Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 Tech Talk
Old May 23rd, 2021, 08:34 AM   #1
Whitedogpoo
Motorcycle(s): Ninja 400 / CBR600
Time for an oil change?
I've got a 2019 N400 which had it's first service (including oil/filter change) in May 2020 with around 300 miles on the clock. I bought it in April this year with around 350 miles on the clock and the dealer did another service (including oil/filter change) before I picked it up. So, should I still be looking at doing a 600 mile oil/filter change? It's out of warranty, so won't be compromising any warranty if I delay a change. What would you do?
Whitedogpoo is offline   Reply With Quote
Old May 23rd, 2021, 09:00 AM   #2
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
If it's already had two oil changes, you shouldn't need to do it again at 600mi.
Originally Posted by https://www.calsci.com/motorcycleinfo/Oils1.html
I recommend you change your break-in oil at 75 to 100 miles, 100 to 150 kilometers. Your engine does shed a fair amount of metal particles in the first 20-50 miles, and I really can't understand why you would want this stuff floating around your bearings for the first 600 miles, 1000 kilometers.
By doing the early oil change(s), the engine is probably a little better off than following the manual's schedule. Even if the dealer didn't actually change the oil when you bought it, you're probably still ok since the first oil change should've gotten rid of the initial break-in crud.
But also keep in mind that oil is the lifeblood of your engine and oil changes are simple. If you ever have any doubts about its condition, changing the oil is cheap, easy insurance vs. severely damaging your engine.
Old June 10th, 2021, 09:42 AM   #3
Whitedogpoo
Oil and filter were defo new when I got it. Just wondering how much break-in crud would still accumulate after the initial 350miles. Think I'll leave it a bit before changing again as, as you say, first oil change would've cleared out the initial stuff. Cheers
Old June 10th, 2021, 05:43 PM   #4
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
The most important thing is never letting an engine get to too low on oil or coolant. Overheating kills!
[motorcycle.com] - Oil’s Well: How Many Miles Before I Have To Change the Oil In My M Ninjette Newsbot Motorcycling News 0 January 30th, 2017 10:00 AM
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
First time oil change woofer987 2008 - 2012 Ninja 250R Tech Talk 18 February 4th, 2013 09:25 AM
Oil drain plug gasket for oil change. tsdexter 2008 - 2012 Ninja 250R Tech Talk 8 July 10th, 2012 01:00 PM
