Old April 16th, 2012, 08:17 AM   #1
DCBenson
DCBenson's Avatar
Motorcycle(s): 2009 Ninja 250R (street) / 2009 Ninja 250R (track)
Rain Drenched Bike Won't Start
OK guys. My bike got caught in the rain and now it won't start. Help me please. Here is what I have done:
1. Completely dried the entire bike.
2. Drained the tank and replaced with fresh gas.
3. Removed and cleaned carb.
4. Cleaned spark plugs.
5. Replace computer (from track bike)
I am getting compression and it turns over fine. It just won't start. I'm at wits end. I wanna ride. HELP!!!
DCBenson is offline   Reply With Quote
Old April 16th, 2012, 08:36 AM   #2
DaBlue1
DaBlue1's Avatar
Was it sitting in the rain or were you riding it? Have you checked inside the airbox / airfilter? Are both carb boots and vacuum hoses securely fitted?
Most Japanese motorcycle electrical connectors are open at the rear, letting in moisture that will collect on the male and female pins/sockets, causing a short, blowing a fuse or creating corrosion limiting current flow. Have you checked your connections?
Old April 16th, 2012, 08:41 AM   #3
DCBenson
DCBenson's Avatar
It was sitting in the rain. New air filter and the box is clean and dry. Carb work should be tight. Pulled it twice and then replaced with the one from track bike. No blown fuses. Checked them all...even the horn. I have not checked all the connections for corrosion. Which ones would prevent it from starting? I have fuel and spark.
Old April 16th, 2012, 09:59 AM   #4
Replace the old computer and test
Old April 16th, 2012, 10:41 AM   #5
are you getting spark?
Old April 16th, 2012, 10:47 AM   #6
Did a lot of water get into the exhaust?
Old April 16th, 2012, 11:59 AM   #7
DCBenson
DCBenson's Avatar
OK. Changed the computer already form the track bike...yes I'm getting spark, replaced exhaust with factory one from track bike. Nothing.
Old April 16th, 2012, 01:11 PM   #8
DaBlue1
DaBlue1's Avatar
Originally Posted by DCBenson View Post
....Which ones would prevent it from starting? I have fuel and spark.
Safety switches. (neutral, sidestand, shut off)
Old April 16th, 2012, 02:48 PM   #9
flynjay
flynjay's Avatar
Having spark rules out the safety switches.
Old April 19th, 2012, 07:45 AM   #10
DCBenson
DCBenson's Avatar
C'mon. I wanna ride. Any more suggestions?
Old April 19th, 2012, 01:12 PM   #11
Whiskey
How much rain are you talking about?
I lived in a country where it rained on average 10 days every month, the bike was used to commute for 2 years so was parked outside for 8-10 hours a day rain or shine and it always started first go.
The rain shouldn't cause any problem
Old April 19th, 2012, 01:15 PM   #12
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Put your bike in a plastic bag with white rice, the white rice will pull all the moisture out and it should start up like new again.
AFM #676
Supersports are for n00bs
Old April 19th, 2012, 03:27 PM   #13
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
this is the only solution.
PS:
If the engine turns over, you have compression and spark, and it STILL won't start, and you have checked everything.... then you missed something.
Re-check all the electrical connections that could have been exposed, it is possible a short is stopping it from starting. Check that none of your hoses are clogged somehow.
MikeBudd is offline   Reply With Quote
Old April 19th, 2012, 05:34 PM   #14
drac
drac's Avatar
Motorcycle(s): '88 Hurricane 600, '09 Ninja 250
Does it fire if you use some starting fluid???
While no trees were harmed in making this post, a large number of electrons were severely inconvenienced.
drac is offline   Reply With Quote
Old April 19th, 2012, 06:41 PM   #15
DCBenson
DCBenson's Avatar
It sputters but not consistently.
Old April 19th, 2012, 06:42 PM   #16
AmplexorJ
AmplexorJ's Avatar
Motorcycle(s): 2003 Ninja 250
ok my bike was also drenched the same day as yours and would not start.
I followed this thread and found some more here and the interwebs and figured out what needed to be done.
Problem:
-Left bike in downpour for no reason (lazy note:wife said "told ya so")
-Bike tried to start first attempt then nothing
-would turn over and could hear and feel compression
The Fix (after checking other stuff)
-with tap turned to "on"
-drained BOTH carb bowls into little cup
-tried to start only to fill bowls
-drained bowls again
-tried to start....almost started
-time to drain tank
-drain bowls once again
-fill tank
-turn over till bowls fill and boom...
Its running great again
could have omitted a few steps there but was testing the "waters" HA
I guess I have a bad gas cap seal.
thats the only thing I can figure?
dunno if this'll help but good luck
AmplexorJ is offline   Reply With Quote
Old April 19th, 2012, 06:44 PM   #17
DCBenson
DCBenson's Avatar
PS:
I've changesd the tank and just about every electrical connection with the track bike. Just tried to start the bike while in gear with the clutch depressed and it tried to roll forward.
Old April 19th, 2012, 06:49 PM   #18
DCBenson
DCBenson's Avatar
It does but I've done everything there is to do with the gas and carb. Drained and then replaced. The carb on it has 125 miles on it. It like brand new.
Old April 19th, 2012, 07:34 PM   #19
drac
drac's Avatar
Spark is good and bright?
Plug firing consistently? Not intermittent.
Old April 20th, 2012, 04:05 AM   #20
GiGs
Un-clip all your electrical connections and blow them out with an air compressor, if you don't have an air compressor use your mouth
Good luck
GiGs is offline   Reply With Quote
Old April 20th, 2012, 11:15 AM   #21
MikeBudd
MikeBudd's Avatar
You tried to start your bike in gear with the clutch depressed and the bike tried to roll forward?
If the clutch is depressed that should not happen.
Old April 23rd, 2012, 05:27 PM   #22
DCBenson
DCBenson's Avatar
Thats what I thought. What would cause that and would that problem prevent it from starting?
Old April 23rd, 2012, 05:33 PM   #23
drac
drac's Avatar
Yes it could keep it from starting..........but if it is in neutral it rolls freely, correct?
Old April 23rd, 2012, 05:44 PM   #24
DCBenson
DCBenson's Avatar
In nuetral it frolls freely. I put it in gear, pulled the clutch in and tried to start. It tried to roll. Still no start.
Old April 23rd, 2012, 06:19 PM   #25
drac
drac's Avatar
The rolling thing could be as simple as clutch cable adjustment, I wouldn't worry about it right now. Get it firing in neutral then go from there.
The fact that it doesn't fire every time when using starting fluid sounds like intermittent spark to me. Are you just spaying some into the airbox? Better would be to remove airbox and spraying equal amount directly onto each carb......Both cylinders should fire every time like that.
Bike Won't Start momoru 1986 - 2007 Ninja 250R Tech Talk 6 June 18th, 2014 08:34 AM
Bike won't start FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 127 November 17th, 2013 03:18 PM
Bike won't start after the rain >_< Zombiphone 2008 - 2012 Ninja 250R Tech Talk 8 March 27th, 2011 06:30 AM
bike won't start :/ SephiaSputnik 1986 - 2007 Ninja 250R Tech Talk 20 March 12th, 2010 02:40 PM
