Old December 12th, 2010, 12:37 PM   #1
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Idle Fluctuation
All of a sudden my bike seems to be having an issue at idle. The idle goes to what it normally is (1500rpm) but every few seconds it jumps up by maybe about 250-400rpm while idling then heads back to normal idle (This is with the bike warmed and even after having a 20 or so mile ride). Do you think maybe the cabs are out of sync or the idle mixture needs to be adjusted? Thanks for the help much appreciated
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old December 12th, 2010, 01:57 PM   #2
has the bike been left sitting unused for a period of time?
Old December 12th, 2010, 02:16 PM   #3
00NissanNinja
I hate driving...
Sort of, I only get to ride it once a week or every two weeks. It seems to be running fine otherwise. Think I should get some seafoam to make up for it being ridden less?
Old December 12th, 2010, 02:31 PM   #4
drain the carb bowls, drain all the fuel in the tank and refill with fresh gas and some seafoam. if you're lucky, you might be able to flush the gunk in your carbs/tank out before they've solidified and save yourself from having to pull the carbs to clean them out from, what sounds to me, partially clogged pilot jets.
Old December 12th, 2010, 02:45 PM   #5
00NissanNinja
I hate driving...
Oh, that sucks lol, These carbs on these bikes good grief...Alright I'll give it a shot thanks kkim. Hopefully I won't have to take them off and clean them.
Old December 19th, 2011, 04:27 PM   #6
cuong-nutz
cuong-nutz's Avatar
Did you ever figure out what caused it? I'm having the same deal. Kind of annoying.
HalfFast Racing Team
Old December 20th, 2011, 01:01 AM   #7
00NissanNinja
I hate driving...
@cuong-nutz I ran some seafoam through it and the idle got a bit better. But randomly sometimes the bike would idle and stabilize at a higher idle than normal. I just finished re jetting my bike and my idle is very stable now. While I was jetting I also found out that one of the idle mixture screws was turned out very little while the other was turned noticeably farther out (about 1.5 turns). That probably caused the issues I had as well. Syncing the carbs also wouldn't be a bad idea. Overall i think the issues were what kkim stated and the uneven idle mixture screws. I also checked the butteryfly operation on the carbs and they moved in sync (which somewhat verifies the carbs are in sync). Otherwise after jetting my bike its been the smoothest idling since I bought it.
Last futzed with by 00NissanNinja; December 20th, 2011 at 01:23 PM.
Old December 20th, 2011, 06:38 AM   #8
coondog
coondog's Avatar
Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125
I have an 05 so maybe things are different, but 1500 is too high of an idle. Once you've gone your 20 miles and bike is good and heated up, adjust to 1300 and try that. No work involved and may be problem or part of problem at this point. Be thankful at worst it's a carb clean. Luck!
coondog is offline   Reply With Quote
Old December 20th, 2011, 01:27 PM   #9
00NissanNinja
I hate driving...
1500 is where my bike works its best and is where quite a few people I have talked to have theirs idling at. My bike is fine now, I mean this was like a year a ago haha. It was still moody over the year, but fine the majority of the time. It idles very smooth now that I rejetted, messed with the idle mixture screws, and checked the carb sync.
Old December 20th, 2011, 02:30 PM   #10
cuong-nutz
cuong-nutz's Avatar
I'll give seafoam a try. I think it's been doing this since it was new. I remember when I rejetted, the right carb was like 3 turns out while he left was close to 2.5. Some guy said it could be a float issue but he did not not elaborate more. I don't have a vacuum leak as far as I know.
My bike runs better with the idle at 1500 as well and it was what most recommended.
Old December 20th, 2011, 11:08 PM   #11
00NissanNinja
I hate driving...
Cool, give it a shot. If that doesn't help try messing with the idle screws some more.
Old December 20th, 2011, 11:23 PM   #12
cuong-nutz
cuong-nutz's Avatar
Yeah, I just dumped half a pint of Seafoam in a new full tank of gas. Hope it was worth the 8 dollars.
Old December 20th, 2011, 11:31 PM   #13
00NissanNinja
I hate driving...
Lol, that is exactly how I felt when I got some. It took awhile but the idle eventually stopped being very erratic when I used some.
Idle issues - Idle is different every time I start up. 106 1986 - 2007 Ninja 250R Tech Talk 6 November 13th, 2014 04:57 PM
Unusual Idle? W.Roworth General Motorcycling Discussion 5 September 17th, 2012 10:16 AM
what should i idle at EvilPooMonkey 2008 - 2012 Ninja 250R Tech Talk 7 July 8th, 2012 03:00 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Tachometer fluctuation at stop and idle issues naturalphenomena 1986 - 2007 Ninja 250R Tech Talk 6 November 28th, 2011 12:24 PM
