Old July 24th, 2011, 05:36 PM   #41
headshrink
headshrink's Avatar
I also got mine off easily with an impact wrench, and adapter from my impact screwdriver to accept the bit.
Everything before that was useless... even the impact screwdriver itself (the kind you hit with a hammer). Although, at the time I didn't have a torch....
Last futzed with by headshrink; July 24th, 2011 at 06:21 PM. Reason: spelling, as always
Old July 24th, 2011, 05:42 PM   #42
Originally Posted by Buffalony View Post
The heat gun has a switch that allows you to set it at two different temps. the sucker gets pretty hot.http://www.harborfreight.com/power-t...112-96289.html
No attachments came with this one. they werent needed though. It didnt damage my grips at all. Instead of aiming inline with the bar I aimed it 90 degrees to the barend so only the end was grabbing the heat. I used an impact driver as well, but it didnt take much with the heat gun on it.
The parking lot situation kinda sucks. Extension cord? Or maybe a friends house. propane torch was another good idea. if that screw head is too damaged you might have to drill it out. You could get an extractor bit too. If you end up drilling, start with a larger bit to clean up the gnarled up head, then go into the bolt with a smaller bit.
Already done at great expense (see OP ).
Old July 25th, 2011, 12:42 AM   #43
Buffalony
Buffalony's Avatar
Ok. so where are you at on this project. you have one off and the other still stuck on right?
Old July 26th, 2011, 08:19 AM   #44
Originally Posted by CZroe View Post
!@$#!ing barends, man.
...and I ended up having to pay someone $37 to remove it.
I came into this knowing what I would need and thinking I was completely prepared and yet I still ended up having to get this taken care of by a professional for way too much money....
I haven't installed my SV650 clip on bars which do fit my new universal bar ends so I've got the original bar ends back in with no Loctite (Floyd gave me one to replace the drilled-out one). I used a wire brush to clean it all out of the threads.
Last futzed with by CZroe; July 27th, 2011 at 12:47 AM.
Old July 26th, 2011, 09:48 PM   #45
Buffalony
Buffalony's Avatar
I haven't installed my SV650 clip on bars the do fit my new bar ends so I've got the original bar ends back in with no Loctite. Floyd gave me one to replace the drilled-out one). I used a wire brush to clean it all out of the threads.
Sounds like success. Drill worked well enough? Congrats.
I'll agree somebody IS going red Loctite crazy at the factory
Old July 27th, 2011, 12:53 AM   #46
Success only after giving up and paying someone $37 to do it. It stings even more when I think about the cost of everything else (pencil torch, alternate torch, butane cylinder, impact screwdriver, etc). I guess one-time use tools from Harbor Freight aren't even that (my third pencil torch failed too; didn't get a single successful use). Not sure I learned my lesson because I'd still probably go for the cheaper, more portable tool next time!
Old July 29th, 2011, 09:53 PM   #47
Suave
Suave's Avatar
I got it done with ease. The stock bar-end/handlebars might be bent a little but I don't need them now anyway since I have Woodcraft clip-ons But all I did was get vise grips on as tight as possible, I mean TIGHT onto the bar ends, then take a rubber mallet and just give it a good whack and it'll break that sucker lose no problem.
"Hey man, I'm not tryin' to start nothin'. But... i wouldn't take that"
Suave is offline   Reply With Quote
Old July 29th, 2011, 10:02 PM   #48
almost40
ninjette.org Monkey Spank
almost40's Avatar
I used propane
#2 bit and a socket wrench with the proper socket to fit the #2 bit
Black 250R
Full Area P QC
Old October 30th, 2011, 02:18 PM   #49
Mr.E
That rider dude.
Mr.E's Avatar
Motorcycle(s): 2011 White Ninja 250 SE.
Bump. So I got one end off with an impact screw driver, sadly, my left bar wasnt so lucky and stripped completely (Idk why, it was a #3). Anywho, what do I do now? I keep hearing people drill off their stripped ones, but then how do you get out the end of the screw from the bike itself? Should I find where around here who can remove it for me? I.e. a mechanic or something? Help purty please.
Mods: flushmount Led front binkers, diode mod, pazzo levers, clear tank pad, racing replica grips, bike monkeys integrated tal light, zx-2r vinyls, rearsets, red bar ends, and more red accented stuff.
Mr.E is offline   Reply With Quote
Old October 30th, 2011, 02:32 PM   #50
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
drill out the head, until it just falls off. the bar end will come off too. then take a good pair of vice grips and the pc sticking out should remove fairly easy.
#1
greatwhiteninja is offline   Reply With Quote
Old October 30th, 2011, 04:25 PM   #51
Mr.E
That rider dude.
Mr.E's Avatar
worked like a charm, thanks Ed.
Old October 30th, 2011, 04:27 PM   #52
greatwhiteninja
Ridin Dirty
Np.. glad it worked
#1
Old October 31st, 2011, 01:20 PM   #53
Mr.E
That rider dude.
Mr.E's Avatar
Out of curiosity, I need a new screw, so is it fine to ride without barends? The grips are glued in real tight, but I dont want to ride if they had a greater purpose...
Old October 31st, 2011, 01:27 PM   #54
I rode without for a while. Might be more likely to get a tank slapper... or less. *shrug*
Old October 31st, 2011, 01:41 PM   #55
DarC
DUCEATR
DarC's Avatar
Motorcycle(s): RVT1000R
Just will have some more vibration, may make your hands numb after awhile if you are especially sensitive to it. I ran woodcrafts without bar ends for thousands of miles without any problems...just a little vibration/buzzing.
2001 SP1 RC51- #62 -Akrapovic Ti, PCIII, Colin Edward's first baby tooth, Honda Racing sticker, some Japanese doods best attempt at Engrish scribbled on my engine block, little touch of soul.
DarC is offline   Reply With Quote
Old September 12th, 2012, 09:08 AM   #56
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
pencil torch = horse bladder
The King
rabies is offline   Reply With Quote
Old September 12th, 2012, 09:13 AM   #57
headshrink
headshrink's Avatar
LOL, what?
Old September 12th, 2012, 09:26 AM   #58
rabies
rabies's Avatar
humorous randomness saying that those pencil torches are junk before they leave the factory
The King
Old September 12th, 2012, 01:18 PM   #59
headshrink
headshrink's Avatar
Ah, gotcha.
Although perhaps ineffective for removing bar ends, I do love my little butane pencil soldering iron. I use it now more than the big electric soldering station, and not just because of the portability... which is very nice. I liken it to big electric stove top vs. a basic model gas range.
Old September 12th, 2012, 01:38 PM   #60
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
This is the case of "the right tool for the job." I didn't use any torches or heating elements to remove my bar ends. I bought a #3 JIS screw driver and took it off in 10 seconds. I use my #2 and my #3 JIS screw drivers when I work on the bike. Philips will strip out JIS screws pretty fast.
http://www.mcmaster.com/#jis-(japane...rivers/=j9i7sr
The www.ModMy250.com guy
Old September 12th, 2012, 02:16 PM   #61
DennyV
Motorcycle(s): 2010 Ninja 250
ehh or just use quality phillips drivers... like Snap-on =) to get mine out, i put a wet towel over the grips, hit it with a benzo torch, then took my #3 impact driver to it, came right out
DennyV is offline   Reply With Quote
Old September 12th, 2012, 09:04 PM   #62
I just drilled the head off the screw with a 1/4" bit. Problem solved.
Old September 12th, 2012, 11:11 PM   #63
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I used a lighter to heat them up and a big ole fatty phillips to take em out
AFM #676
Supersports are for n00bs
Old September 13th, 2012, 05:25 AM   #64
Redgeneral
Redgeneral's Avatar
Motorcycle(s): '09 Ninja 250r (SOLD) - Black. 2011 ZX-6R Green/Black - 2001 Garbage Bag Green KLR650
Zombie thread...but oh well.
I didn't use heat at all. 24" Breaker bar with #3 Phillips socket. Came out with no problem at all.
Redgeneral is offline   Reply With Quote
Old September 13th, 2012, 11:50 AM   #65
headshrink
headshrink's Avatar
Originally Posted by Jiggles View Post
I used a lighter to heat them up and a big ole fatty Phillips to take em out
I tried that out of desperation when nothing was working. When that failed I ordered the impact hammer that had attachments to but the included Phillips bit onto my pneumatic impact wrench. This was the only thing that would budge it for me, without a significant risk of stripping the screw head. I've been enjoying the Throttlemeisters I put in the stock ends place, although I very rarely lock the throttle.
Bar Ends skilletmo 2008 - 2012 Ninja 250R Tech Talk 8 March 8th, 2013 11:17 PM
bar ends skikman 1986 - 2007 Ninja 250R Tech Talk 8 January 7th, 2013 06:15 AM
Bar ends james250ninja 2008 - 2012 Ninja 250R Tech Talk 8 October 22nd, 2011 08:54 PM
ZX-R bar ends Shaol1n Monk 2008 - 2012 Ninja 250R Farkles 14 July 29th, 2011 12:30 PM
bar ends james250ninja 1986 - 2007 Ninja 250R Tech Talk 13 April 22nd, 2010 04:06 AM
