Old April 28th, 2010, 06:21 AM   #1
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Do shogun sliders get in the way of carb removal?
So I'm in the midst of a round of upgrades to my bike.
In hand is my set of "after the horses have bolted" Shogun frame sliders.
On the way are a used AreaP exhaust, a K&N filter and a jet kit.
I'm going to be ripping into the bike this weekend and I have a question:
Do the Shogun sliders cause problems with removing the carbs and/or working with them still installed?
I'd hate to install the sliders first and find out after the fact (and after I've installed/stretched the special bolts) that I need to take them off to get at the carbs.
Old April 28th, 2010, 06:47 AM   #2
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
They make it hard(er) to adjust synchronization and idle mixture, but other than that, they don't make it hard to pull the carb. I adjusted the mixtures with them on, so it is doable. Just harder with less space to reach in.
A "MOS" and a ratcheting right angle wrench with driver bits will take care of you. See my build thread pics.. think some of that in there.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old April 29th, 2010, 03:54 AM   #3
adouglas
adouglas's Avatar
Mos?
Old April 29th, 2010, 07:53 AM   #4
QuarterBoreNinja
Motorcycle(s): Why do you care?
Mos?
A Milwaukee Offset Screwdriver... This little gem makes working on the carbs while mounted on the bike much easier. Around $20 at Home Depot. The thumb bracket can be rotated or removed completely, the socket is magnetic so no dropping bits...
http://www.amazon.com/Milwaukee-48-3.../dp/B0000224AW
QuarterBoreNinja is offline   Reply With Quote
airbox realignment problems after carb removal Akane 2008 - 2012 Ninja 250R Tech Talk 2 April 15th, 2014 01:04 PM
carb removal mikedabike64 2008 - 2012 Ninja 250R Tech Talk 8 November 19th, 2013 08:34 AM
Help me please! Carb Removal (I'm Stuck) zach 2008 - 2012 Ninja 250R Tech Talk 30 August 13th, 2013 08:17 PM
Gas Tank Removal; Carb Boots aweesner 1986 - 2007 Ninja 250R Tech Talk 1 September 6th, 2011 06:53 AM
Question on Shogun Sliders + Carb clearance. Betlog 2008 - 2012 Ninja 250R Tech Talk 6 December 29th, 2009 10:43 PM
