Old July 22nd, 2012, 06:57 PM   #1
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
how to repair those pesky side fairings
ok so im in the process of repainting my ninja and plastic welding cracked and broken fairings. and im trying to take pics of what i do so i can help my fellow ninjas. so im going to be adding pics about other fixes as i do them but this first one is going to cover the pegs that slide under the gas tank.
like this one
the one on the left is factory, the right is the one i made.
ok so here is what you will need. you can get all these mats for under 10$ along with the tools.
1 Thumb tack -Free
some thin packing foam sheets -free from ordering stuff online
some type of glue 3$
heat shrink tubing free cuz i had it but you cna get it for 2$
a soldering iron 4$
and i lighter $0.25
Step 1, heat up the spot where the peg was and push the thumb tack into the fairing
Step 2, use the soldering iron to melt the bottom of thumbtack to the fairing
Step 3, now take the soldering iron and melt the top of the thumbtack down into a peg
Step 4, this is where the foam sheet comes into play
Step 5, cut a small strip bigger then the peg
Step 6, coat one side of the strip with glue
Step 7, wrap the foam around your new peg making it two and a half sizes bigger then the peg
Step 8, take your heat shrink tubing
Step 9, take some heat shrink tubing bigger then the peg and trim it to size
Step 10, heat the tubing on the peg in till the foam melts and allows the tubing to shrink down to the size the factory peg is.
Step 11, now take a smaller tubing and slip it over the peg
Step 12, heat it up but this time be careful not to melt the foam underneath any more then its been melted
Step 13, trim it to the right size
and boom you have a peg to slide under your gas tank, make sure to check back with me for more tips tricks and fixes for your ninja!
this is 7ox saying, ride safe, look good, and keep it Kawi!
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
Last futzed with by 7oxSin; July 22nd, 2012 at 07:02 PM. Reason: added prices
7oxSin is offline   Reply With Quote
Old July 22nd, 2012, 07:49 PM   #2
cool idea
Old July 23rd, 2012, 12:02 AM   #3
Monkeytofu
I told you bro
Monkeytofu's Avatar
Assuming most of the other pegs have some space under them (although you could just JB weld them to the old spots) this would work great for the holder pegs as well.
Old July 23rd, 2012, 06:33 AM   #4
Nice, but they sell little rubber caps damn near anyplace that sells heatshrink tubing.
Old July 23rd, 2012, 07:05 AM   #5
7oxSin
MSF Coach!
7oxSin's Avatar
Didn't see them any where at harbor frieght so I just made my own
Posted via Mobile Device
Best way to repair fairings? PloXyZeRO 2008 - 2012 Ninja 250R Tech Talk 5 April 29th, 2014 01:05 AM
[sportrider - tech] - That Pesky 65-Series Front Tire | Ask the Geek Ninjette Newsbot Motorcycling News 0 March 4th, 2014 11:00 AM
[topix.net] - Joe's Scooter Repair: Not limited to just scooters, they also repair AT Ninjette Newsbot Motorcycling News 0 August 12th, 2012 08:30 PM
