Old August 19th, 2010, 10:43 PM   #1
ReDnEcK
ReDnEcK's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250R
Bike lacks power after installing 15 tooth sprocket...
Installed a 15 tooth front sprocket and MT-75 tires... I have to shift into 5th now to get enough power to pass cars on the freeway. Is this how its supposed to be?
Posted via Mobile Device
ReDnEcK is offline   Reply With Quote
Old August 19th, 2010, 11:52 PM   #2
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
Increasing the gear ratio will result in slower acceleration you just use a lower gear than before when passing other vehicles. From what I know most of the riders who have chosen the 15 tooth front are riding a lot of highway where it makes sense to drop the rpm a little.
Steve
SteveL is online now   Reply With Quote
Old August 20th, 2010, 04:37 AM   #3
dubojr1
dubojr1's Avatar
Your bike must be black. Everyone knows green is the fastest!
I'm running the 15T on both my 250's. Most traveling here is done on the interstate. I wouldn't say I would have to switch down to 5th unless I needed to pass quickly. Is this the only issue your having?
Old August 20th, 2010, 06:22 AM   #4
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
The sprocket setup multiplies engine torque, and torque is what makes the wheel turn and the bike accelerate. When you increase the front (or reduce the rear) sprocket sizes you reduce the torque multiplication and therefor reduce power available to the rear wheel. That's normal.
Old August 20th, 2010, 06:26 AM   #5
want1sobad
Ninjette CPT
want1sobad's Avatar
Motorcycle(s): Black 08 250r
jeff,
have you shimmed the needles and pulled the snorkel? if not, that should fix the problem
i have 15t, 2 washers, snorkel pulled, stock exhaust - no issues overtaking on the highway.
want1sobad is offline   Reply With Quote
Old August 20th, 2010, 08:07 AM   #6
His bike is a pregen which does not have the snorkel. Shimming the needles though is a good fix. I have a 15T on mine and 3 shims on each needle. It helped acceleration tremendously.
Old August 20th, 2010, 08:51 AM   #7
want1sobad
Ninjette CPT
want1sobad's Avatar
i always forget to check if we're talking about a pregen.....
Old August 20th, 2010, 08:54 AM   #8
No worries Vince.
Old August 20th, 2010, 09:51 AM   #9
ReDnEcK
ReDnEcK's Avatar
Its a green '03... before they needed to breathe under water! As for shims... I dont know anything about that. Can you explain what your talking about please?
Old August 20th, 2010, 10:01 AM   #10
Two great threads to read:
http://www.ninjette.org/forums/showthread.php?t=11963
http://www.ninjette.org/forums/showthread.php?t=10208
Old August 20th, 2010, 01:49 PM   #11
here's another thread to help explain...
http://www.ninjette.org/forums/showthread.php?t=9465&
Old August 21st, 2010, 01:05 AM   #12
CZroe
CZroe's Avatar
Yup. Obviously, if everything remained the same at lower RPMs/higher MPG, they'd come that way from the factory!
Old August 29th, 2010, 04:37 AM   #13
leesic66
Motorcycle(s): 2005 Ninja 250
I went up in the front and I tell you its the best thing I coulda done!!! SOOOOOmuch smoother I also rejetted cuz the douchebag who owned the bike b4 me put the pods on and didnt rejet or tell me about it > I have no problems smoking anything on 4 wheels and I dont even get close to 11k rpms......
leesic66 is offline   Reply With Quote
Old August 29th, 2010, 09:15 AM   #14
Cuongism
Cuongism's Avatar
What gear did you pass cars on the highway before? I have a 15T and 6th gear will still accelerate 70 mph+, but just not as fast as 5th gear.
Old August 29th, 2010, 10:19 AM   #15
leesic66
5th..... U should remember thAt I live on an island...... people here dont drive like people on the mainland. in 5th at like 8.5k Im passin EVERYBODY
Old September 3rd, 2010, 09:13 AM   #16
sprale
Dead-thread Necromancer!
sprale's Avatar
Motorcycle(s): K5 V-Strom
I went with a 15/41 for the highways in Texas. Makes lots of difference when cruising for long stretches. I have to drop a gear to pass, it's just a part of the change. It's a Ninja! It's not like you ever get to ride much without constantly changing gears anyway, it just happens slightly more often!
2007 Kawasaki Ninja EX250 ZG250 Quarter-Concours commuter Gone
2005 Suzuki V-Strom DL1000 Big Black Vee future hack?
sprale is offline   Reply With Quote
Old September 3rd, 2010, 09:43 AM   #17
greg737
Motorcycle(s): -
I like the idea of changing the gearing to get the slightly lower highway cruising RPMs.
It's pretty obvious that if you're going to do this but you still want the bike's original level of performance, that is to say if you want the bike to "feel" the same acceleration-wise, then you've got to increase it's horsepower just a bit.
If you added an aftermarket exhaust like the Area P full-system and properly re-jetted the carbs you'd get a boost in power. Then put on the longer gearing and you'll break even on the bike's performance and get the bonus of the nice lower-RPM highway cruise.
15 tooth sprocket Hero Danny 2008 - 2012 Ninja 250R Tech Talk 4 July 7th, 2014 06:53 AM
15 tooth sprocket... Josh_kcco 1986 - 2007 Ninja 250R Tech Talk 23 January 17th, 2014 01:59 PM
JT Sprocket 42 tooth Rear Sprocket lolibater Motorcycle-related 36 February 25th, 2013 12:30 PM
15 tooth sprocket help. wild-bill 2008 - 2012 Ninja 250R Tech Talk 3 November 10th, 2010 09:39 AM
15 tooth cs sprocket mxnello 2008 - 2012 Ninja 250R Tech Talk 12 April 4th, 2009 02:25 PM
