Old October 15th, 2014, 07:50 AM   #1
[sportrider - features] - 2015 Kawasaki Versys 650 ABS and Versys 650 LT First Look
Kawasaki has announced a host of updates for the 2015 Versys 650, and the new bike will be offered in a standard ABS version as well as an LT version that features hard saddlebags and hand guards as standard equipment. In addition to a styling makeover very similar to the updated Versys 1000, the 2015 Versys 650 also gets the larger three-level-adjustable windscreen and twin side-by-side headlights. The exhaust is now a one-piece unit with header pipes joining together in the under-engine collector that is claimed to provide an incremental boost in top-end power (claimed peak power went from 68.3 hp to 69 hp), and the ECU fueling curves were modified to offer better mileage. The engine receives the similar rubber engine mounting for less vibration. Suspension upgrades also mimic the 1000, with a separate function fork featuring the damping control in the right fork leg and spring preload in the left. The rear shock has modified settings, along with a remote hydraulic spring preload adjuster.
2015 Kawasaki Versys 650 LT
Brakes were also updated for 2015 with the Versys 650, with the dual discs remaining at 300mm but with different dual-piston calipers and brake pad changes aimed at providing a stronger initial bite. The rear disc diameter grows from 220mm to 250mm, along with an upgraded caliper, and the ABS system has been upgraded to a smaller, lighter unit. And last but not least, fuel tank capacity grows a half gallon to 5.5 gallons for even more range.
Pricing information for the 2015 Kawasaki Versys 650 ABS and Versys 650 LT have not been released. Both the ABS and LT models will be available in Candy Lime Green or Pearl Stardust White color options.
Related articles:
Kawasaki's press material for the Versys 650 follows:
A multi-talented, middleweight motorcycle that will make your commuting and paved adventures lots of fun!
The Kawasaki Versys® 650 ABS comes into the 2015 model year with a host of updates, including dramatic new styling, more power and torque, improved comfort as well as rubber-mounted engine and handlebar, plus new suspension to maximize your street-riding fun. The 2015 Versys 650 ABS is one of those rare motorcycles that is equally at home commuting on the local freeway or mixing it up on your favorite back road. Whatever your destination, this reliable, versatile, comfortable and nimble motorcycle will eat up the miles and encourage you to take the long way home.Two versions of the 2015 Kawasaki Versys 650 will be offered– an ABS model, with everything you’ve come to expect from this flexible motorcycle, as well as an LT model. The LT includes all the same high specification but will additionally have KQR™ (Kawasaki Quick Release) Hard Saddlebags and Hand Guards to increase its overall versatility.
KEY FEATURES OF THE 2015 KAWASAKI VERSYS 650 ABS:
  • NEW Front-end styling with an aggressive and functional design
  • NEW Repositioned footpegs and rubber-mounted engine for extended comfort
  • NEW Larger windshield with increased adjustability provides better wind protection
  • NEW SHOWA front suspension with easy adjustment
  • NEW KYB rear shock with remote preload adjuster
  • NEW Passenger grips for increased confidence and comfort incorporating KQR™ saddlebag mounting system
  • NEW Brake master cylinders and Nissin calipers
  • NEW More power and torque from 649cc parallel-twin engine with Digital Fuel Injection (DFI®)
  • NEW Larger fuel tank for extended range
  • NEW Rear subframe allows increased payload capacity
  • •NEW KQR™ (Kawasaki Quick Release) Hard Saddlebags and Hand Protectors (standard equipment on the LT model)
  • Extensive selection of Kawasaki Genuine Accessories
The 2015 Kawasaki Versys 650 ABS continues to lead the way in the street adventure segment with its proven reliability, back road ability and awesome performance. And, with the 2015 updates, Kawasaki has ensured it will continue to be the top choice as the go-to bike for riding enthusiasts needing a dependable, versatile machine at an affordable price.
FUN & COMFORT
One of the standout attributes of the 2015 Kawasaki Versys 650 ABS is its upright riding position, which is ideal for commuting, back road runs and even weekend jaunts. Its narrow frame allows the Versys 650 ABS to be nimbler than its bulky competition. And for 2015, the comfort has been enhanced with the relocation of the footpegs. Located 15mm lower and 20mm further forward in comparison to the 2014 model, the footpegs allow the rider to enjoy this versatile motorcycle in greater comfort.
The stepped seat has a tapered front and low profile, assisting riders to reach the ground. The raised passenger area is also very comfortable for extended journeys. Combined with the new footpeg location and increased wind protection, the 2015 Versys 650 ABS is a truly comfortable companion.
The 2015 model also gets a new rear subframe and revised rear suspension that will allow the motorcycle to carry a larger payload. It will also make longer road trips a pleasure, thanks to a compliant ride and impressive suspension action that allows you to make the most of any road.
As an added bonus, the new subframe was designed to integrate the optional KQR™ (Kawasaki Quick Release) Hard Saddlebags (these come standard on the 2015 Versys 650 LT model). The two bags, when combined with the purchase of the additional KQR 47-liter Top Case, will provide up to 103 liters of extra storage space. The One Key system allows a single key to be used for the motorcycle ignition and the saddlebags. So you can gear-up for longer journeys, wherever your paved road adventure may lead.
A revised upper triple-clamp has also been added for 2015. It has a rubber-mounted handlebar, which helps to reduce vibration for the rider. The rubber collars tame vibration while new rubber pads control movement fore and aft.
STYLING
The 2015 Kawasaki Versys 650 ABS has all-new, dynamic styling that is sure to catch your eye. To sculpt the aggressive new appearance, the designers took inspiration from Kawasaki motorcycle heritage with the creation of a new front fairing, where we now find a design that is equally good-looking as it is functional. Rather than the previous stacked headlights, it has two horizontal headlights incorporated into the upper cowling. The new look exudes Kawasaki’s sportbike DNA in a uniquely Versys-specific package.
Design elements include a chin spoiler under the headlights, as well as air passages on the side of the cowling. The spoiler provides downforce at higher speeds, while the passages direct air around the rider and passenger.
The new cowling also incorporates a larger windshield. It is almost twice as large as last year’s model, giving increased wind protection and reduces buffeting on the rider. It can be adjusted in height by up to 2.4” (60mm) without needing any tools, and thereby suit a wide range of riders.
The passenger handholds and tail section have been updated. The LED tail light incorporates an all-new design that reinforces the sporty image.
To add to its stunning new looks, the 2015 Kawasaki Versys 650 ABS is available in either Candy Lime Green or Pearl Stardust White to emphasize the sharp new lines.
POWERTRAIN
The dependable fuel-injected 649cc, parallel twin engine remains the best choice for this light and nimble street motorcycle with its lively performance and smooth acceleration. Derived from the Ninja® 650 motorcycle but tuned for greater torque, the engine inspires confidence for daily commuters and provides fun on weekend trips. The torquey twin delivers a deep ribbon of power in the low- and mid-range of the powerband, while also pulling vigorously to the top of the rev range.
For 2015, the engine receives a new one-piece exhaust that boosts high-RPM power, which is matched by ECU changes that have also optimized fuel economy. When combined with a larger 5.5-gallon fuel tank, the fun-to-ride 2015 Kawasaki Versys 650 ABS can now enjoy extended periods between fill-ups.
Adding to the versatility of the motorcycle is its proven six-speed transmission that seamlessly shifts between the gears, making maneuvering even easier.
CHASSIS & CONTROLS
Long-travel, high-tech suspension coupled with the revised riding position is critical to the multi-role mission of the 2015 Kawasaki Versys 650 ABS. Combine these enhancements with the updated frame and you have one of the most versatile bikes in Kawasaki’s line-up.
In the front, the all-new, adjustable Showa fork is utilized to increase rider confidence and comfort in all situations. It splits the damping and spring functions into separate fork tubes, giving the rider adjustability while also saving weight.
New longer outer fork tubes help to improve rigidity and provide the ultimate combination of light handling and supreme comfort.
At the rear, a new KYB shock allows riders to quickly make preload adjustments via the new remote-mounted adjuster. This can compensate for cargo or passenger weight or be tuned to the rider’s preference.
The crisp, linear ABS brake system is revised and included as standard equipment for 2015. The brakes incorporate several updates including new Nissin block-style calipers, new brake pad material, new master cylinders and a larger rear disc to help enhance overall braking power.
Completing the upgrade is a new, easy-to-read instrument cluster that features a revised fuel gauge, maximum range indicator and ECO Economical Riding Indicator that shows the rider when maximum efficiency is being achieved.
With all these revisions, a great motorcycle is now epic. The 2015 Kawasaki Versys 650 ABS is a highly versatile motorcycle that is equally at home on the commuter run, cruising the freeway or on your favorite back road. It’s all about having fun, enjoying life and experiencing as many fun roads as you can. This is what the dependable, comfortable, reliable and fun-to-ride 2015 Kawasaki Versys 650 ABS allows you to do with ease.
LT MODEL
The 2015 Versys 650 will be available in two models. There is the fully equipped ABS model, and then the new LT model, which has the same specification and will be supplied with standard KQR (Kawasaki Quick Release) 28-liter Hard Saddlebags and Hand Guards. This equipment will add even greater flexibility to an already accomplished motorcycle. The saddlebags, for example, will be invaluable for both daily commuting and to make it more practical for weekend escapes. Furthermore, the Kawasaki Quick Release system makes it very easy for the rider to remove and mount the bags in a matter of seconds.
The Hand Guards will further add to its appeal, bring welcome protection from the elements, increasing the long-distance comfort of the Kawasaki Versys 650 motorcycle.
ACCESSORIES
The Kawasaki Genuine Accessories program is available at authorized Kawasaki dealers. The range of options includes KQR™ (Kawasaki Quick Release) 28-liter Hard Saddlebags with the Kawasaki One Key system, as well as a new KQR 47-liter Top Case (with the same One Key system), which can accommodate two full-face helmets and can be used alone or with saddlebags. There is also an optional LED Light Bar, a 12v DC Outlet to power electronics, Grip Heaters, a low Gel Seat, Tank Bag, Knee Pads, Frame Sliders, Windshield and a Gear Position Indicator, to name some of the items offered as Kawasaki Genuine Accessories.
Features and Benefits
Key Features
  • Amazingly versatile motorcycle is exceptionally comfortable
  • NEW Front-end styling with an aggressive and functional design plus larger windshield
  • NEW Front and rear suspension
  • NEW Front and rear brake master cylinders, calipers and pad material
  • NEW Dunlop tires
  • NEW Larger, adjustable windshield
  • NEW Instrument cluster and ignition switch position
  • NEW Increased power and torque from the 649cc parallel twin with Digital Fuel Injection (DFI®)
649cc DOHC Parallel Twin Engine
  • Most compact engine in its category, helps reduce the dimensions of the entire motorcycle
  • Triangular crank and transmission shaft layout keeps the motorcycle short
  • Semi-dry sump oil system reduces overall engine height
  • Narrow, chrome composite-plated aluminum cylinders help reduce engine width
  • Tuned to deliver smooth, responsive power in the low- to mid-RPM range for exceptional roll-on response – ideal for negotiating city traffic, tight back roads or freeways
  • 180-degree crankshaft and a balancer shaft produce a remarkably smooth engine
  • Oil jets on the connecting rod ends spray oil on the undersides of the pistons to aid cooling
  • Under-engine muffler with 3-way catalyzer helps mass centralization for light handling and great looks
  • NEW One-piece exhaust and muffler helps to boost top-end performance
  • NEW Exhaust end-cap design for smarter appearance
  • NEW Fuel pump for improved fuel delivery
  • NEW Revised ECU settings to match exhaust updates and enhance fuel economy
Liquid-cooled
  • NEW KAMS (Kawasaki Air Management System) radiator air ducting system
  • Engine temperatures remain consistent for long engine life and sustained power in tough conditions
  • Coolant routed through the engine case reduces the number of external hoses
  • A pair of 38mm Keihin throttle bodies with ECU-controlled sub-throttle valves mean optimum performance
  • Sub-throttle valves, located behind the main throttle valves, give the Versys 650 ABS precise throttle response and great feel
  • Automatic fast idle system makes starting and warm-up easy, even on cold days
  • Precise fuel injection provides great fuel mileage, and the 3-way catalyzer significantly reduces emissions
Six-speed Transmission
  • Versys 650 ABS motorcycle has a racing-style cassette transmission layout that is extremely compact
Slender Double Pipe Perimeter Frame
  • Frame is small, light and narrow at the knees and pegs for excellent comfort and control
  • 3D computer analysis in the design process achieved the optimum balance of stiffness for superior ride and handling
  • NEW Rear subframe design adds strength for saddlebag mounting
Suspension
  • NEW Showa front fork has spring components in the left tube and damping components in the right, saving weight
  • NEW KYB offset lay-down rear shock includes new remote adjustable preload
  • Lay-down single shock complements the distinctive frame design, with an integrated line flowing from steering head to rear hub
  • Short, compact frame and engine design allows the swingarm to be longer, improving overall handling
Anti-Lock Disc Brakes
  • NEW Front and rear brake block-style calipers, front and rear master cylinders and brake pad material for increased braking performance
  • Standard ABS brakes
  • Same disc design as found on some Kawasaki sportbikes: the petal design offers improved cooling and warp-resistance compared to traditional discs
Six-spoke Wheels
  • NEW Versys 650-specific Dunlop Sportsmax D222 tires for light handling and comfort
  • The six-spoke wheels are similar to the ones found on the Ninja® ZX™-6R and ZX-10R motorcycles. They use less material between the spokes, so rim thickness is reduced along with overall weight
  • Lightweight wheels increase suspension performance, handling, acceleration, deceleration and initial turn-in performance
Comfortable Ergonomics
  • NEW Footpeg location is 15mm lower and 20mm further forward to accommodate a wide range of riders
  • NEW Subframe design with increased stiffness, enhanced grab rails and comfortable seating position make the Versys 650 ABS more enjoyable for the passenger, as well as allowing use of Kawasaki Quick Release (KQR™) saddlebags (standard equipment on the 2015 Versys 650 LT model)
  • Seat is tapered at the front to make it easier for most riders to reach the ground
  • Rubber bushings at the rear engine mounts, on the handlebar mount and hollow rubber-covered footpegs result in reduced engine vibration and a more comfortable ride
Unique Bodywork
  • NEW Bodywork design emphasizes sporty appearance of this touring motorcycle
  • NEW Cowling with twin horizontal headlights and a new LED tail light give the Versys 650 ABS a distinctive, high-tech appearance
  • NEW Adjustable and larger windshield provides a large still-air pocket for comfort, and its tool-less adjustability makes it adaptable to fit the rider’s preference
Instruments
  • NEW Easy-to-read instrument panel has a large analog tachometer and digital readout for the speedometer, fuel gauge, odometer, dual trip meters and clock
Versys 650 LT model
  • NEW KQR™ (Kawasaki Quick Release) 28-liter Hard Saddlebags and Hand Guards are standard equipment
  • Hard Saddlebags allow riders to carry gear on the daily commute or weekend jaunts. They mount and dismount quickly using the Kawasaki Quick Release (KQR) system and also have the Kawasaki One Key system that allows them to be locked using the motorcycle’s ignition key
  • Hand Guards are mounted with aluminum brackets and use composite covers to protect hands from the elements when riding in all weather
Kawasaki Genuine Accessories**KQR™ (Kawasaki Quick Release) 28-liter Hard Saddlebags with Kawasaki One Key systemKQR47-liter Top Case with Kawasaki One Key system. It can accommodate two full-face helmets, is color-matched to the motorcycle and can be used with the standard Hard Saddlebags Optional Saddlebag and Top Case LinersLED Light Bar to provide greater visibility for the rider and for other road usersGrip Heaters for cold weather ridingHand Guards for protection form the elementsHelmet Lock to secure your helmet to the motorcycleRadiator Guard to protect from debris and stonesFrame and Front Axle SlidersGear Position Indicator to let the rider know what gear is selectedDC Power Outlet to charge devices GPS Mount to allow you to mount a GPS deviceWindshield to provide more protection from the elementsGel Seat to provide more comfort for longer journeysBackrest Pad to keep the passenger more comfortableTank and Knee Pads to improve comfort and to protect the paintworkU-Lock Bracket to secure a lock when not in use**
2015 Kawasaki Versys® 650 ABS Specifications Engine: Four-stroke, liquid-cooled, DOHC, four valves per cylinder parallel twin Displacement: 649cc Bore x stroke: 83 x 60mm Compression ratio: 10.8:1 Cooling: Liquid Fuel injection: DFI® with two 38mm Keihin throttle bodies Ignition: TCBI with electronic advance Transmission: Six-speed with positive neutral finder Final drive: Sealed chain Frame: Double pipe diamond frame constructed from high-tensile steel Rake / trail: 25 degrees / 4.3” Wheelbase: 55.7” Front suspension / wheel travel: 41mm hydraulic telescopic fork with stepless adjustable rebound and preload / 5.9” Rear suspension / wheel travel: Single offset laydown shock with remote adjustable spring preload / 5.7” Front tire: 120/70 ZR17 Rear tire: 160/60 ZR17 Front brake: Dual 300mm petal-style rotors with two-piston calipers and ABS Rear brake: Single 250mm petal-style rotor with single-piston caliper and ABS Overall length: 85.2” Overall width: 33.1” (LT model TBD) Overall height: 55.1” (windshield low) / 57.1 (windshield raised) Seat height: 33.1” Curb weight**: 476 lb (LT model TBD) Fuel capacity: 5.5 gallons Colors: Candy Lime Green, Pearl Stardust White MSRP: $TBD Warranty: 12 months Optional Kawasaki Protection Plus: 12, 24, 36, and 48-month plans are available
Click here for full story...
[webbikeworld.com] - 2015 Kawasaki Versys 1000 LT and Versys 650 LT Preview Ninjette Newsbot Motorcycling News 0 October 26th, 2014 07:50 AM
[cyclenews.com] - First Look: 2015 Kawasaki Versys 650 ABS & 650 LT Ninjette Newsbot Motorcycling News 0 October 16th, 2014 05:40 AM
[motorcycle-usa.com] - 2015 Kawasaki Versys 650 LT/ABS First Look Ninjette Newsbot Motorcycling News 0 October 15th, 2014 05:50 PM
[motorcycle.com] - 2015 Kawasaki Versys 650 ABS/650 LT Preview Ninjette Newsbot Motorcycling News 0 October 15th, 2014 08:30 AM
[roadracingworld.com] - Kawasaki Bringing Versys 650 ABS And Versys 1000 ABS To North Ninjette Newsbot Motorcycling News 0 September 30th, 2014 04:30 PM
