Old May 17th, 2014, 10:53 AM   #1
Josh_kcco
Josh_kcco's Avatar
Motorcycle(s): '04 Ninja 250R
Slow crawl to idle.
When coming to a stop or just revibg it at idle, it will hang at 2k rpm then slowly crawl down to idle. I have idle set at 1200.
Is this normal? Or could something be wrong.
I haven't noticed it till now. Last I did was remove tank, clean airbox. Not sure if I put something back wrong or what. Please help.
Josh_kcco is offline   Reply With Quote
Old May 20th, 2014, 06:59 AM   #2
If everything was good before, spritz some carb cleaner around the vacuum lines, carb boots and airbox to check for leaks.
[motorcycle-usa.com] - Smoky Mountain Crawl Ruckus|Grom Event '15 Ninjette Newsbot Motorcycling News 0 February 26th, 2015 09:40 PM
Giving up the slow bike for a slow car CycleCam303 Off-Topic 17 February 18th, 2014 02:13 AM
Slow throttle response and slow return to idle help Crriiissss 1986 - 2007 Ninja 250R Tech Talk 22 August 7th, 2013 12:26 AM
Portland Bike Pub Crawl ninja_sleeper Ride Reports 7 September 2nd, 2011 04:49 PM
slow return to idle red 2008 - 2012 Ninja 250R Tech Talk 4 April 9th, 2011 09:25 PM
