Old July 20th, 2012, 07:48 PM   #1
rc51bullet
Motorcycle(s): '03 ninja
Unhappy bike wont fire
I guess I will make this my intro thread as well as my I need help thread. So here it goes:
Intro
I bought an '03 ninja 250 with approx. 12k miles for my wife because she has decided she want to learn to ride so she can ride with me. That being said, I bought the bike for a really good deal because the previous owner said it quit running (it was his daily) and im pretty mechanically inclined so I wasn't worried about putting in some elbow grease. Besides, the bike looks to be in pretty good condition and I didn't want a brand new bike for her to learn on just in case something happens.
Dilemma
As stated before, the previous owner said the bike quit running and when he took it to the local shop they replaced the fuse junction box and that didn't fix it. Then he told me that the bike shop told him it needed a new cdi box and he couldn't afford a new cdi box plus the shop fee so this is the reason for selling it. Anyways, I got the bike and put new ngk plugs in it plus I bought a different cdi box off ebay in hopes it would be that simple and checked all the fuses just to be safe. The bikes turns over with no problem but neither plug fires and with the key in the on position I stick my voltage meter into the plug wire and even without hitting the start button I still have power coming thru the coils. I have chased most of the wiring harness and I can't find any cut or lose wires so now I turn to you knowledgeable folks that have had your ninja for any time. Please help me any way you can.
Is it possible for both coils to go bad and still have power running thru them?
Thank you for any help or advise
rc51bullet is offline   Reply With Quote
Old July 20th, 2012, 08:44 PM   #2
Welcome to the site!
I don't know what could be wrong among the pick-up coil, module, coils and plugs; but I know how to direct you to these schematics:
http://faq.ninja250.org/wiki/Wiring_...s_%26_diagrams
Old July 20th, 2012, 09:20 PM   #3
rc51bullet
Thank you! That actually helps alot.
On a side note, what part of florida are you in? Give me a buzz anytime and we'll get a ride together
'02 RC51 (my baby) and '03 ninja 250 (her baby)
Old July 21st, 2012, 04:23 AM   #4
You are welcome.
I am in the area of West Palm Beach and mainly commute to work everyday.
Additional general info here:
http://www.jetav8r.com/Vision/Ignition/CDI.html
http://www.dansmc.com/cdiignition.htm
".....first check all the plug in connectors. Check and clean all the ground connections and make sure the kill button is working right too. Also, remember some bikes have safety kill switches at the clutch lever, the side stand....."
Old July 21st, 2012, 04:37 AM   #5
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Hello and welcome
Let's start with Basics.
Remove both plugs and put the spark plugs into the spark plug boots. Set them in such a way that the threads are touching the metal part of the engine.
Make sure the right handlebar red bar switch is in the on position. Then with it in neutral and the kick stand up. ( I hope you have a bike stand) push the starter button for a couple seconds.
Do you see any sparks at the plugs? Also then cranking it try to feel if there is air coming out of the spark plug holes. Or see if you can get a compression tester from some one .
You need compression, spark and fuel. A bike that has been sitting can have stuck piston rings and 12000 miles it could have tight valves. That will cause a loss of compression.
Sitting will also cause the carbs to foul up and then the engine will not get fuel.
And you have an ignition problem. So let's start with the basics. First do the part numbers from your original CDI and the one you bought on eBay match? They plugs are the same but there are four different ones available.
We can make it live again
- - -Bike Wont Start - - - Triple R 2008 - 2012 Ninja 250R Tech Talk 1 July 31st, 2014 06:54 AM
Help!! Need advice... Bike Wont Run Trainsk8 2008 - 2012 Ninja 250R Tech Talk 3 May 30th, 2012 06:32 PM
bike wont idle right :( 86ninjarider 1986 - 2007 Ninja 250R Tech Talk 11 August 3rd, 2011 09:09 AM
Bike wont start, please help? zev42 2008 - 2012 Ninja 250R Tech Talk 11 November 9th, 2010 01:02 PM
bike wont idle james250ninja 1986 - 2007 Ninja 250R Tech Talk 7 April 1st, 2010 12:05 PM
