer look at it tonight when it gets dark. This afternoon I couldn't tell anything was wrong.
My Ninja Blog
Old December 25th, 2012, 05:18 PM   #4
n4mwd
n4mwd's Avatar
Update
I found the problem. It was a faulty voltage regulator AND a bad battery. The voltage regulator was cutting off and on causing the voltage to go from 14V to 12V causing a noticeable difference in brightness. Not sure if the battery went bad because of the regulator or caused the regulator to go bad. In either case, I changed out both.
Note: The battery was cranking down to 6-7V which is too low for the igniter circuit to work properly. This was also causing hard starts. With the new battery and regulator, just a tap on the starter button and its running.
My Ninja Blog
Headlight problem puma22 2008 - 2012 Ninja 250R Tech Talk 10 August 16th, 2013 10:48 AM
headlight problem Moto126 2008 - 2012 Ninja 250R Tech Talk 2 May 20th, 2012 05:48 AM
having an intermittent starting problem! davidfriend 1986 - 2007 Ninja 250R Tech Talk 8 April 18th, 2012 05:16 AM
Intermittent headlight dowmace 1986 - 2007 Ninja 250R Tech Talk 3 May 19th, 2010 09:55 AM
Headlight Problem Chamus57 2008 - 2012 Ninja 250R Tech Talk 7 September 29th, 2009 02:53 PM
