Old April 17th, 2009, 02:22 PM   #1
mxnello
Motorcycle(s): 2009 Ninja 250R 'Blue'
Oil change
09 shifting is a little clunky, any opinions on best oil to allow smoother gear changes?
mxnello is offline   Reply With Quote
Old April 17th, 2009, 02:26 PM   #2
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
How many miles and last oil change?
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old April 17th, 2009, 02:38 PM   #3
mxnello
250 miles
1st change
Old April 17th, 2009, 02:41 PM   #4
OldGuy
Live Life
OldGuy's Avatar
Well that would tend to rule out oil as the problem. Can you help us understand what you mean by "clunky".
On both my '01 and '09 I will occasional get a "clunk" during an up shift, especially if I am short shifting (shifting way early in the RPM range).
- ATGATT -
Old April 17th, 2009, 02:47 PM   #5
mxnello
clunky
just not as smooth as I would of thought, had many a motocross bike that shifted way smoother.
Old April 17th, 2009, 02:52 PM   #6
Sound Wave
Ramen Rider
Sound Wave's Avatar
mine "clunks" from n-1 and 1-2. i think that is the way it is supposed to be.
Old April 17th, 2009, 02:53 PM   #7
OldGuy
Live Life
OldGuy's Avatar
If you are getting up and down in gears without any problem and it's just not as smooth as you think it should be, give it some time and keep you ears open for unusual sounds. I've found both my bikes shift the best when you ride them "with spirit"
- ATGATT -
Old April 17th, 2009, 02:54 PM   #8
mxnello
same
here, seems worse with the shift from 1-n-2,
Old April 17th, 2009, 02:58 PM   #9
Sound Wave
Ramen Rider
Sound Wave's Avatar
i don't think changing the oil will help our "problem" and it doesn't bug me. however, i was going to change my oil this weekend anyways. i got a bit over 1300 miles and i am switching to semi-synthetic. this will be my 2nd oil change. first was at 550 miles with conventional oil.
i will see if there is any difference with the "clunk" after the change.
Old April 17th, 2009, 03:01 PM   #10
mxnello
semi syn
let me know how you make out, if it helps at all.
Old April 17th, 2009, 03:45 PM   #11
islanderman7
The Sexy Filipino
islanderman7's Avatar
Motorcycle(s): Ninja 250R 2008 (da black one)
http://www.ninjette.org/forums/showthread.php?t=16993
Area P CF Standard,Airbox Removed,K&N R-0990,Factory Pro Jet Kit 3.0, Zero Gravity DB
I'm not riding too fast... I'm flying too low.
islanderman7 is offline   Reply With Quote
Old April 17th, 2009, 03:48 PM   #12
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
I doubt changing the oil will help, but it certainly won't hurt.
I would recommend you stick with good old 10W40, as recommended in your owner's manual. Synthetic IMHO is a waste of money as you'll be changing the oil soon anyhow.
I find that the Ninja 250r has a very solid, positive feel to the transmission. When you change gears, the feeling that reminds me very much of flicking a lightswitch. As soon as you give it a firm nudge with your foot, the next gear just snaps right into place.
Old April 17th, 2009, 04:06 PM   #13
The trannys on the 250Rs are not the snickety snick type. They are rather crude and clunky, but they do get the job done. I agree I've had dirt bikes that shift cleaner and smoother than the ninja.
That being said, I'd recommend you try changing the oil and filter on your own and see if it makes a diff. I know there are some that have had a remarked difference after getting that horrible factory oil out and some quality fluids in there in terms of shifting ease.
I also agree that changing to a synthetic after you feel the motor is fully broken in is a good thing. With so little power from these engines, any advantage you can give them to make as much power as possible is a positive. Full synthetic helped the shifting in my bike, too, and I highly recommend it, but then I've always been a believer in synthetic oils in small displacement engines for a number of different benefits.
ps- also, make sure your clutch lever/cable is properly adjusted.
Old April 17th, 2009, 04:21 PM   #14
1hardryder4life
Motorcycle(s): Nothing
mine be a bit clunky sometimes too. Usually only when shifting at low rpm ranges though. perhaps i will try synthetic next change.
1hardryder4life is offline   Reply With Quote
Old April 17th, 2009, 06:30 PM   #15
I recommend you do that only after you feel your bike is fully broken in. That is the only caveat I have on using the proper synthetic oil in our bikes.
Old April 17th, 2009, 09:07 PM   #16
almost40
ninjette.org Monkey Spank
almost40's Avatar
I have to agree with Kkim..... I would run regular 10w40 motorcycle oil till at least 1500 miles and change it often.(at least 3 times) I switched to full synt Mobil 1 and did notice a big difference in shifting smoothness.
Black 250R
Full Area P QC
Old April 17th, 2009, 09:10 PM   #17
plus, if you beat the hell out of your bike at the dragstrip, every little bit of shear strength protection helps, eh?
Old April 18th, 2009, 04:47 AM   #18
mxnello
thanks
will do the regular oil for 1st 3 changes then switch over.
Old April 18th, 2009, 07:43 AM   #19
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
I just changed my oil yesterday from regular Rotella T to full synthetic Rotella T. Rotella T is slightly thicker truck-type oil and is used by a lot of riders and comes highly recommended. Try using the regular Rotella T and it may make the wet clutch slightly easier to engage. Then when you hit 1500 miles or more you can switch to Rotella T full synthetic.
TrueFaith is offline   Reply With Quote
Old April 18th, 2009, 09:18 AM   #20
almost40
almost40's Avatar
Well Kkim it sure doesnt hurt lol. I figure the extra 7 bucks (at most) is worth every penny. By the way I dont beat up my bike, I polish it with a diaper. Ill beat up the lil mill on my upcoming track days.
Black 250R
Full Area P QC
Old April 18th, 2009, 03:17 PM   #21
1hardryder4life
my bike is def broken in. Its a daily commuter, and my commute is canyon riding, no freeway stuff here. though I just changed the oil a few days ago and didnt even consider synthetic. I shall wait til next service.
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
Oil drain plug gasket for oil change. tsdexter 2008 - 2012 Ninja 250R Tech Talk 8 July 10th, 2012 01:00 PM
Oil Change Honko 2008 - 2012 Ninja 250R Tech Talk 10 July 17th, 2011 08:58 AM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
