Old July 21st, 2022, 12:42 PM   #1
zpromax777
Motorcycle(s): 2012 Kawasaki Ninja Ninjette 250
Advice on brakes
Brakes are 23 years old everything works, I am replacing the lines, they are not leaking.
Now do I take good working calipers apart and rebuild or leave good working factory seals out and put fresh ones in?
I can argue that leave good one alone or put fresh parts in and risk fubaring it...
I only dealt with one bad caliper on all the cars I have owned and it was leaking.
What do you do?
zpromax777 is offline   Reply With Quote
Old July 21st, 2022, 01:41 PM   #2
thedrewski86
thedrewski86's Avatar
I would replace the brake fluid with fresh, check the pads and replace them if they need it. I see no reason to replace the piston seals if everything is working though. I suppose if you have reason to suspect that the calipers are full of condensate and gel then you could... but factory seals are undoubtedly better than questionable replacements. If you replace, I would try to find real Kaw parts.
Also, 23 years old? Are you talking about the 2012 listed under your username? 10 years old or 23 years old, if the system holds pressure I would not mess with the seals. Fluid should be replaced every two years.
Don't think, look!
Old July 21st, 2022, 03:00 PM   #3
Ceeloo Yello
Motorcycle(s): 250
Also suggest only changing one at a time such as only the rear or only the front
Old July 23rd, 2022, 12:08 PM   #4
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
My philosophy is if it's working fine leave it alone ! too many other things need immediate attention on a bike ! if the bike is in great shape and needs nothing else and your looking for something to fix regardless.... go take a hike or something leave the bike alone ! LOL
Bob......
Old July 24th, 2022, 01:23 AM   #5
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Remove calipers, remove pads & give the inside of caliper a good clean & degunge. No need to strip caliper if its working good.
Brakes??? Billtrill 2008 - 2012 Ninja 250R Tech Talk 18 April 27th, 2017 01:02 PM
Brakes what would you do? crazymadbastard General Motorcycling Discussion 7 March 30th, 2015 11:27 AM
Need new brakes! corksil 2008 - 2012 Ninja 250R Tech Talk 18 September 28th, 2014 11:36 PM
Brakes marc_previtera 1986 - 2007 Ninja 250R Tech Talk 5 October 3rd, 2013 05:22 AM
Brakes Jesse8931 1986 - 2007 Ninja 250R Tech Talk 7 April 11th, 2011 06:17 PM
