Old January 12th, 2020, 02:48 AM   #1
Jim Moore
Jim Moore's Avatar
Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150
Torque Spec for Front Brakes - 2010 Ninja 250
Hi Guys,
I just picked up a 2010 Ninja 250. It needs new brake pads in the front, but I don't know the torque spec for the pins or the caliper bolts. Can anyone tell me that offhand, or direct me to a spot where torque values are listed?
Thanks,
Jim Moore
Jim Moore
Jax, FL
Jim Moore is offline   Reply With Quote
Old January 12th, 2020, 10:59 AM   #2
there's table here: https://faq.ninja250.org/torque/ex250j/
Hmm, no torque-spec for pad-holder shafts.
Nothing in manual either. They don’t actually have much load, so 10-15 lb*ft should be sufficient.
Also be sure to use blue Loctite on those threads.
Last futzed with by DannoXYZ; January 12th, 2020 at 06:10 PM.
Old January 13th, 2020, 03:35 AM   #3
Jim Moore
Jim Moore's Avatar
Thanks. That's just what I was looking for.
jim
Jim Moore
Jax, FL
Old January 13th, 2020, 09:12 AM   #4
Ralgha
Ralgha's Avatar
Wouldn't blue loctite be wasted with the heat of the brakes causing it to break down?
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old January 16th, 2020, 11:26 AM   #5
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
The 300 has a torque spec of 12.7 ft-lbs for the pins.
Dave Wolfe is offline   Reply With Quote
Old January 16th, 2020, 12:40 PM   #6
Would still hold in place since there's no turning torque on those pins. Even on race-bike, brake-caliper won't get too hot for too long (at least if you're going fast). Replacement pins come with blue threadlocker pre-applied to threads. Vibration can back it out due to such low torque for that size fastener. Avoid temptation to use more torque to hold it in as that will cause you issues when trying to remove later... damn $@)#&*! POs
Last futzed with by DannoXYZ; January 16th, 2020 at 10:01 PM.
Old January 20th, 2020, 11:44 PM   #7
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
I've always had trouble with those damn pins! I've always sprayed copper antiseize on em to help with the pin removal later.
I rounded out the hole for the allen wrench on that pin once and had a lovely time trying to extract the pin. After that it was anti seize all the way
[visordown.com] - Why does Kawasaki’s imminent Z900RS have higher-spec brakes than th Ninjette Newsbot Motorcycling News 0 October 5th, 2017 05:10 AM
Torque spec cheat sheet? N_hutter 2013 - 2017 Ninja 300 Tech Talk 5 December 3rd, 2014 06:59 PM
Torque spec and sequence bruce71198 2008 - 2012 Ninja 250R Tech Talk 6 November 19th, 2013 01:37 PM
04 cam holder torque spec? bcemkara84 1986 - 2007 Ninja 250R Tech Talk 1 August 6th, 2011 08:15 AM
