Old July 23rd, 2013, 11:11 PM   #1
anacron
anacron's Avatar
Motorcycle(s): Triumph Street Triple R
300 Slipping out of 2nd and into neutral
Have any of you folks encountered this issue with your 300?
This typically happens when I'm accelerating hard, shift to second and ease off the gas. As soon as I start easing off the throttle in 2nd gear, I feel the gear slipping (I lose power) and I'm suddenly in neutral.
Is this common during the break-in period?
I'm not exactly babying the bike, lots of hills and curves that I refuse to ease up on (Got to get comfortable in the curves if I want to step up to the track in the future).
Here's my Youtube Channel.
Here's my Flickr Photostream.
anacron is offline   Reply With Quote
Old July 23rd, 2013, 11:58 PM   #2
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Most definitely not normal and never happens on my bike. Could you somehow only be 'partially' in gear and maybe riding the clutch? Not good for the bike if the gears are slipping like that.
Old July 24th, 2013, 12:12 AM   #3
anacron
anacron's Avatar
That might be a possibility. I usually cover the clutch and given the easy pull I may be riding it. I wonder if this is actually me, not kicking up all the way to 2nd...
Old July 24th, 2013, 12:31 AM   #4
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Shift harder. Like really kick that ****er, kick it in the nuts, straight into 2nd gear.
AFM #676
Supersports are for n00bs
Old July 24th, 2013, 12:42 AM   #5
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Try lowering your shift leaver down some so it takes less movement of your foot to shift up
Old July 24th, 2013, 01:39 AM   #6
JELY1990
Boring is my middle name.
JELY1990's Avatar
Motorcycle(s): '09 Ninja 250r
Like Jiggles said, kick up harder. You can also try putting pressure on the shift lever before pulling the clutch in. Also, since 300's have a friction zone pretty far out, you might accidentally be causing slipping by covering the lever.
JELY1990 is offline   Reply With Quote
Old July 24th, 2013, 10:22 AM   #7
sprinter
Motorcycle(s): 2018 Ninja 400 Race Bike (in progress...)
Mine was back-shifting out of 4th and 5th gear at full-throttle high-rpm at the track last week. I run a quick-shifter on it, and it was going into the gear cleanly but then popping back down to the lower gear after a second or two. I just installed the FactoryPro shift detent kit in it and will try it again at the track this weekend to see if that solves the problem.
sprinter is offline   Reply With Quote
Old July 24th, 2013, 10:41 AM   #8
anacron
anacron's Avatar
Good to know, keep us posted on this.
Old July 24th, 2013, 10:49 AM   #9
.........during the break-in period?........... I'm not exactly babying the bike.........
This may be part of the problem.
Nothing wrong with being smooth and nice with a baby machine;........ it will return to you as reliability and precise controls later on.
Rather than using damaging hard or pre-loading shifting, take your time on moving the selector lever all the way until your foot feels a solid top.
Assertive and ample clutch-in doesn't hurt either.
I second the shifter adjustment to your ergonomics.
Old July 24th, 2013, 11:33 AM   #10
harder is incorrect. being abusive on the shifter will result in ****ed up shift drum arms. (these are different from the shift forks) but anyway, the problem is that you are not releasing the hold on the engine for long enough. that means that you are not snapping the throttle closed fast enough, or not leaving it closed for long enough, or using the clutch and not pushing the lever down all the way before reapplying power.
once you shift, hold the shift level down (or up... which ever direction you shifted) for a few seconds past the shift. if you let it up too quickly it can fall out, or if you let it up when you are going to fast with your throttle close/clutching you can only engage the gear partially and it will slip out next time the gears aren't pressing against each other (let off throttle)
note, don't hold the shift lever away from center position too long, just a second or two. count "one-one thousand, two-one thousand" there is a little spring in there that loses tension over time by moving the shift lever (this is what returns it to the center position) and i actually just lost that spring the other day because it lost enough tension to the point that the spring came off the arm.
Old July 24th, 2013, 01:03 PM   #11
anacron
anacron's Avatar
I think you've hit it... I'm pretty sure my mechanics for quickly shifting up/down isn't good enough (or doesn't match the 300 well). I think I'm trying to force myself to be faster with shifts rather than smoother. I'll keep this in mind and build that muscle memory before trying shift quicker.
This aside, the bike's been a blast and I'm absolutely addicted to riding.
Old July 24th, 2013, 06:34 PM   #12
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I had it happen once, scared the crap out of me. Put it back in gear and never had it happen again. Dunno the cause, or the solution... Was a one and done situation
Old July 25th, 2013, 03:01 PM   #13
anacron
anacron's Avatar
Today was much better. I was paying attention to how quickly I was letting the clutch and how much throttle I was giving. Turns out it was a combination of letting the clutch out too quickly and too much throttle.
Practiced smooth clutch releases and the ride was really good.
Old July 25th, 2013, 03:35 PM   #14
the 300 was a dream to shift with compared to the 250. clutchless was effortless and smoother than clutched upshifts i thought. i tried as hard as i could to lock up the rear wheel with engine brake alone and couldn't get more than a chirp out of it with the slipper.. really smooth let go on the slipper too, nothing abrupt at all. i was very pleasantly surprised. if you feel spicy, try not using the clutch when upshifting. its easiest when done from WOT. be safe.
Old August 23rd, 2013, 01:11 PM   #15
tuan3742
tuan3742's Avatar
Motorcycle(s): 13' zx-6r 636
this has actually happened to me once. but i think it was more rider error rather than the bike. was riding hard and i think i didn't fully upshift.
Yes, I'm a squid. But it's okay, I love squid, so can you
tuan3742 is offline   Reply With Quote
Old August 23rd, 2013, 01:14 PM   #16
anacron
anacron's Avatar
Yeah, I agree. I was still in my fantastic, super noob phase. I've since gotten the shift lever adjusted (pulled it down a bit to decrease foot travel) and I haven't had issues with not fully upshifting.
Gotten over the positive neutral finder too...
Old August 24th, 2013, 06:42 AM   #17
JohnnyBravo
I got mine to do it a second time... Def rider error!!! I know what I did wrong each time, never had it happen anywhere but second. Good job sorting yours out
Old September 14th, 2013, 11:42 PM   #18
Sargent
Sargent's Avatar
Motorcycle(s): Kawasaki Ninja 300
I've actually had this issue on my 300. I was kicking the shifter at the same time that I was releasing the clutch. My hands were moving a bit faster than my foot apparently. Started holding the clutch a half second longer and haven't had the issue again.
Sargent is offline   Reply With Quote
Old September 30th, 2013, 09:51 PM   #19
Surferboy120
Finding some curves....
Motorcycle(s): 2013 300 Ninja
I have the exact same issue identically to you and I have also ordered the Factory Pro shift kit. Some might have been rider error but some definitely were not. No quick shifter here I might add. I hope this shift detent kit resolves most of this.
Surferboy120 is offline   Reply With Quote
Old October 1st, 2013, 08:35 AM   #20
sprinter
The shift detent kit did firm up the shifts, but I still get that backshifting problem occasionally. I've narrowed it down to occurring pretty much only on the first couple of laps when the engine is colder, after that it never seems to happen. Also, with the quick-shifter I have to be very sure not to let my foot come anywhere close to the lever in between shifts or I can accidentally bump it and cause the issue that way.
Old October 1st, 2013, 08:38 AM   #21
Surferboy120
Very good information thank you
Old April 16th, 2015, 08:28 PM   #22
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Anyone had issues with being in 3rd gear and slipping back in neutral?
Riding it like I financed it.
Old April 24th, 2015, 01:33 PM   #23
Sirena
Sirena's Avatar
Motorcycle(s): Ninja 300, GSXR 600, CBR 500
Question
I just raced the 300 for the first time this weekend and was having a LOT of trouble up-shifting while under hard acceleration. Not sure what percentage of this is rider error
So I'm reviving this thread - hoping to hear more from you guys! If it's mostly me, then I don't want to prioritize spending on these parts...
Any updates?
~ The way to go fast is to never slow down ~
Sirena is offline   Reply With Quote
Old April 24th, 2015, 04:10 PM   #24
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Not completely unheard of... sounds like to me the ninja 300 gear box is garbage or something... I've had it slip a few times on me... My old ninja 250's did it too actually. I heard kawi had clunky gearboxes..
Be careful. Remember you are
invisible
Old April 25th, 2015, 08:30 AM   #25
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
Mine tends to do pop out of gear when decelerating under engine braking, very disconcerting when you're tipping into the corner!
GregS is offline   Reply With Quote
Old May 22nd, 2015, 09:29 AM   #26
APEmike
Motorcycle(s): 2014 Ninja 300
Seems like I need to talk the boss into undercutting a 300 trans up and down to see if it helps...
Old May 22nd, 2015, 10:19 AM   #27
GregS
Would be nice to see the results of that
Old May 26th, 2015, 09:08 AM   #28
APEmike
Yes it would be. Might help the transmissions live longer as well. It does with the Hayabusa powered cars and drag bikes that we normally do it for.
Old September 16th, 2015, 10:53 AM   #29
bad vibe
Motorcycle(s): 2014 Ninja 300 SE ABS
mmm love when i dont kick it hard enuff
bad vibe is offline   Reply With Quote
Old September 16th, 2015, 11:44 AM   #30
sprinter
Since this thread is still alive, I guess I'll provide an update here. The FactoryPro shift detent kit did nothing to help this problem, and it continued all through the 2014 season and was still doing it this year. I found that it was more prevalent when the engine was cold, but that was not true all of the time. It finally gave up the ghost at Road America when I was up there for the race wekeend July 4th, at that point it would literally not go into 5th gear any longer so I had to retire from the race weekend. It actually backshifted on it's own from 5th to 4th when I was in the middle of the carousel, and just about blew me off the track, I parked it after that session and called it quits. Haven't torn it apart yet to see what things look like, but we have quite a few guys running in our Ninja 300 Spec race series and virtually everyone is having problems with the transmission not staying in the higher gears during hard acceleration. It's not rider error, it's something mechanical, just not sure exactly what yet since I haven't torn mine apart. I'll update once we have it torn down. I suspect there are dogs rounded off, but it could be some other kind of problem with the shift drum or detent.
Old September 16th, 2015, 11:49 AM   #31
bad vibe
damn, glad I top out at about 75mph, probably just doesn't like that I'm over 200lbs
Old September 16th, 2015, 03:10 PM   #32
APEmike
The factory transmission is not undercut at ALL, thats why its happening. Its not so big of an issue on the 250 due to the lower power output but the 300s need it. Aftermarket undercutting will fix this. Ill have pics soon of before and after on a 300 trans my shop is doing.
Old September 19th, 2015, 05:56 AM   #33
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
Hold the shift lever up with your foot and let it go ONLY after you've fully released the clutch.
Guarantee you it won't drop out of gear anymore.
Linkin is offline   Reply With Quote
Old September 19th, 2015, 12:56 PM   #34
snot
sammich maker
snot's Avatar
MOTM - Apr '15
never had the issue with mine. I do still have a factory warranty and I am renewing it for another 2 years because of the bugs I read about.
that being said my bike is within the first 1100 made.
Old September 19th, 2015, 01:13 PM   #35
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
^^^ I agree, seen that advice many times, must be worth it.
xXecuterXx2 is offline   Reply With Quote
Old September 19th, 2015, 02:37 PM   #36
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Pre-loading the shift lever with your foot just before you pull in the clutch also helps assure a crisp shift. (It's a habit for riders of BMWs with older Getrag transmissions).
Old May 31st, 2016, 02:57 PM   #37
1wardogusmc
1wardogusmc's Avatar
Motorcycle(s): 2010 250/ZX-10R, 2014 300
What kind of oil are you using and how many miles since last change?
1wardogusmc is offline   Reply With Quote
Old June 7th, 2016, 09:08 AM   #38
TP Ninja
Motorcycle(s): 300 Ninja
Bent shift fork from too many wheelies. Engine tear down.
TP Ninja is offline   Reply With Quote
Old June 7th, 2016, 09:36 AM   #39
allanoue
allanoue's Avatar
MOTM - Sep '14
OP July 24th, 2013, 02:11 AM
Going from 1st to 2nd I hit neutral?? TwoWheelNinja General Motorcycling Discussion 6 October 10th, 2012 07:49 PM
Downshifting by itself from 2nd into neutral?? azimmer11 2008 - 2012 Ninja 250R Tech Talk 6 August 15th, 2012 08:23 AM
Clutch slipping - False Neutral....? sopranos 2008 - 2012 Ninja 250R Tech Talk 6 November 16th, 2011 04:31 PM
slipping from second into neutral...? clintalmighty 2008 - 2012 Ninja 250R Tech Talk 8 March 21st, 2011 08:43 AM
Clutch is slipping when I accelerate hard in 2nd or 3rd bliket 2008 - 2012 Ninja 250R Tech Talk 22 January 18th, 2011 04:02 PM
