Old July 23rd, 2012, 10:47 PM   #1
Coolbpf
Limp Noodle
Coolbpf's Avatar
Motorcycle(s): 2006 Ninja 250, Fastest Red money can buy
Clutch Play
My clutch freeplay adjuster thing is all the way loose. So I have this ridiculous amount of movement at the end of my lever. I have to readjust it every single ride because it somehow works itself loose each time!
I just wondered if having so much freeplay affects anything negatively... Besides pissing me off because I go OCD that the lever won't go all the way back out
Coolbpf is offline   Reply With Quote
Old July 24th, 2012, 12:29 AM   #2
Scattcatt
Scattcatt's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR
How many miles are on the bike since the clutch cable has been replaced (if at all)? Are the adjusters staying in the same position as the cable stretches? Or are they threading back in as you ride causing the slack? Sounds like potentially a bad clutch cable to me, like you have several strands of the steel braid unraveling, gradually lengthening the cable as you use it.
As far as your second question is concerned, too much free play may not allow the clutch plates to separate completely so you could be putting excess wear on your clutch plates if they're in contact.
ATGATT
Scattcatt is offline   Reply With Quote
Old July 24th, 2012, 09:34 AM   #3
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
Additionally, it's really bad for the transmission to be shifting while the clutch is not fully disengaging. Get this issue solved before you do too much more riding.
cbdallas is offline   Reply With Quote
Old July 24th, 2012, 10:26 AM   #4
Is there a counter-nut in your adjuster?
That is what holds the thing from loosing the setting.
Old July 24th, 2012, 11:03 PM   #5
Coolbpf
Limp Noodle
Coolbpf's Avatar
No counter nut... May have broken off when it got dropped by the previous owner... Then clutch is fully disengaging though, it's not like it's slack in the catch point. It's just slack for a good ways after it catches.
Old July 25th, 2012, 05:46 AM   #6
Well,....you will need to install the nut.
[motorcycle-usa.com] - Cole Seely Play By Play at Atlanta I 2015 Ninjette Newsbot Motorcycling News 0 February 24th, 2015 04:52 AM
Why is my fender not in line with my tire and question about clutch play? SwagenGTI 2008 - 2012 Ninja 250R Tech Talk 16 March 17th, 2013 09:54 PM
Clutch lever with too much play. how to fix? 5evenz 2008 - 2012 Ninja 250R Tech Talk 11 November 11th, 2011 06:15 AM
Play in Clutch Basket Normal? *Video Inside shiftdrift06 1986 - 2007 Ninja 250R Tech Talk 2 April 21st, 2011 04:52 PM
Clutch handle play Cab305 2008 - 2012 Ninja 250R Tech Talk 2 April 22nd, 2010 05:26 PM
