Old March 14th, 2012, 11:44 AM   #1
Zaydoc
Motorcycle(s): 2004 Ninja 250R
Carb Slide
Does anyone know what the factory hole size is for the slides. Not the needle hole but the vaccum hole.
Zaydoc is offline   Reply With Quote
Old March 14th, 2012, 04:21 PM   #2
No idea exactly. What are you looking to do to your slides? enlarge the hole for improved throttle response? That can be done with a #70 drill bit to make a 2nd hole, but I had issues with that last summer, so do that at your own risk. I will be going back and opening up the #70 holes again, and playing with my needle mixture to smooth out the poblems I had from drilling my slides
Old March 14th, 2012, 04:58 PM   #3
Zaydoc
They where already drill larger and I want to go back to or.
Posted via Mobile Device
Old March 14th, 2012, 05:03 PM   #4
Oh that makes more sense now.
Just curious, have you noticed any oddities when cruising at exactly 6k? does your bike completely stutter and stumble and choke? that's what mine did when I drilled my slides and what made made me decide to seal the holes up
Old March 14th, 2012, 06:18 PM   #5
Zaydoc
Yep
Old March 14th, 2012, 06:23 PM   #6
can you do me a huge favor? Like HUGE favor.
Want to add another washer to your needles and see if it helps at all?
Old March 14th, 2012, 06:38 PM   #7
Zaydoc
Mine was on the 4th clip I moved it up to 3rd, but I'll be messing with it this weekend.
Old March 14th, 2012, 06:57 PM   #8
Cool tell me how that goes. I suspect raising the needles a little might help with that 6k issue because I've read of people who haven't had any issues with that, so I know it has to be possible to do somehow. I want throttle response it got better when I installed slipons. Then it got better again when I did my intake and jetted. I want more
Old March 14th, 2012, 06:59 PM   #9
Zaydoc
I also have a R6 throttle tube and love it
Old March 14th, 2012, 07:00 PM   #10
zip-tie throttle mod. same idea but cheaper.
Old March 17th, 2012, 05:48 PM   #11
Zaydoc
Ok so I got my new jets in on Friday and got a chance to put them in today. The 110's are I think spot on for WOT. Had to raise the needles up so 5th from the top and opened up mixture screws to 3.5 but still had some popping and surging at cruise so think I'll go to 3.75 and see how that does. Next step is a #40 pilot jet.
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
Highway slide Christofini !%@*#$%!)@#&!%@ I crashed! 8 September 8th, 2013 04:11 PM
Carb Slide Orientation lotusseven 1986 - 2007 Ninja 250R Tech Talk 7 November 25th, 2010 04:43 PM
