Old March 4th, 2022, 11:37 PM   #1
NinjaFinally
Motorcycle(s): GPX250R 2006
My front sprocket seemed to have had rubber dampers?
While I was fixing my neutral wire, I noticed that the sprocket does not look like in the wiki. At the bottom just left of the bolt is a piece of green rubbery stuff. It looks like there should be 6 but there is only one left. I found what I thought were other ones in the crud in the cover. What is this - I suspect some sort of chain damper? Will their lack be a problem? Cheers.
NinjaFinally is offline   Reply With Quote
Old March 7th, 2022, 09:33 AM   #2
shspvr
That most like just antifreeze mix in or dark green grease and you need new front drive sprocket
Old March 12th, 2022, 02:34 AM   #3
NinjaFinally
OK thanks. I am planning a chain and sprockets change in the future and will fix it then.
96 250R Sprocket cover & rubber feet nickcasa 1986 - 2007 Ninja 250R Tech Talk 7 January 25th, 2014 11:32 AM
Rubber build up on front fender MarcoPolo General Motorcycling Discussion 6 May 10th, 2012 09:16 PM
