Old September 17th, 2010, 08:45 AM   #1
JCCJMM_
JCCJMM_'s Avatar
Motorcycle(s): 2007 EX250
Operating temp. question
I know it's been a while since I have been on here......working 2 jobs and doing ALOT of riding to get there.
I posted this question on ninja250.org and got mixed feedback.
So, here goes: 2007 with just over 12,000 miles. I do all maintenance; valves last adjusted around 6,000 miles (I know its time again) to the polar "loose end" of the spectrum. Carbs never pulled/cleaned, but have run some B12 in the gas recently. Carbs synced once, at around 1000 miles. Bike has not sat for more than 3 days without being ridden since last December.
Issue: Here over the last month or so, the bike wants to stall when coming to a stop at the beginning of the ride. I have tried letting it warm up with the choke.....which helps a bit, but I know better than to let it warm up idling. Once the bike gets up to temp, it runs great at any rpm/speed. Idles fine...no problems when warm.
This morning on the way to my first job, I let it run with choke for about a minute then rode off. At my first stop it died, even with enrichner on. It was difficult to get it restarted and I had to blip the throttle at the first 3 lights I came to. I find it difficult to set the enrichner properly for use until it will idle without it. After about 5 solid minutes of riding, it finally ran/idled fine. No problems with warm starts afterwards either.
What are the possibilities here? It is certainly temperature related.....never hesitates or acts strange after a good 5 min of riding. Motor also sounds normal. Ideas?? Thanks a bunch for any input!
JCCJMM_ is offline   Reply With Quote
Old September 17th, 2010, 08:55 AM   #2
Snake
Snake's Avatar
Do a valve job and see if the problem goes away.
Old September 17th, 2010, 12:02 PM   #3
I agree. If nothing else, you'll be up to date on your service.
I do believe I've read of this problem before on this forum and the solution was a valve adjustment.
Old September 17th, 2010, 12:27 PM   #4
bob706
bob706's Avatar
+1 for valve adjustment. Have you checked the fuel filter?
Old September 29th, 2010, 10:04 AM   #5
JCCJMM_
JCCJMM_'s Avatar
***UPDATE***
Worked on the valves Monday night. 2 exhaust valve clearances (same cylinder) were too tight.
Also, electrodes on plugs were worn. Seemed odd for only 12,000 miles...plugs were clean though.
Adjusted 2 valves, popped in new plugs, changed oil/filter, cleaned air filter and she is riding like new again.
My only question is, was it the valve lash or the plugs that caused the problem???
Thanks again guys.
Old September 29th, 2010, 11:59 AM   #6
what plugs are you using/was in there?
Old September 30th, 2010, 07:39 AM   #7
JCCJMM_
JCCJMM_'s Avatar
Old plugs were factory installed, new ones are same brand/model. In addition to the worn electrodes, the old ones had too wide of a gap too.
On another note, my bike is running better than it ever has! I am beginning to wonder if I mis-adjusted the 2 exhaust valves the last time I worked on them. I just never thought that 2 exhaust valves being a bit too tight would cause the bike to run as poorly as it was.
New here, question about temp gauge Neps 2008 - 2012 Ninja 250R Tech Talk 6 June 30th, 2014 04:39 PM
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
Normal operating temp deanomyte 1986 - 2007 Ninja 250R Tech Talk 10 September 11th, 2013 08:20 AM
What is the normal operating engine temperature? arnoldc6 2008 - 2012 Ninja 250R Tech Talk 16 February 21st, 2013 01:30 AM
oil temp vs coolant temp cuong-nutz General Motorcycling Discussion 11 January 23rd, 2013 05:44 PM
