Old February 8th, 2024, 12:23 PM   #1
[ridermagazine.com] - 2024 Triumph Speed 400 and Scrambler 400 X Review | First Ride*
Prospective Triumph motorcycle owners need no longer pay their dues by wrestling large-displacement bikes until they build their riding skills. Instead, they can save their skin and wallets by honing their skills on Triumph’s new entry-level machines. Powered by 398cc Singles and with claimed wet weights below 400 lb, the new Triumph Speed 400 and […]
The post 2024 Triumph Speed 400 and Scrambler 400 X Review | First Ride* appeared first on Rider Magazine.
The 2024 Triumph Speed 400 features a new 398cc Single, a wet weight of 375 lb, and an MSRP of $4,995, making it a smart and attainable choice for newer riders.
Prospective Triumph motorcycle owners need no longer pay their dues by wrestling large-displacement bikes until they build their riding skills. Instead, they can save their skin and wallets by honing their skills on Triumph’s new entry-level machines. Powered by 398cc Singles and with claimed wet weights below 400 lb, the new Triumph Speed 400 and Scrambler 400 X are the smallest and least expensive Triumphs we’ve seen in decades, paving the way for newer riders looking for an affordable and manageable first or second bike.
The Scrambler features a larger 19-inch front wheel and longer suspension travel than the Speed.
While these two Modern Classics share engines, they have different chassis and ergonomics and offer different riding experiences, giving riders two options to choose the bike that best fits their needs. The Speed 400 follows in the footsteps of the Speed Twin 900 and 1200 with a roadster aesthetic, while the Scrambler offers the potential for light off-roading with longer suspension, off-road-capable tires, a wider and taller handlebar, and other extras.
Newer riders will enjoy the Triumph Speed 400’s easy nature, upright riding position, and nimble handling.
When crafting small-displacement machines meant to draw in new riders, Triumph accessed what new riders value most. Beginner-friendly models need to draw the eye with an attractive attitude, they need to feel forgiving and easy to ride, and they need to have a pricetag that isn’t out of reach for the target customer. Triumph has struck this balance, offering the Speed 400 for $4,495 and the Scrambler 400 X for $5,595.
Related: 2024 Triumph Scrambler 1200 X/XE Review | First Ride
The engine powering both models is the new TR-Series liquid-cooled 398cc Single with a 4-valve DOHC cylinder head. Triumph claims 39.5 hp at 8,000 rpm and 27.7 lb-ft of torque at 6,500 rpm. Other similarities between the Speed 400 and Scrambler 400 X are the swingarm, switchgear, display, and 3.4-gallon fuel tank.
All new for these two models, the 398cc Single proved to be a capable engine for a fun ride through Spanish mountains.
The differences between the two models begin in the chassis. They both have a tubular-steel frame with a bolt-on rear subframe, but the Scrambler 400 X features a longer wheelbase of 55.8 inches (compared to the Speed’s 54.2 inches) thanks to a different headstock. Both feature a 43mm inverted fork and a preload-adjustable monoshock, but the 400 X has longer suspension travel, with 5.9 inches front and rear compared to the Speed’s 5.5 inches front and 5.1 inches in the rear.
The Speed 400 strikes the balance of being inviting and forgiving while also being fun and engaging.
The Speed gets 17-inch wheels while the Scrambler has a 19-inch front and a 17-inch rear. The Scrambler’s front brake disc is larger than the Speed’s at 320mm compared to 300mm, both pinched by a 4-piston caliper. Both bikes get a 230mm rear disc paired with a 1-piston caliper.
The seat of the Scrambler 400 X is comfortable and provides plenty of space to move around.
These differences between the Speed 400 and Scrambler 400 X are noticeable as soon as you swing a leg over them. The Speed 400’s 31.1-inch seat height is an easier reach for those of us with short inseams, and it also features an upright and comfortable riding position but allows the rider to more easily tuck into a sporty position when the speed picks up.
Related: Best Motorcycles for Smaller Riders: Seat Height 31-31.9 Inches
In contrast, the Scrambler uses a wider and taller handlebar, a taller seat height (32.9 inches), and lower pegs, resulting in an overall roomier feel. The Speed 400 has a claimed wet weight of 375 lb, while the Scrambler 400 X has a wet weight of 395 lb.
Upswept twin pipes add to the Scrambler’s off-road-ready styling.
To get a taste for how the Speed 400 and Scrambler 400 X perform, and to be able to compare them back-to-back, we hopped on a flight to Spain to attend Triumph’s press launch. During the riding day, we swapped between the bikes as we rode through city traffic and up into the mountains north of Valencia, even tackling a short gravel section.
With short gearing and easy maneuverability, the Speed 400 would make a convenient bike for around-town errands.
GEAR UP
I started on the Speed 400, drawn to its shorter seat height and more classic appearance. As we rolled down Valencia’s streets, I found the Speed 400 to be an adept city bike. Short gearing allows for reasonably quick acceleration, and the brakes were capable of shedding speed quickly when approaching a stop. The Speed is also quite nimble, aiding in low-speed maneuverability.
We then headed north into the mountains. The 398cc Single ran like a champ, eating up miles of curvy roads. Power was available for a spirited ride, but the delivery was smooth and even, perhaps making things a little less thrilling for veteran journalists but allowing for a controllable ride for newer riders. The Speed 400 was easy to flick into curves, and tucking down delivered a more engaging experience.
The Triumph Speed 400 was our pick for curvy sections of road.
After a quick stop for a cup of café con leche, we were ready to continue farther into the mountains. The Speed 400’s suspension was pleasantly plush for soaking up any inconsistencies in the road, although it allowed the front end to dive when braking at speed. If a curve turned out to be tighter than expected, smooth and even braking was called for to slow the bike without pitching too far into the curve. Past 75 mph or so, the engine gets a little buzzy, but the power is still there, and we didn’t reach max speed during the ride. The engine’s sweet spot is around 4,000-7,000 rpm, and the exhaust has a pleasing note.
Before we knew it, our stomachs were signaling lunch, and we parked the bikes in front of a family-owned restaurant in a small hillside town. We enjoyed some paella, had another cup of coffee, and then headed out on the Scrambler 400 X.
2024 Triumph Scrambler 400 X in Matte Khaki Green and Fusion White.
The first thing I noticed while mounting the Scrambler was that the 32.9-inch seat height was quite a stretch for my 5-foot-1 height. Newer riders who are closer to my size will struggle with this taller seat height, but it seemed to be quite manageable for the other journalists who were a few inches taller than I am. The Scrambler 400 X offers a roomier cockpit with its taller and wider handlebar and lower footpegs. Even though I had a long stretch to the ground, I found the seating position of the Scrambler more comfortable for all-day riding than its Speed sibling.
The seat height on the Scrambler was a stretch for my inseam, but the seating position is more comfortable than the Speed’s thanks to the taller and wider handlebar and lower footpegs.
The engine hasn’t been changed for use in either model, although the X has slightly taller gearing. While the Speed encourages spirited riding, the Scrambler prioritizes comfort. The Scrambler’s larger front wheel meant it didn’t lean into curves quite as gracefully as the Speed, but the wider handlebar helped provide the needed leverage to keep pace with the riders aboard Speeds.
The Scrambler 400 X is a capable machine for light off-road use.
Both models feature ABS and switchable traction control, and the Scrambler adds an off-road mode and the ability to disable ABS. We only got a brief off-road experience with the Scrambler, but it proved capable of being up for some light off-roading. It wouldn’t be our first pick to tackle serious trails, but Scrambler owners need not worry about taking a dirt or gravel shortcut should the need arise.
The headlight grille and handguards come standard on the Scrambler and are available as accessories for the Speed.
Aside from the off-road riding mode, the Scrambler 400 X offers a few other upgrades not present on the Speed 400. Adding to the bike’s scrambler styling and capabilities are protection for the headlight and radiator, handguards, a handlebar brace with pad, and a longer rear fender, all of which provide a little more peace-of-mind for those looking to venture off the pavement.
The Scrambler 400 X enjoys a curvy section of asphalt.
Instrumentation is the same on both models and consists of a round analog speedometer with an integrated LCD screen that shows a tachometer, fuel level, and a gear indicator. On the right side of the instrumentation is a USB-C charging port, a convenient feature if you like to ride with your phone mounted on the handlebar. The display is also set up to show heated grip info for those who add that accessory. The instrumentation is simple yet intuitive.
Instrumentation comes in the form of a round analog speedometer with an inset LCD screen. On the right side of the LCD screen is a USB-C charging port.
Triumph has a reputation for quality and sophistication, so seeing models that are priced several thousand dollars below any other on-road model in the Triumph lineup led us to wonder if the lower price would reveal itself in lower quality components or poorer fit and finish. We’re happy to report that these two models look and feel like quality products that we’d expect from Triumph.
The Scrambler 400 X includes a handlebar brace with pad.
They were created in a partnership with Bajaj Auto in India, and Triumph told us that the bikes are selling well in India for those who want something more premium than the 125-150cc bikes often seen on Indian streets. The bikes are manufactured by Bajaj, as well as in Triumph factories in Thailand and Brazil.
It’s hard not to become dismayed when prices seem to be increasing everywhere you look, and motorcycles are no exception. Many bikes are becoming bigger with more technology and more features, which is exciting for customers with deep pockets, but they are receding farther out of reach for many buyers, especially younger riders.
2024 Speed 400 in Carnival Red
On U.S. shores, these models will arrive in dealerships in early March. The Speed 400 has an MSRP of $4,995, and the Scrambler 400 X is priced at $5,595. Color options for the Speed 400 are Phantom Black, Carnival Red, or Caspian Blue. Colors for the Scrambler 400 X are Phantom Black and Silver Ice, Carnival Red and Phantom Black, or Matte Khaki Green and Fusion White.
It’s refreshing to see Triumph providing more accessible options that are affordable and inviting while still delivering the quality and riding experience of a premium brand. We’ll see how they catch on in the U.S. once they start arriving at dealers, but we expect them to draw serious attention and bring in a new customer base for Triumph.
The 2024 Triumph Speed 400 in Carnival Red and 2024 Triumph Scrambler 400 X in Matte Khaki Green and Fusion White
Check out more new bikes in Rider’s 2024 Motorcycle Buyers Guide
Triumph Speed 400 (Scrambler 400 X) Specifications
  • Base Price: $4,995 ($5,595)
  • Website: TriumphMotorcycles.com
  • Warranty: 2 yrs., unltd. miles
  • Engine Type: liquid-cooled Single, DOHC w/ 4 valves
  • Displacement: 398cc
  • Bore x Stroke: 89 x 64mm
  • Horsepower: 39.5 hp @ 8,000 rpm (factory claim)
  • Torque: 27.7 lb-ft @ 6,500 rpm (factory claim)
  • Transmission: 6-speed, cable-actuated slip/assist wet clutch
  • Final Drive: Chain
  • Wheelbase: 54.2 in. (55.8 in.)
  • Rake/Trail: 24.6 degrees/4.0 in. (23.2 degrees/4.3 in.)
  • Seat Height: 31.1 in. (32.9 in.)
  • Wet Weight: 375 lb (395 lb)
  • Fuel Capacity: 3.4 gal.
[ridermagazine.com] - 2024 Triumph Scrambler 1200 X/XE Review | First Ride Ninjette Newsbot Motorcycling News 0 January 19th, 2024 04:51 PM
[motorcyclistonline] - 2024 Triumph Speed 400 and Scrambler 400 X Preview Ninjette Newsbot Motorcycling News 0 November 14th, 2023 04:12 AM
[webbikeworld.com] - Pricing Revealed for Triumph Speed 400 / Scrambler 400 X Ninjette Newsbot Motorcycling News 0 October 6th, 2023 04:12 PM
[RideApart] - Triumph India Opens Pre-Bookings For New Speed 400 And Scrambler 400 X Ninjette Newsbot Motorcycling News 0 June 29th, 2023 06:36 AM
[ridermagazine.com] - 2024 Triumph Speed 400 and Scrambler 400 X | First Look Review Ninjette Newsbot Motorcycling News 0 June 27th, 2023 11:14 AM
