Old June 13th, 2016, 05:31 PM   #1
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
How I replaced the chain using "regular" tools
With 18,000 miles on the OEM chain, the delta between the tight spot and the loose spot was ridiculously huge. At the tight spot, I had less than 1/2" of play. At the loose spot, I had more than 2" of play (chain was able to hit the swingarm at the loose spot).
The OEM rear sprocket and front cog are in really good shape and I decided not to change them.
I didn't want to buy a chain breaker/chain tool. These are the tools I used to replace my chain:
1. A $10 Harbor Freight grinder with a cut off wheel
2. A random nut I had lying around
3. Vise grips (pliers)
4. Needle nose pliers
Riding it like I financed it.
Old June 13th, 2016, 08:04 PM   #2
Clips and o-ring chains don't get along.
I would use safety wire around it, if not a riveted link.
Old June 14th, 2016, 06:20 AM   #3
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Or you can remove the big pivot bolt and pop the swingarm out to install a pre-made chain loop. I'm sure it's more complicated on a bike without a centerstand, but it is possible to swap OEM chains with just undoing (a number of) nuts and bolts.
"factory spec" chain brand? Insan3guy General Motorcycling Discussion 19 June 26th, 2014 11:17 AM
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl Ninjette Newsbot Motorcycling News 0 August 16th, 2012 04:30 PM
[motorcyclistonline] - RK Chain GXW Series "XW"-Ring Chains Ninjette Newsbot Motorcycling News 0 May 25th, 2011 01:20 PM
Is any 520 sized 106-link chain "the right chain?" If so, what's wrong with these? CZroe 2008 - 2012 Ninja 250R Tech Talk 12 March 24th, 2010 12:36 PM
is there such a thing as a "non rusting chain"? poo poo 2008 - 2012 Ninja 250R Tech Talk 4 February 27th, 2010 10:21 AM
