Old November 7th, 2009, 03:41 PM   #1
.KiT
Engine Kill Switch won't kill
So my red engine kill switch isn't working. I have to use the key or put down the stand to kill the engine. I bought a replacement switch since putting a cont. test on the switch showed both ways the two wires (red and red/yellow) were shorting. The new switch responded the same way. What could be the problem? Thanks!
-KiT
.KiT is offline   Reply With Quote
Old November 7th, 2009, 03:48 PM   #2
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
welcome Kris! Have you traced the wires to be sure there aren't any visible cuts, etc?
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old November 7th, 2009, 04:05 PM   #3
.KiT
No, but when I put continuity on the switch leads while connected it was always a closed circuit. I'm wondering how a visible cut would cause that, unless it was a... cut that would short the two wires to each other?? The service manual mentions replacing the IC Igniter??
Second Step
•Turn on the ignition switch.
•Set the neutral position.
•Turn the engine stop switch to run position [A].
•Push the starter button and run the engine.
•Turn the engine stop switch to stop position.
•Immediately the engine should be stop.
If the engine does not stop, inspect or replace the following
item.
Engine Stop Switch (see Switch Inspection in the Electrical
System chapter)
If the engine stop switch is good condition, replace the IC
Igniter.
I will go out there and trace it now. Thanks for the response!
Old November 7th, 2009, 07:10 PM   #4
HKr1
IC2(SW)
HKr1's Avatar
Replace the cdi....... Thats interesting. I thought the kill switch cut the 12v to the coils. Looks like it in the schematic anyway
Old November 8th, 2009, 05:50 AM   #5
.KiT
Excuse my stupidity.. but does the CDI = IC Ignitor? If not what exactly is a CDI?
Old November 8th, 2009, 07:40 AM   #6
bob706
bob706's Avatar
CDI = Capacator Discharge Ignition
IC Ignitor = Ignition Coil Ignitor
Old November 8th, 2009, 08:28 AM   #7
ninjabrewer
dirty old man
ninjabrewer's Avatar
Motorcycle(s): Blue '08 Ninja 250
Check the wiring that leads from the kill switch to wherever it goes. You may have to take off the fairings to get to them. Visually look at them and look for cracks or breaks in the insulation on the outside of the wire. I have seen places where wires were rubbing against each other rubbed bare and making contact.
nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894)
www.friendsofsanonofre.org
ninjabrewer is offline   Reply With Quote
Old November 8th, 2009, 10:36 AM   #8
Out of curiosity, what year is the bike? I'm wondering why Kawi says to use the key and not the switch, contrary to the MSF guidelines.
Old November 8th, 2009, 12:04 PM   #9
.KiT
2008 with 250 miles, pristine condition. I bought it used but never checked that switch when I bought it since I use the key.
Old November 8th, 2009, 12:30 PM   #10
HKr1
IC2(SW)
HKr1's Avatar
same thing.
Old November 8th, 2009, 07:21 PM   #11
Thanks. With only 250 miles, I think it's safe to say that it wasn't worn to that point.
Anyway, next time, remember that you have to disconnect the switch to test it's continuity. The short is obviously on the other side of the wiring.
Old November 9th, 2009, 03:12 PM   #12
.KiT
So do I replace the CDI or the IC Ignitor? Oh wait it is the same thing. Is this a common problem on this bike? I just read about a potential recall and everyone is saying CDI. This bike has 250miles on it. Really shouldn't have a part failure already?
Old November 9th, 2009, 04:51 PM   #13
noche_caliente
is it by chance still under warranty if it only has 250 miles? maybe the dealer can figure it out?
Old November 9th, 2009, 05:09 PM   #14
HKr1
IC2(SW)
HKr1's Avatar
I dont see why they say to replace the CDI. The CDI just grounds the coils to make a spark, the kill switch is supplying the +12 to the coils(via main sw). Seems like you would have to trouble shoot why the +12 is not being cut by the switch.
Old November 10th, 2009, 08:40 PM   #15
.KiT
Here I go... got her tore down and looking over the wires. Just as clean under the seat as everywhere else. Going to follow that schematic back now. Good time to install my tender leads. Quick question on that, does the ground go directly to the battery as well?
Thanks again for the replies
-KiT
Old November 10th, 2009, 08:43 PM   #16
that's where I connected mine and it works fine.
Old November 10th, 2009, 09:13 PM   #17
.KiT
Alright I give up tracing wires for now. Everything seems fine. I am going to read service manual on how to VOM test the CDI if it is even possible.
I am going to install the tender lead. I am bringing it up under the back seat and making a cigarette lighter plug that adapts to the battery side of the tender connection. Mounting it under back seat and it will leave enough space in that storage to stick a cell phone. I'm guessing this has been done before? I will take pics if it hasn't.
Old November 11th, 2009, 08:04 AM   #18
g21-30
g21-30's Avatar
Kris, I created the following just for your benefit:
http://www.ninjette.org/forums/showt...776#post120776
Maybe it will help you! Let me know if it does.
Old November 11th, 2009, 09:49 AM   #19
HKr1
IC2(SW)
HKr1's Avatar
-KiT
That is odd, seems like OFF would be open. Personally I would unplug the kill switch, key -on, see if theres +12 at the coils. If there is, you need to check the harness(br/bk & r). < can even check at the harness conector.
If theres no +12 at coils, it has to be the switch.
Old November 11th, 2009, 09:49 AM   #20
g21-30
g21-30's Avatar
As Kerry (HKr1) stated, the function of the engine stop switch is to "OPEN" the circuit, thus cutting off the 12V supply to the coils. You said that you have already replaced the switch once, so why not disconnect the switch from the circuit? If the engine starts, then the problem is either in the wiring (not the engine stop switch wiring) or the CDI.
Old November 11th, 2009, 11:36 AM   #21
randomwalk101
self wrencher
randomwalk101's Avatar
may be it's a faulty switch
Old November 11th, 2009, 12:12 PM   #22
g21-30
g21-30's Avatar
Yep, but he already replaced it once, but the new one could be bad; however, not likely.
Old November 11th, 2009, 12:12 PM   #23
HKr1
IC2(SW)
HKr1's Avatar
He mentioned buying a new one???
The kill switch supplies +12 to the starter switch too. < So with the kill switch off, the starter button should not work.
Old November 11th, 2009, 12:42 PM   #24
g21-30
g21-30's Avatar
It's also possible that the 6 way connector (blue ellipse in pic) has the BR/BK and R pins shorted together...similiar to what Kerry said about the harness.
Old November 11th, 2009, 02:32 PM   #25
.KiT
Yeah I really should've unplugged the switch and tested it. But here is what I did with it plugged up. I put a cont. test on the old switch, beeped both on and off.
Installed new switch. Does same thing. I will disconnect harness and put a cont. test on the leads.
I can try to take switch out completely like suggested. While out I can test switch outside while disconnected.
Oh I did dissect old switch but when I dissected it the little spring went flying and I lost it. BUT by just rocking it while it is back together without the spring it opens and closes properly on cont. test.
I got some great ideas to go try now... thanks for all the replies.
Old November 11th, 2009, 02:33 PM   #26
.KiT
I will get to this harness first before anything else with the CDI.
Old November 11th, 2009, 02:42 PM   #27
HKr1
IC2(SW)
HKr1's Avatar
Where does it say if the kill switch doesnt work to replace cdi. ?? Book & pg #
Old November 11th, 2009, 02:44 PM   #28
g21-30
g21-30's Avatar
Checking continuity without removing the switch from the circuit is never recommended. It will give you false readings, i.e take other unexpected paths. I would really like to know if the bike starts up with the switch unplugged from the circuit.
Good Luck!
Old November 11th, 2009, 03:36 PM   #29
.KiT
Good Luck!
the connector is in excellent condition. I phsyically inspected it and everything looks good.
I unplugged it and put continuity on it and it worked flawlessly. on off, beep no beep respectively.
I plugged it up and tested cont. behind the switch and it is always closed. onto the CDI??
Old November 11th, 2009, 03:43 PM   #30
.KiT
page 2-41 of the 08- service manual
Old November 11th, 2009, 03:57 PM   #31
HKr1
IC2(SW)
HKr1's Avatar
So I take it, it does "not" start(turn over) in the off postion?
For the life of me, I dont under stand the Replace IC ignitor (pg2-41)....
Kawi should know best
Old November 11th, 2009, 04:05 PM   #32
.KiT
Starts perfect runs everything in off. Basically the switch is for looks on my bike. Luckily it is locked on and not off.
Old November 11th, 2009, 04:15 PM   #33
g21-30
g21-30's Avatar
Did you physically unplug the switch from the circuit and try to start the bike?
Old November 11th, 2009, 05:03 PM   #34
.KiT
LOL, no I have not tried physically unplugging and start, I will go do that now.
I had the switch in the off position after verifying that when the switch is in the off the meter shows open circuit.
Old November 11th, 2009, 05:09 PM   #35
.KiT
Will NOT start with the switch disconnected.
Old November 11th, 2009, 05:16 PM   #36
HKr1
IC2(SW)
HKr1's Avatar
Has to be the switch.
Whats locked on?
Old November 11th, 2009, 05:19 PM   #37
.KiT
Whats locked on?
The switch is perfect. It is the second one too.
not locked on just means the switch, on position instead of off. Meaning always closed even though it rocks fine. at least I can still ride.
I put the meter on the switch harness with it disconnected. SWITCH ON = CLOSED CIRCUIT BEEP SWITCH OFF = NO BEEP
How can you be sure it is the switch with a test condition like this?
Old November 11th, 2009, 05:39 PM   #38
.KiT
OK so correct me if I am wrong but if the switch works when disconnected from the harness (tests closed and open with a meter) and the rest of the harness that the switch goes in controls the start switch, and a short of the r wire then there is no way to start the bike with that harness disconnected because there is an open circuit, but with the harness hooked up the plug basically overrides with whatever is on the other end of the plug making the stop switch not work... therefore ruling out the fact that it is the switch. I could unsolder the switch from the handle that way the starter still works but I don't really want to do that
According to the attachment that plug does more than just control the kill switch.
Old November 11th, 2009, 05:45 PM   #39
g21-30
g21-30's Avatar
I just checked my bike. The switch connector is a 6 way, so the only way to disconnect the kill switch alone would be to use your old switch. You could cut the 2 wires leading to the kill switch on the old connector and hook it up to the bike. If the bike starts, it definitely is NOT the kill switch.
Old November 11th, 2009, 05:57 PM   #40
HKr1
IC2(SW)
HKr1's Avatar
With the key on, the kill sw disconnected. Is there 12 volts on the Red wire @ harness ??
If there is, could be what Kawi says... the cdi. Cdi should only be grounding the coils. If there something wrong with the cdi, perhaps the 12v is going back thru the coils via cdi. ????
Kickstand Kill switch - Inert omarcarbomb 1986 - 2007 Ninja 250R Tech Talk 10 March 13th, 2015 12:45 PM
Frozen Kickstand Kill Switch? Brother Michigan 2013 - 2017 Ninja 300 Tech Talk 8 January 9th, 2014 12:59 PM
Wiring Kill switch after MP throttle, anyone? JBinSD 2013 - 2017 Ninja 300 Tech Talk 13 September 2nd, 2013 03:57 PM
Kill Switch Countersteer General Motorcycling Discussion 6 May 6th, 2012 12:55 AM
hidden kill switch? petiteninja 2008 - 2012 Ninja 250R Tech Talk 4 May 26th, 2010 04:09 PM
