Old February 6th, 2017, 03:44 PM   #1
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Valve checks
Just an FYI...
I have close to 9000 miles on the bike, I took it in for a valve check.
My valves did need adjustments, I will have the full report Saturday.
The dealer and I were both surprised it needed done. So, don't forget to check them or put it off.
Old February 6th, 2017, 04:19 PM   #2
pantera
pantera's Avatar
Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300
Surprising as most do not need an adjustment until well beyond that mileage.Keep us updated.
pantera is offline   Reply With Quote
Old February 6th, 2017, 05:45 PM   #3
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Noted! I need time now to do mine. She just passed 14,000 miles so it's time to check 'em.
Old February 7th, 2017, 08:16 AM   #4
Dsheumaker
Dsheumaker's Avatar
Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB
Finally got the cluster wired back up on the race bike build just to see that it has 12k on it... wish i would have known this before i mounted the engine back in the frame haha. Ill be checking mine soon.
Dsheumaker is offline   Reply With Quote
Old February 7th, 2017, 12:25 PM   #5
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
How much did it run you back at the dealer?
Floki is offline   Reply With Quote
Old February 8th, 2017, 02:13 PM   #6
snot
sammich maker
snot's Avatar
MOTM - Apr '15
$200.00 for the dealer to do it.
My bike is still under warranty, so I spend the extra to let them do the work. The guy working on it was the one who put it together out of the crate....
I did have them install the brake lines for an extra $$ while it was there. I get her back Saturday, so I will keep you all posted.
Old February 8th, 2017, 08:24 PM   #7
Wow, that's cheap for a dealer. What dealership are you using?
Cyclewerks in Lima is highway robbery. $150 labor just to change tires. Bastards.
Old February 9th, 2017, 08:20 AM   #8
Floki
Motorcycle Nurse?
Floki's Avatar
It was $400 at my dealer, but the closest shop to me wanted $1,200 because of the "difficulty of taking the cans out and timing it"
Old February 9th, 2017, 03:37 PM   #9
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Rehmerts in Versailles
Old February 11th, 2017, 11:24 AM   #10
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Both cylinders were adjusted. the largest difference was .4.
The cylinder was checked at .7 and adjusted to .11 (intake).
The smallest was .9 and adjusted to .11 (intake).
300 air switching valve and purge valve (CAL) removal joyspring 2013 - 2017 Ninja 300 Tech Talk 21 February 13th, 2017 01:36 PM
Fixed valve cover bolt leak & valve clearances Linkin Videos 3 June 24th, 2015 03:49 PM
Valve checks for track bikes? MirinNinja Ninjettes At Speed 15 February 5th, 2015 05:40 PM
Dropped bike off for valve adj. v. New valve stems? edxmon 2008 - 2012 Ninja 250R Tech Talk 14 July 17th, 2012 04:55 PM
Border Patrol Checks backinthesaddleagain Off-Topic 15 September 21st, 2010 12:48 PM
