Old November 11th, 2009, 06:13 PM   #41
g21-30
g21-30's Avatar
If it is the CDI, he can do the continuity/resistance checks illustrated in my other thread on CDI troubleshooting. He may have just discovered another potential problem with the '08+ CDIs.
Old November 11th, 2009, 06:34 PM   #42
.KiT
ok putting my VOM on 2000 OHM setting and touching each of the pins according to the pin out diagram you provided the following is what I got:
.KiT is offline   Reply With Quote
Old November 11th, 2009, 06:36 PM   #43
Huh. If so, could this be what the recall is for? After all, it's safety-related considering that it's an EMERGENCY cut-off switch.
Old November 11th, 2009, 06:37 PM   #44
.KiT
these might not mean much since i had the vom on 2000 OHM setting
Old November 11th, 2009, 09:04 PM   #45
HKr1
IC2(SW)
HKr1's Avatar
If you think its the cdi, just disconnect the Neg lead on both coils. Will it still try and turn over via the starter button in the off postion?
Old November 14th, 2009, 08:50 PM   #46
.KiT
I got a replacement CDI and swapped it out tonight. Still same effect. Kill switch does NOT work still. I give up... use the key to cut the engine.
Old November 14th, 2009, 09:00 PM   #47
that tells you it's not a CDI problem.
did you check for continuity on the br/blk wiring harness wire from the switch to the CDI?
while you should be using the key to kill the motor, anyway, the killswitch is a safety device to shut off the engine should you ever need to in an emergency. having it functional may come in handy one day.
Old November 14th, 2009, 09:05 PM   #48
.KiT
Im open to any testing. I will try that next. Yes I was kidding, I know I need that switch to work.
Thanks for the suggestion i will test that cont. next.
Old November 15th, 2009, 10:27 AM   #49
HKr1
IC2(SW)
HKr1's Avatar
It gonna be the Red wire, thats the one that should have No +12 with the switch off.
Red supplies +12 to the starter switch & coils, when the kill switch is On..
Old November 15th, 2009, 10:30 AM   #50
g21-30
g21-30's Avatar
Just an FYI, your CDI resistance numbers that you measured are the same as my '09 CDI, at least for the pins that you checked.
Old November 15th, 2009, 10:49 AM   #51
disconnect the connector leading to the kill switch. jumper it on the harness side of that connector and see if the bike starts. if it does start, the switch is the problem.
Old November 15th, 2009, 11:18 AM   #52
.KiT
I will short out the connection KKIM, but this is a new switch that tests fine when disconnected from the harness.
Old November 15th, 2009, 11:26 AM   #53
g21-30
g21-30's Avatar
It's also a 6 wire connector. That's why I suggested earlier to use the old switch and cut the 2 kill switch wires and plug the connector into the harness. If the bike doesn't start, the switch is the problem.
Old November 15th, 2009, 11:43 AM   #54
sorry, wasn't aware of that.
Kickstand Kill switch - Inert omarcarbomb 1986 - 2007 Ninja 250R Tech Talk 10 March 13th, 2015 12:45 PM
Frozen Kickstand Kill Switch? Brother Michigan 2013 - 2017 Ninja 300 Tech Talk 8 January 9th, 2014 12:59 PM
Wiring Kill switch after MP throttle, anyone? JBinSD 2013 - 2017 Ninja 300 Tech Talk 13 September 2nd, 2013 03:57 PM
Kill Switch Countersteer General Motorcycling Discussion 6 May 6th, 2012 12:55 AM
hidden kill switch? petiteninja 2008 - 2012 Ninja 250R Tech Talk 4 May 26th, 2010 04:09 PM
