Go Back   ninjette.org > General > Cargo Space
Old August 28th, 2013, 05:27 PM   #1
Ytse Frobozz
Not dead yet!
Ytse Frobozz's Avatar
Alu-Rack + fender eliminator = complications!
I installed my SW Motech Alu-Rack and V37 Coocase yesterday. The install was complicated by my Projekt-D fender eliminator. It turns out that the bracket for the Alu-Rack has inch-long spacers, and therefore wants to take up the same space as the turn signals. After some swearing and fiddling, I decided to unbolt my fender eliminator and stand it off along with the Alu-Rack bracket:
As you can see, this means two of the bolts are gone. It's quite sturdy as is, since the Alu-Rack bracket connects to the rest of the rack, but I'm going to get some long bolts to shore things up a bit more, and maybe fashion my own spacers out of... something.
The end result is still pretty good! Now I just need some saddlebags for mini-Goldwing mode.
Ytse Frobozz is offline   Reply With Quote
Old August 28th, 2013, 08:45 PM   #2
Numbersix
Numbersix's Avatar
Motorcycle(s): Honda Elite 110 (deceased), Green 2012 Ninja 250 (sold on Pi day); Grey/Green 2019 Ninja 400 ABS
Is that the light smoke or dark smoke windscreen?
Numbersix is offline   Reply With Quote
Old August 29th, 2013, 05:38 AM   #3
Ytse Frobozz
Not dead yet!
Pretty sure it's dark smoke.
Old August 29th, 2013, 08:47 AM   #4
BRad704
Big Dreams, Small Wallet
BRad704's Avatar
Motorcycle(s): 08 Ninja 250R (Sold), 93 VFR750F (In Pieces)
Looks good from here.
I wouldn't stress over the rack having the longer stand-offs, especially if you only have it installed when you are using all that luggage. You could always just replace the fender eliminator when you decide to take off the racks... Just a thought.
~BRad
BRad704 is offline   Reply With Quote
Old August 30th, 2013, 09:03 PM   #5
Numbersix
Numbersix's Avatar
I'd like to recommend http://www.onlinemetals.com/ as a good source for small quantities of "something."
Thanks for the reply; as you can guess from my nearby thread, I have the same rack and case, just haven't added the windshield yet. It looks exactly (except mine is GREEN) like what I'm shooting for.
Old August 31st, 2013, 03:37 AM   #6
Snake
Snake's Avatar
Great job of improvising and making it work. Looks good. Can't wait to see it with the saddlebags.
Old March 9th, 2014, 09:50 PM   #7
headshrink
headshrink's Avatar
Actually I think it's the light smoke. I say that because I have the light smoke ZG, and thought it was supper dark to be "light." It looks like the one pictured.
Old May 21st, 2014, 09:58 PM   #8
rasta
Your face
rasta's Avatar
Anyone else have problems installing the alurack w/ a fender eliminator? I just tried to install it, and it just doesn't work. Do I have to remove the eliminator first? @Kevin1956?
Last futzed with by rasta; May 22nd, 2014 at 01:13 PM.
Old May 22nd, 2014, 04:25 PM   #9
Kevin1956
Kevin1956's Avatar
I don't know @rasta. I have the stock fender.
Kevin1956 is offline   Reply With Quote
Old May 22nd, 2014, 10:57 PM   #10
rasta
Your face
rasta's Avatar
I should have done more research before buying lol. Good thing TT has great customer service. Their e-mail:
Hello,
Our products are only guaranteed to fit completely stock bikes so it is possible that it will not fit your bike if you have a fender eliminator kit.
If your top rack is still in new condition with no install marks, we can create a return for you.
Regards
Old May 25th, 2014, 08:46 AM   #11
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Ace hardware - if you have one near you
usually has a wide variety of Nylon, steel and bronze bushings…
or you could buy some automotive steel tubing and cut it to make stand offs.
What are you doing about passenger pegs?
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old June 29th, 2014, 08:41 PM   #12
Numbersix
Numbersix's Avatar
And ... the green version:
Old July 7th, 2014, 07:16 AM   #13
Klondike1020
Intrepid Adventurer
I like the tall wind screen and luggage combo ! U r ready for distance. Side cases woul complete that package
Eating some miles - breakfast lunch and dinner on that ride !
Old July 22nd, 2014, 04:21 AM   #14
wardie
Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT
my top case
I removed the rear seat and used it as a pattern to make a plate that fits exactly inside the seat area opening. I used well nuts drilled the holes in the sub frame slightly larger to accommodate and now the case sits where the passenger would be. Does not affect handling at all since it's over the rear wheel.
I purchased a used seat cut the large plastic tabs off so seat will snap into place but because I removed the plastic I cannot sit anyone on this seat. It is for looks when I take the top case off. Heading to Moto GP in two weeks I can carry several days worth of clothing no problem.
wardie
wardie is offline   Reply With Quote
Old July 22nd, 2014, 12:13 PM   #15
headshrink
headshrink's Avatar
Would love to see pics of your DIY mounting plate.
Old July 22nd, 2014, 01:38 PM   #16
iamjacob
iamjacob's Avatar
Motorcycle(s): 2011 250R SE
I know that you didn't ask me but here's the one I made. I keep meaning to do a write up but I never get around to it.
The 4 studs that you can see in the first pic are from the last 2 pics. They are 1/4-20 bolts that come up through the holes where the pilon seat rests.
The 6 holes in the middle if the plate are tapped to take the screws that hold the top case's base plate.
The down side is that it takes tools to remove the plate but it only takes a few seconds to do. It's completely secure.
iamjacob is offline   Reply With Quote
Old July 22nd, 2014, 01:40 PM   #17
iamjacob
iamjacob's Avatar
Oh and it's eventually going to get painted or powder coated black. As is I barely notice it.
Old July 22nd, 2014, 02:43 PM   #18
headshrink
headshrink's Avatar
That looks fantastic, and very sturdy. Thanks for sharing.
Old July 23rd, 2014, 07:10 PM   #19
wardie
rea rack mounting
Headshrink here's some pictures. Make a cardboard cut out of hole left when seat is removed. You'll see two holes in cross members in front and rear. Drill those out to accept 10/24 well nuts (sometimes called rivet nuts). Towards the front of the mounting you'll have to make, machine or cut spacers to keep the angle of the plate reasonable and not dipping sharply. All I have to do is take a number 2 Philips screwdriver, unscrew four Philips screws pull plate and slide on seat.
IAMJACOB has a nice set up as well the differences are my plate sits inside the rear seat opening and doesn't require more the a Philips screw driver to take it off. I would think IAMJACOBs mount would hold more weight though..both are good setups and I do not need saddlebags to go for several days. Really if you can carry three changes of clothes there's always a laundra mat somewhere
wardie
Old July 24th, 2014, 02:57 AM   #20
headshrink
headshrink's Avatar
Nice
Old July 25th, 2014, 01:39 AM   #21
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
Anyone have this Alu-Rack? If so, would appreciate them posting the dimensions. Think I'd like to try my hand at making a similar, possibly wider, one.
http://www.ebay.com/itm/321250356450...%3AMEBIDX%3AIT
flitecontrol is offline   Reply With Quote
Old February 13th, 2015, 09:50 PM   #22
Daakuryu
Motorcycle(s): Red 2012 Ninja 250
Do those Alu-Racks work with 250's right off the bat or do they need to be tweaked?
When I look at the site to see about ordering one they say there aren't any racks available for 250's.
Also are there any racks that go a little bit higher? I have an integrated brake/turn signal so I would imagine having a case right above the brake light like showing in those pictures would be an issue.
Daakuryu is offline   Reply With Quote
Old February 14th, 2015, 09:13 PM   #23
headshrink
headshrink's Avatar
The racks are built specific to the model ordered for, so no modifications are needed. There is no way to raise them, but cars can still see your light, so no problems. I'm going to be selling mine, so let me know if you're interested. It's for the 2008-2012 model.
Old February 14th, 2015, 09:45 PM   #24
Daakuryu
I have a 2012
Any reason you are selling it?
For how much?
Old February 16th, 2015, 12:11 PM   #25
headshrink
headshrink's Avatar
I have a 2012
For how much?
I'm rebuilding the engine to sell the bike. I only got one season of use out of the rack, but love it so I got one for my other bike too.... it's a beast.
Sending PM with details.
Old February 23rd, 2015, 12:48 PM   #26
Daakuryu
Mr. headshrink, you shall from now on forever be known as Ser Usestoomuchgoddamntape
Old February 23rd, 2015, 12:53 PM   #27
headshrink
headshrink's Avatar
LOL, yes sir. All that tape was because I had to make the box to both fit the part and keep shipping down. Glad you got it, and hope you enjoy it.
Old February 23rd, 2015, 07:39 PM   #28
Daakuryu
aaaaand it's already on the bike.
Old February 23rd, 2015, 07:42 PM   #29
headshrink
headshrink's Avatar
Nice!
I hope you're as happy with it as I was.
Old February 23rd, 2015, 08:02 PM   #30
Daakuryu
Still have to buy an adapter plate and a case but I am sure I will appreciate it much better than the backpack and soft backseat bag I was using before.
My wallet is on cool down right now though so it has to wait a little bit.
Old February 23rd, 2015, 08:14 PM   #31
headshrink
headshrink's Avatar
What case are you looking at buying?
That's a lot of toys you have in the mail... I'm a little jealous. All I've got is a back and forth with Revzilla on a small part mix-up (they've actually been great about it).
Old February 23rd, 2015, 08:23 PM   #32
Daakuryu
Not sure yet to be honest. Hoping to find something with a decent size at a low price for now.
The Rack and a FuseBlock FZ1 are the two that arrived today, got
  • A Koso RX2N + PnP kit (the pre shipment)
  • Ninja 250 adaptor plate for the Koso RX2N
  • BK Moto HID Kit
  • A used headlight assembly ( so I can do a retrofit and not worry about ****ing up.
I spoil her too much
Old February 23rd, 2015, 08:40 PM   #33
headshrink
headshrink's Avatar
[*] A used headlight assembly ( so I can do a retrofit and not worry about ****ing up.[/LIST]
That's how I like to do things too.
Old February 28th, 2015, 04:17 PM   #34
killerkeith
killerkeith's Avatar
Took the plunge and bought the Zero G touring screen and the Alu Rack with a Givi top case. I bought the light kit for the top case. $700 for everything. Not an easy decision but my 7 year old co-pilot can't fit on any bigger motorcycle in my price range. She wanted a back rest so we could go faster. Besides, I love this little bike. I'll post pics of the install once everything gets here.
Start>2008CBR125R>2007Ninja650R>2008BWS50>2007Ninja650R>2009Ninja250R>2009Versys 650>2009Ninja250 ST EditionCurrent
killerkeith is offline   Reply With Quote
Old April 12th, 2015, 04:33 AM   #35
killerkeith
Not having a good time. One of the bolts to attach the mounting bracket was bent and therefore ruined one of the threads as I was forcing it in. No 6mm 60 replacement bolts at home depot. Grrr
Old April 26th, 2015, 10:36 AM   #36
killerkeith
So I ended up drilling two hole so they couldn't thread into the subframe, and just used locking nuts to secure the bolts. My new issue is the Admore Lights i bought for the Givi topcase. They are not very bright, and I can't get the turn signals to flash in unison. I changed the electronic flashe, and have the diode kits. My current turn signals are LED, just can't get the AdMores to flash at the same rate.
Old April 26th, 2015, 11:26 AM   #37
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
...That's a lot of toys you have in the mail... I'm a little jealous.
I'm jealous because Jean gets to work on the bike in the house!
Old April 26th, 2015, 12:12 PM   #38
killerkeith
Did I mention how poorly lit the LEDs are with the Givi topcase? You can't even see them in daylight. Everything works as advertised, but the whole lighting system is very dim compared to my LED aftermarket turn signals. I email Admore my issues. If I can't get them brighter or turning at the same rate as the others I'm taking this back.
Old April 26th, 2015, 08:08 PM   #39
headshrink
headshrink's Avatar
They are so overpriced, I'm shocked to hear how bad they are. Thanks for saving me the $$$, as I was considering buying the kit for my Coocase. I think I'll just buy they $20 LED strip from Autozone instead.
Old April 29th, 2015, 07:45 AM   #40
Daakuryu
I'm sure if I had a wife I wouldn't have been able to work on the bike in the house.
It's finally sunny and warm here in the land of almost perpetual ice so I'll hopefully be able to take pictures of all the stuff I put in sometimes in the next day or so
Alu-Rack and seat cowl? Kevin1956 Cargo Space 1 April 8th, 2015 06:32 AM
FS: SW-MOTECH Alu-Rack Toprack for '08-'12 250r headshrink Motorcycle-related 8 February 16th, 2015 03:10 PM
One SW-Motech Alu-Rack + 1 Coocase = Numbersix Cargo Space 17 June 20th, 2013 07:50 AM
Anyone Tried the Twisted Throttle Alu-rack Top Rack? NathanF Cargo Space 47 June 19th, 2013 12:01 PM
Installed Twisted Throttle Alu-Rack Guoseph 1986 - 2007 Ninja 250R Farkles 7 October 26th, 2011 04:09 PM
