Old July 31st, 2012, 09:37 AM   #1
Skid
troll bait
Motorcycle(s): 2006 Ninja 250EF
engine rattle
My bike developed a weird rattle/noise at idle. Sounds like a "slapping" noise coming from the front part of the engine - near handle bars. The bike otherwise runs fine.
Loose timing chain, maybe? I'll get it looked at this weekend, but if it's a simple fix that anyone here knows about, maybe I can save a buck or two.
Skid is offline   Reply With Quote
Old July 31st, 2012, 09:45 AM   #2
when was the last time you checked valve clearance?
Old July 31st, 2012, 09:57 AM   #3
Skid
troll bait
I've only had the bike for a couple of months. Tight valves will cause this? The bike has 14K on the odo, and don't know when the last valve job was. If it's valves, then I'll leave it up to the pros.
Old July 31st, 2012, 09:58 AM   #4
toua70
toua70's Avatar
Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission)
mine is doing the exact same thing. Weird ticking sound during cold start with choke on and then while it idles, there's a slapping or flapping sound coming from the front. I asked Kevin bout it but he said I shouldn't have to worry about the valve inspection/adjustment until 12k or so. I am closing onto 8000 miles.
toua70 is offline   Reply With Quote
Old July 31st, 2012, 10:09 AM   #5
Skid
troll bait
I was told to check valve clearance every 6000 miles or so.
Who's your mechanic? I did the brakes, oil change, and other simple stuff myself, but I don't know about valve adjustments so need to find a good mechanic.
Old July 31st, 2012, 10:17 AM   #6
toua70
toua70's Avatar
I do everything myself. But valves I'm not so confident about. I'm gonna get help from another member here with valves but he said to wait. Was sure its 7500 miles
Old July 31st, 2012, 10:24 AM   #7
Skid
troll bait
Who, Kev? Whatever happened to the tech day he was talking about?
Old July 31st, 2012, 10:46 AM   #8
toua, we can do your valves any time. the newgen and pregen have different valve adjustment schdules. first schedule for new gen is 7500 but they rarely are out of spec by then. always good to check clearances though.
Old July 31st, 2012, 10:54 AM   #9
Skid
troll bait
toua, I'll get it checked out and let you know what the source of this is. If it's a loose timing chain, it can destroy your engine eventually (so I read). I'm taking it in for servicing tomorrow.
Old July 31st, 2012, 11:19 AM   #10
toua70
toua70's Avatar
Sweet!! haha i just have to buy the hot cams kevin was telling me about. He wants to wait til he gets his new engine then we'll work on it so I can wait
Old July 31st, 2012, 11:21 AM   #11
toua70
toua70's Avatar
Cool!
Old July 31st, 2012, 11:34 AM   #12
dont bother i have a full kit
Old July 31st, 2012, 11:35 AM   #13
kawis are known for their tick at idle. it easily could be nothing but definitely get it checked by someone who knows what they are doing
Old July 31st, 2012, 01:03 PM   #14
toua70
toua70's Avatar
Sweet! Then I'll just wait on kevin and then meet you up or something
Old August 1st, 2012, 02:23 PM   #15
Skid
troll bait
update
cam chain tensioner going bad.
Old August 1st, 2012, 02:50 PM   #16
toua70
toua70's Avatar
How much was it?
Old August 1st, 2012, 03:12 PM   #17
Skid
troll bait
How much was it?
dunno yet. But the mechanic said it's not a lot of labor, and will charge $20 (30 minutes) plus the cost of the part. I think a new part is like $100. I'm checking around right now.
Valve set too wide will also make your bike rattle, but valves get tight over time not loose? :dunno
Old August 1st, 2012, 03:15 PM   #18
lgk
i think bike bandit had it for $65
Old August 1st, 2012, 03:39 PM   #19
make sure your mechanic actually measures the cam chain to make sure its not stretched. ive heard lots of stories of people taking it to the mechanic and the mechanic just replaces the cct because thats what people love to do only to have the noise return a week later.
Old August 1st, 2012, 06:16 PM   #20
Skid
troll bait
mechanic just called and said he fixed the rattle by tightening the tank bolts? LOL. I'll have to check it tomorrow when I pick it up. He initially speculated that it may be the CCT, but apparently not.
Old August 2nd, 2012, 05:01 AM   #21
n4mwd
n4mwd's Avatar
I hope the mechanic knows what he is doing. Not saying he's wrong, but too much tightening of the upper tank bolts will puncture the tank and cause it to leak.
Before doing anything, pregens have a tick issue that is caused by the clutch basket. That's a 5 second test you can do yourself.
My Ninja Blog
Old August 2nd, 2012, 01:20 PM   #22
Skid
troll bait
Picked the bike up at lunch today, and she's purring like a kitten again without costing much money. She's a cheap date!
engine rattle contact148 2008 - 2012 Ninja 250R Tech Talk 9 April 23rd, 2013 05:31 PM
2010 250R Engine Rattle TearingRaven 2008 - 2012 Ninja 250R Tech Talk 13 July 24th, 2012 07:11 PM
Rattle can touch up? WhiteRice 2008 - 2012 Ninja 250R Farkles 12 November 13th, 2011 02:12 AM
Engine and rattle noise Minnesotah 2008 - 2012 Ninja 250R Tech Talk 16 September 13th, 2010 10:51 AM
Rattle... bigrodge8 2008 - 2012 Ninja 250R Tech Talk 13 May 7th, 2010 11:06 PM
