Old December 24th, 2017, 06:14 PM   #1
EffaMoulton
EffaMoulton's Avatar
Motorcycle(s): 2010 Ninja 250r SE
What is supposed to go on the gauge cluster bolt
The bolt holds on the gauges but it looks like it’s missing some kind of grommet. I used a couple crush washers (because that’s all I had on hand) but I would like to know what actually goes on the bolt. Not sure if it’s supposed to be something rubber to absorb shock. (The bolt it question is the one with the goldish washers)
File Type: jpg 501E0311-3847-4AE8-BF25-B4847064C1D2.jpg (109.7 KB, 18 views)
Last futzed with by EffaMoulton; December 24th, 2017 at 08:25 PM.
EffaMoulton is offline   Reply With Quote
Old December 25th, 2017, 01:42 AM   #2
Flying
It's supposed to be just a bolt and a washer to distribute the force over the plastic.
Old December 25th, 2017, 08:59 AM   #3
EffaMoulton
With just the one washer the gauges flop all around, is that normal?
Old December 26th, 2017, 07:17 AM   #4
Flying
That isn't normal. Make sure that the fastener/threads are in good shape.
Old December 26th, 2017, 04:19 PM   #5
EffaMoulton
Didn’t think so, it’s possivle that the previous owner put way too long of bolts in, I’ll figure something out. Thanks.
Is the fan supposed to stay in all the time? Omarel 1986 - 2007 Ninja 250R Tech Talk 20 September 20th, 2016 07:14 AM
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd Klondike1020 General Motorcycling Discussion 8 August 17th, 2014 12:23 AM
What are you supposed to do... corksil Off-Topic 13 December 17th, 2013 01:13 AM
When is your fan supposed to come on? 20ninja03 1986 - 2007 Ninja 250R Tech Talk 3 February 26th, 2011 01:37 PM
valve clearance??? what are they supposed... ecannon1 1986 - 2007 Ninja 250R Tech Talk 3 May 20th, 2010 10:41 AM
