Old June 18th, 2010, 11:39 PM   #1
00v_Lucky
00v_Lucky's Avatar
Motorcycle(s): '09 Candy Thunder Blue Ninja 250R
Exclamation Won't start after valve adjustment
Just need some ideas from ninjette as to what the problem may be on my bike. Has anyone gotten into trouble after doing their valve adjustments that they looked over?
What I mean by the bike "Not starting" is that the starting motor is not kicking over and there is also a click when hitting the ignition with no noise until I let go of the ignition and then, nothing.
*also in case this may have affected anything, I did also take out the CA kleen air system but the vacuum and gas hoses are in place. & I also put in a little longer bolt for the camshaft chain tensioner (too tight?) does the bolt actually hold the tension or just the clockwise spin of it?
What I have tried so far:
1. all wires I have double checked and are correctly in place
2. all fuses in good condition
3. turned the engine over again after everything was assembled (almost sounded like it was going to turn on
4. battery has full charge
edit:
Tried turning it on again but it sounds like something is grinding?
the starter motor may be blocked by something to not turn the engine over? (but what could it be?)
HELP!
Thanks in advance!
00v_Lucky is offline   Reply With Quote
Old June 19th, 2010, 07:59 AM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
Sometimes one needs a little " luck" u know j/k
sorry I haven't done valve yet so no idea?
If you had everything back together correctly, I'm thnking your timing is off.
Posted via Mobile Device
Old June 19th, 2010, 09:35 AM   #3
00v_Lucky
00v_Lucky's Avatar
That first remark made me chuckle a little bit :ashamed01:
And yes, I will probably have to check my timing again although before I put the valve cover on I made sure by my markings that the sprocket was exactly aligned with the chain from how it was in the beginning.
Does it matter to turn the engine exactly where the first cylinder is at the highest point or anything like that?
Valve adjustment and now bike won't stay idle har0ld 2008 - 2012 Ninja 250R Tech Talk 13 December 16th, 2012 06:16 PM
Valve adjustment ?s Jewtoys 2008 - 2012 Ninja 250R Tech Talk 5 August 1st, 2012 08:47 PM
Valve Adjustment to Come Soon! gilmorec61 2008 - 2012 Ninja 250R Tech Talk 54 June 22nd, 2012 03:43 PM
Valve Adjustment Engine Won't Turn Over. ukie 1986 - 2007 Ninja 250R Tech Talk 86 February 15th, 2012 05:23 AM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
