Old March 25th, 2010, 12:38 PM   #1
00v_Lucky
00v_Lucky's Avatar
Motorcycle(s): '09 Candy Thunder Blue Ninja 250R
In the market for Sprocket/Chains
I was searching through the boards, and I am not seeing a thread on where/what people purchase when it comes to chains and sprockets. I know there is a lengthy discussion on what types of combinations are good but not really on brands of chains and sprockets.
I personally am wanting to change to a 15/44 change from the stock 14/45 (I believe that is the right size), since now I am going to LMU/LAX area every Friday from the OC riding the freeway most of the time.
I also am racking up to over 8000k on my chain (but constantly cleaned/lubed) and would like to change it out with the sprockets too.
Ty for any helps guys!
00v_Lucky is offline   Reply With Quote
Old March 25th, 2010, 04:20 PM   #2
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
Stealth on the sprockets.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old March 27th, 2010, 01:38 PM   #3
Ramen
Frak It
Ramen's Avatar
Just swapped my sprocket out today! Bought a JT Front Steel Sprocket from Bikebandit.com here:
http://www.bikebandit.com/jt-front-s...=2072&t=1&td=1
Took it for a test ride afterwards (changed the oil and tire at the same time) and it's definitely an improvement. On paper, acceleration is slightly less, but not having to shift constantly actually more than makes up for it, imho.
Don't forget a breaker bar with a cheater bar. I bought a socket set from Harbor Freight that included one. Also, I used a 3' black glavanized pipe from Lowes. Only ~$10.
Coupons for Harbor Freight are online with a little Googling.
Ramen is offline   Reply With Quote
Old March 27th, 2010, 01:49 PM   #4
00v_Lucky
00v_Lucky's Avatar
Thanks for the info! that looks like a pretty good price.
Did you only change out only the front sprocket? and was it the 15?
Old March 27th, 2010, 01:58 PM   #5
Ramen
Frak It
Ramen's Avatar
Yep, just the front sprocket, and it was 15T. Some folks on here have changed the rear sprocket all the way down to 41T. I kept my rear sprocket stock as I do most of my riding/commuting in town.
Old March 27th, 2010, 02:25 PM   #6
00v_Lucky
00v_Lucky's Avatar
when will I have to also change out the chain? how far will the OEM chain count be compatible? because since I am mostly on the freeway, (with cars usually going around 80) i'd like to lower the rpms just a tad from 10k
Old March 28th, 2010, 07:06 PM   #7
Momaru
Momaru's Avatar
My front 15T is a JT steel sprocket as well & seems to be holding up very well with the original OEM chain after ~11,000mi. Not sure how far down the stock chain will go with rear tooth count, but suspect it's pretty far.
RE: replacing the stock chain, that'll depend on how worn the sprockets/chain are. The common wisdom I've been told is to replace all three at once so you don't have an old/messed up chain eating your new sprocket(s) or vice versa. But if the chain's still in good condition and has a lot of life left, don't see why you'd have to replace it unless you wanted to be really really sure they all wore together
Proud member of the Blue Army
Old November 6th, 2010, 10:53 AM   #8
Bleak21
Bleak21's Avatar
Motorcycle(s): 05 Ninjette
Hey all sorry to revive an old thread but...
I am also in the market for new sprockets (15/43) and chain but can't find/don't know where the best place is to get it from.
Does anyone have any suggestions as to the best place with the best price? I know there are cheaper aftermarket chains but I'd like to buy close to OEM. I only saw one suggestion above.
Thanks
(note- I have a pregen, but it shouldnt matter if the site carries all years)
Bleak21 is offline   Reply With Quote
Racing chains? Diablita Ninjettes At Speed 11 March 6th, 2024 08:49 AM
How long do you go between new chains? agentbad 1986 - 2007 Ninja 250R Tech Talk 13 November 25th, 2014 02:53 PM
All about chains Sirref 2013 - 2017 Ninja 300 Tech Talk 27 September 1st, 2014 10:33 AM
Chains? quadcrazy 2013 - 2017 Ninja 300 Tech Talk 2 January 22nd, 2014 06:03 PM
JT Sprocket 42 tooth Rear Sprocket lolibater Motorcycle-related 36 February 25th, 2013 12:30 PM
