Old July 20th, 2016, 07:00 PM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Anyone else think the stock muffler sounds really good?
We recently bought a Ninja 300 after owning a pregen Ninja 250 for a while. The stock exhaust on the 250 is pretty pathetic, so I was expecting the Ninja 300's sound to be similar, but boy was I wrong.
The Ninja 300 stock has a nice, throaty sound to it, and it's not overly load. It's actually quite perfect for my taste.
Anyone know if I could use stock Ninja 300 mufflers on the pregen 250? If I could find a pair of them for cheap, I'd love to slip them on the 250.
Cra1g is offline   Reply With Quote
Old July 20th, 2016, 11:57 PM   #2
rgx107
Motorcycle(s): Ninja 300
I like it too. It is heavy but I think that is needed to avoid the tin can type of noise that is common with aftermarket mufflers.
Don't know if it can be fitted to the older 250s.
rgx107 is offline   Reply With Quote
Old July 21st, 2016, 06:37 AM   #3
Brother Michigan
Motorcycle(s): 2013 Ninja 300
The noise you're hearing is more than likely the induction noise, which is from the airbox rather than the muffler. To a third party, the 300 sounds just as much like a sewing machine as the 250.
DISCLAIMER: I generally have no idea what I'm talking about.
Old July 21st, 2016, 08:28 AM   #4
DanteCoal
DanteCoal's Avatar
Motorcycle(s): 2016 Ninja 300 ABS, R.I.P 1986 Ninja EX250
I personally dislike it, and agree with what Brother Michigan is saying. I thought it didn't sound bad, until a friend of mine got a 300 and rode past me on it. There wasn't much a throaty, deep sound at all. =(
DanteCoal is offline   Reply With Quote
Old July 25th, 2016, 08:44 AM   #5
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I thought it sounded fine! I liked my areaP better
Old August 5th, 2016, 08:09 AM   #6
3ØØ
3ØØ's Avatar
Motorcycle(s): '13 ninja 300
stock exhaust sounds like baffled farts. what i do like with the stock exhaust, is that in high rpm's you can really hear the engine trying to go high pitch indy style.
one of the main reasons i will upgrade from this bike one day i because it doesn't have that beautiful F1 4cyl sound. pretty much the deal breaker for me, otherwise id keep it forever. now if it had a 300cc 4cyl, like some of 80's&90's cbr250rr's having 250cc 4cyls revving to the moon(20,000rpm's), that would be a different story.
although some do track this platform, or use it for commuting 60+mpg's, i see this bike as nothing more than a stepping stone to a 600cc bike.
3ØØ is offline   Reply With Quote
Old August 5th, 2016, 08:23 AM   #7
Cra1g
Cra1g's Avatar
Haha, I guess that's a good way to put it, actually.
I think compared to the stock exhaust on my pregen Ninja 250, the stock exhaust on my Ninja 300 just sounds waaaayy better. Has a deeper, grumble sound to it compared to the 250.
But yeah, there's really no good way to make a parallel twin sound really good, even with an aftermarket slip-on.
Old August 5th, 2016, 08:31 AM   #8
allanoue
allanoue's Avatar
MOTM - Sep '14
@NevadaWolf put a 300 can on her new gen 250
Old August 5th, 2016, 08:34 AM   #9
JohnnyBravo
300 sounds way better than my feet, or the cards in my bike spokes
Old August 5th, 2016, 06:17 PM   #10
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
You need a TurboSpoke!
Goin' fast on slow bikes!
Old August 5th, 2016, 07:11 PM   #11
Tim Fox
Tim Fox's Avatar
Motorcycle(s): 2014 Ninja 300 SE
Love the way my 300 sounds when I gas it!
:green moto:
Tim Fox is offline   Reply With Quote
Old August 5th, 2016, 07:20 PM   #12
JohnnyBravo
Originally Posted by RacinNinja View Post
You néed turbo spoke
Old August 5th, 2016, 07:21 PM   #13
JohnnyBravo
I love the sound all the way up to redline, the higher the better! Then again the 3 ain't stock here
Old August 5th, 2016, 08:37 PM   #14
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I don't hear mine, I hear everyone else's exhausts hahaha
Old August 6th, 2016, 06:47 AM   #15
JohnnyBravo
I liked the sound from the factory, I love the sound from the areaP
Old August 14th, 2016, 05:45 AM   #16
TP Ninja
Motorcycle(s): 300 Ninja
I wear earplugs. My boot hits the stock heat shield so I wouldn't buy an aftermarket pipe. It's not worth $400. You can do better things with your money, like feed some hungry people.
TP Ninja is offline   Reply With Quote
Old August 14th, 2016, 07:19 AM   #17
greg737
Motorcycle(s): -
The elements of engine+exhaust noise that we enjoy are due to the engine's architecture, not the exhaust system.
The EX250 engine is very noise-handicapped at idle and low RPMs by its architecture: you probably know that the EX250 is a parallel twin with a 180 degree crankshaft (a.k.a. flatplane crankshaft). This architecture results in a firing order that has two pulses only 180 degrees apart followed by 540 degrees of nothing.
This quick double pulse followed by a long pause sounds really bad to the human ear. Unfortunately there's nothing you can do about that, a different exhaust system will only make the exhaust sound louder or softer but it cannot change the nature of the exhaust.
At high RPMs it all evens out (thankfully). At high RPMs all engines configured with even-numbered cylinder counts and a 180 degree crankshaft sound identically pleasant to the human ear. At high RPMs the EX250 has the same sound appeal as other engines with flatplane crankshafts: same as motorcycles with inline-4 cylinders and V-8 engines with flatplane cranks (like Ferraris and the new Ford Mustang GT350)
Old August 14th, 2016, 08:20 AM   #18
cuong-nutz
cuong-nutz's Avatar
If you wanted, you could gut the stock can and cut the internal baffle to make it a semi straight through.
HalfFast Racing Team
Old August 15th, 2016, 10:12 AM   #19
APEmike
Its tone is OK but thats it. Its WAY too quiet for me. Plus its heavy... Besides, between 5,000 and 9,000 it picks up a Ducati-like sound either un-muffled, or with an aftermarket slip-on.
I ride because therapy is too expensive, and less fun.
Old August 17th, 2016, 03:48 PM   #20
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I prefer the sound of my ZX6R at sixteen thousand revolutions per minute.
Old August 17th, 2016, 03:55 PM   #21
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Someday you'll win a race!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old August 17th, 2016, 03:59 PM   #22
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
But...I've already won a few
Old August 17th, 2016, 04:11 PM   #23
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
Just an easy play on words. I had to swing at it!
Old September 6th, 2016, 04:20 PM   #24
benhh972
Motorcycle(s): 2012 CBR 250R, 2013 Ninja 300
I like the way most engines sound when they are wound up. I like the way my stock bike sounds and the muffler does not even look bad. The muffler on my CBR 250 was awful looking.
My favorite though is the crackle and pop I get sometimes get when decelerating.
benhh972 is offline   Reply With Quote
Old September 6th, 2016, 08:46 PM   #25
JohnnyBravo
I have been known to crackle and pop mine on purpose too @benhh972
Old September 8th, 2016, 07:45 PM   #26
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
A friend of mine once suggested, to a few of us who hated the sewing machine sound...
"Drill a hole to your stock exhaust. get a fine thin wire and tight a nut inside the muffler. Each time you open up the throttle the gas will push the wire hence the hanging nut will hit your muffler's inside wall. You'll get a sewing machine made by ducati's sound..."
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old September 21st, 2016, 07:36 AM   #27
travellingtenor
travellingtenor's Avatar
Motorcycle(s): 2013 Kawasaki Ninja 300, 2001 Honda Goldwing, 1996 Honda Pacific Coast, 1994 Honda Magna 750
No stock exhaust for me. I hated the sound. It was the first mod that I did to my bike when I installed the Yoshimura slip on. Less weight and a much better sound IMHO.
travellingtenor is offline   Reply With Quote
Old September 21st, 2016, 07:52 AM   #28
Cra1g
Cra1g's Avatar
To each his own I guess. I just like how it has a deep grumbly sound to it when idling, as opposed to other stock 250/300 exhausts I've heard.
2010 + stock muffler and muffler cover Boom King Items Wanted 2 October 28th, 2012 03:42 PM
kawasaki shows how lame a stock 650 sounds! Klondike1020 General Motorcycling Discussion 35 June 28th, 2012 01:27 PM
2008 ninja green seat cowl ,stock muffler and header,and stock sprockets Darkshadow4ya Motorcycle-related 0 December 3rd, 2010 08:02 PM
