Old June 1st, 2016, 06:14 PM   #1
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Is RK Racing a reputable brand?
Looks like I can't make it to 20k. I adjusted my chain tension exactly a month ago. Today (and 2,000 miles later), during my pre-ride check, the tension was over 2 inches (hitting the swingarm). I had to adjust it again. Torqued the axle nut to 72lbs/ft. But my tight spot vs loose spot on the chain is close to 1" difference. Some portion of the chain almost hits the swingarm. Other portions of it barely moves.
Anyway, it's time for a new chain. RK Racing a good brand? Is there any reason why I shouldn't get this chain? http://smile.amazon.com/RK-Racing-Ch...ords=520+chain
Additionally, my rear sprocket still looks pretty good to me. Can you guys confirm? I'm not going to replace it.
Riding it like I financed it.
Old June 1st, 2016, 06:34 PM   #2
That sprocket is new.
How the small one looks?
That difference in slack is crazy.
Could it be that it happens for each full turn of the tire?
In that case, the sprocket may not be rotating in a concentric way for some reason.
Old June 1st, 2016, 07:21 PM   #3
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
RK makes good chain. I run them.
Goin' fast on slow bikes!
Old June 1st, 2016, 07:34 PM   #4
Ghostt
Ghostt's Avatar
Same here.
violente et ignorantia
ZX-2R BLOG
Old June 1st, 2016, 07:35 PM   #5
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Front cog looks pretty good as well the last time I checked 2 months ago when I took off that little cover to degrease that whole area. I also thought the sprocket wasn't centered, but it doesn't seem to be the case. The tight and loose spots are at the same place. Not dependent on tire/wheel rotation position.
I just ordered the chain. I'll see how it is after installing it. If I still have the massive tight/loose spots, I'll change the rear sprocket and front cog.
Old June 2nd, 2016, 12:13 AM   #6
pratik06
Motorcycle(s): Yamaha R15, Kawasaki Ninja 300
As good as DID. Another good chain is Tsubaki.
pratik06 is offline   Reply With Quote
Old June 2nd, 2016, 12:21 AM   #7
MrAtom
MOTM - July '15
I've been personally advised against buying from RK racing (after purchasing that specific one and installing it). Since last year, no issues. It's doing its job. Would recommend.
Old June 2nd, 2016, 10:49 AM   #8
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Cool. Who advised you not to purchase RK Racing chains? If this new chain can last as long as the OEM chain, I'll be a happy camper.
If I read the warranty correctly, it says 20,000 mile warranty. Not sure how you go about filing a claim if the chain stretches like crazy. That's probably just normal wear and tear, not a manufacturer's defect.
Old June 2nd, 2016, 11:23 AM   #9
Suki2003
Ninjette Lurker
Motorcycle(s): 2003 Ninja EX250 (Cafe, Naked, Wreckurrected)
I have a chain from RK on a Pregen, 8K on it, I clean and lube it every 2-4 hundred miles. Still good, no slack on the sprockets
Suki2003 is offline   Reply With Quote
XT Racing GPX Pro 4 GPS Lap Timer brand new Racingredhead Motorcycle-related 0 October 11th, 2015 08:46 AM
[motorcycledaily.com] - MX Sports Pro Racing Announces the Winner of a Brand New 201 Ninjette Newsbot Motorcycling News 0 August 27th, 2014 10:40 AM
Is PBR a reputable company? Looking for frame sliders AdreeN 2008 - 2012 Ninja 250R Farkles 5 October 6th, 2010 07:50 PM
FS: Brand New Throttle Racing Products Ultra-Flow Helmet, $125 Shipped camaroz1985 Miscellaneous 5 August 26th, 2010 07:00 AM
What does a Craigslist reputable bike ad look like? Grn99Kawi General Motorcycling Discussion 4 September 4th, 2009 01:53 PM
