Old September 4th, 2016, 05:22 PM   #1
algs26
Motorcycle(s): ex300, gave up looking for a 250
Question Vortex rearset install
I'm trying to install my vortex rearsets and I'm running into an issue.
The hinge pin that connect the pedal to the master cylinder doesnt quite fit in the pedal. I'm thinking about going to the dealer to see if a new one will fit but I'll have to wait until they open. I'm wondering if it's the manufacturing tolerance. Or can I find a slightly smaller one at a hardware store?
I can see some white space when I look from above.
Maybe I should just give it a good whack.
algs26 is offline   Reply With Quote
Old September 4th, 2016, 06:27 PM   #2
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I had no issues installing mine. You might want to contact Vortex about the issue.
Old September 5th, 2016, 12:04 PM   #3
algs26
Guess I'll shoot them a note then.
Did yours come with a shift rod? Mine just had the ball joint so I have to reuse the stock one.
Also the brake pressure switch wiring seemed kinda short. I doubt that I can get the connection under the body work. Did you have that issue?
Old September 5th, 2016, 01:22 PM   #4
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Extra grease + rubber mallet?
My Ninja 300
Old September 5th, 2016, 05:22 PM   #5
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Mine came with a couple of ride and I bought the switch.
I had no issues, I just had to wire the new switch (I cut the wires so they would be long), I used the existing wires and added connectors.
Old September 5th, 2016, 05:26 PM   #6
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Pics
Old September 5th, 2016, 05:37 PM   #7
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Kit should be RS424K
https://www.vortexracing.com/shop/product/17194/1475/
Instructions https://www.vortexracing.com/file/293/
Old September 5th, 2016, 09:39 PM   #8
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I hit mine with a hammer. mine came with a shift rod... Put blue loctite on it; mine came loose once ( it's no fun )
Old September 15th, 2016, 11:46 PM   #9
algs26
Reused the original rod and it seems fine after I moved the shifter connection a few teeth.
Old September 16th, 2016, 02:43 PM   #10
JohnnyBravo
Sweeeeeeet
Old September 16th, 2016, 03:08 PM   #11
Normally you try to set them up so the arm on the transmission shaft is parallel to the arm on the foot lever. It looks like the shift shaft arm on yours is rotated way toward the pedal. That could make for odd shifting, especially in the downshift direction. Can you extend the rod any more to get them closer to parallel?
If it's not a problem and it shifts great, ignore me.
Old September 16th, 2016, 06:04 PM   #12
algs26
It's pretty maxxed out downwards. There's adjustment room upwards.
At the stock marking, the pedal was around 10 o'clock.
Old September 16th, 2016, 06:11 PM   #13
Well, like I said, if it works well, nothing needs to be done. If it doesn't, I'd get a longer rod. The kit looks like a high quality one. Maybe they forgot to include the rod, and a phone call would get you one.
Old September 18th, 2016, 12:43 AM   #14
algs26
Success!
After much elbow grease and sand paper:
Old September 25th, 2016, 10:29 PM   #15
algs26
Done. After "only" 3 weeks.
Last futzed with by algs26; September 28th, 2016 at 12:30 PM. Reason: switched to daytime lit shots
vortex rearsets snot 2008 - 2012 Ninja 250R Tech Talk 19 July 26th, 2014 03:59 AM
Left rearset install issues Rugby Winger 2008 - 2012 Ninja 250R Tech Talk 9 July 2nd, 2013 10:25 PM
Vortex Rearset Install Issues. drinkchai 2008 - 2012 Ninja 250R Tech Talk 11 February 7th, 2011 08:25 PM
Shinto rearset install & shifting issue randomwalk101 2008 - 2012 Ninja 250R Tech Talk 5 August 31st, 2010 04:48 PM
Vortex Sprocket! ShelbyOne 2008 - 2012 Ninja 250R Tech Talk 6 July 23rd, 2009 04:03 PM
