Old February 17th, 2012, 07:08 AM   #1
-kj-
Motorcycle(s): 09 Ninja 250r
confirmation of key code
Hi Everyone,
I know its another key code thread but I searched the forum and no one has given a complete answer. I've read that the code is on the ignition but no one has confirmed cutting the key from there.Can anyone confirm? I went to the locksmith and he took the pattern from the gas cap. I've read that that doesn't work because the ignition is different.Is this true as well? I also read the helmet lock has the code but i have only for the older generations.
I have an 09 ninja 250r.
-kj- is offline   Reply With Quote
Old February 17th, 2012, 07:13 AM   #2
http://www.ninjette.org/forums/showthread.php?t=27349
Hillbilly Cycles can cut a new key from that code.
Old February 17th, 2012, 09:44 AM   #3
-kj-
The one from the key ignition cylinder?
Old February 17th, 2012, 10:00 AM   #4
Yes.
Old February 17th, 2012, 11:09 AM   #5
indr
If you have one of the originals and need a spare, you can order a blank (~$10) from your Kawi dealer and have it cut anywhere that cuts keys.
Edit: Are you asking if a key cut for the gas tank will work for the ignition and vice versa? I'm positive it will.
indr is offline   Reply With Quote
Old February 17th, 2012, 12:06 PM   #6
Are you sure of this? I know that an ignition key will work in the gas tank (of course), but I thought that the gas tank tumblers only used a portion of the key, so one cut only for the gas tank wouldn't work as an ignition key. But I hope this thread can clarify that.
Old February 17th, 2012, 12:38 PM   #7
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
Originally Posted by -kj- View Post
Hi Everyone,
Sorry maybe im completely retarted and responding without thinking,
but since you open your tank with your ignition key, theoretically SHOULNDT it be the same? =/
blink-182
blink is offline   Reply With Quote
Old February 17th, 2012, 12:59 PM   #8
Momaru
Momaru's Avatar
It is the same key, same pattern. However Alex is correct, the gas cap only uses the front ~2/3 of the ignition key, so if you use the 'pattern' from there, it won't work in the ignition because you're missing that bit next to the base of the key. I fairly sure the same is true of the rear seat lock but will have to confirm (doesn't use all of the key).
In short, all three locks (ignition, helmet/trunk and gas cap) use the same key but the only lock that uses 100% of the key is the ignition.
Proud member of the Blue Army
Old February 17th, 2012, 02:20 PM   #9
blink
Always.
blink's Avatar
Gotcha! Makes sense now
Hope fully it isn't too hard to get a copy then
blink-182
Old February 19th, 2012, 09:26 AM   #10
Momaru
Momaru's Avatar
Well, as stated in the other key thread, Hillbilly Cycle Sales in Princeton, WV is the go-to place for getting keys cut by code. If they're uncomfortable working with you since you're not stateside, let me know. I live about 45min from them, happy to liaison. That said, I haven't heard of them having any such qualms.
Old February 19th, 2012, 11:25 AM   #11
-kj-
I ended up getting the key cut from the car key that i use.If your wondering why its a car key its because the its salvaged and the seller used a car key to make a key. The locksmith said he couldn't cut it from the 4 digit code near the ignition. The key works but only works one way and it doesn't lock the steering .
Old April 2nd, 2012, 06:16 PM   #12
ninja_sleeper
ninja_sleeper's Avatar
Motorcycle(s): Red 2009 Kawasaki Ninja 250R
Call Hillbilly! They know what to do. I am so glad I called them. They were so sweet and there was no problem with me being out of state. They make it work. They were pretty surprised to hear I was in Oregon. No hassle, and pretty inexpensive.
ninja_sleeper is offline   Reply With Quote
Old April 2nd, 2012, 06:32 PM   #13
wicked300z
Rider of the Blue Comet
wicked300z's Avatar
Motorcycle(s): 2009 Ninja
How much was it from HillBilly?
I called Kawaski USA and they referred me to KawaskiKeys.com. Cost about $35 shipped TYD. Plus they require Proof of ownership so no one can just take your code and make "extras".
wicked300z is offline   Reply With Quote
Old April 2nd, 2012, 06:40 PM   #14
ninja_sleeper
It was $44 Total
Old April 2nd, 2012, 07:12 PM   #15
jjb84
Motorcycle(s): 2009 Ninja 250
so all i would have to do is send my 4 digit code, and they can send me a key that works for my bike? thats it???
jjb84 is offline   Reply With Quote
Old April 3rd, 2012, 04:23 AM   #16
wicked300z
wicked300z's Avatar
Yes, You will just need the 4 digit code off the ignition and registration for the proof of ownership.
Old April 17th, 2012, 10:51 AM   #17
-kj-
Can someone tell me about their experience from kawasakikeys.com?
Old April 18th, 2012, 04:54 AM   #18
wicked300z
wicked300z's Avatar
Kawasakikeys.com is pretty good. They source their keys through Lockworld in California and those guys will call you with updates as they cut and ship your key. It was a smooth and easy transaction. Good Communication too.
Old April 18th, 2012, 06:16 PM   #19
-kj-
Originally Posted by wicked300z View Post
Kawaskikeys.com is pretty good. They source their keys through Lockworld in California and those guys will call you with updates as they cut and ship your key. It was a smooth and easy transaction. Good Communication too.
I agree, Kawasakikeys.com is great. I ordered from them on Monday and I just got my key today( I live about 40 mins away). Great customer service!
How do I get the key lock code for my 2009? airjordan23 2008 - 2012 Ninja 250R Tech Talk 12 April 24th, 2015 04:35 AM
Need Visual Confirmation of Carb Hose Routing indr 2008 - 2012 Ninja 250R Tech Talk 3 June 23rd, 2013 07:49 PM
Help! - need confirmation! AndrewMack 2008 - 2012 Ninja 250R Tech Talk 25 January 15th, 2013 04:30 AM
[sportrider - features] - Keith Code California Superbike School - Cracking The Code Ninjette Newsbot Motorcycling News 0 September 20th, 2010 05:40 PM
[roadracingworld.com] - New NHTSA Administrator Waiting On Confirmation By Senate Ninjette Newsbot Motorcycling News 0 December 16th, 2009 10:30 AM
