Old April 21st, 2013, 08:37 PM   #1
Monkeytofu
I told you bro
Monkeytofu's Avatar
Strange fuel leak from carbs
Hey guys, no idea where this leak is coming from so I recorded a video of it. Happened after I put my gas tank on the bike and only happens when my bike is running:
Do I need to empty the bowls? It's not from the tank as looked over the whole thing to check for leaks.
Old April 21st, 2013, 08:54 PM   #2
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Only one way to find that leak is to take it apart.
Old April 21st, 2013, 08:59 PM   #3
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
There is a gasket on the float bowls so I'd check that It may be cracked or installed improperly. Check the fuel lines to the carbs too; follow them from the gas tank to the carbs. See if there is any cracking or hoses that are fully secure. Probably should try that before pulling the crabs to check those gaskets.
EDIT: Could start by draining the fuel out too. You might have something clogging the system up or a stuck float too. Is the fuel coming from the carb vent? Can't really tell from the vid
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old April 21st, 2013, 09:22 PM   #4
Monkeytofu
I told you bro
Monkeytofu's Avatar
All I can see is fuel dripping off that point in the video. If the carb vent is that yellow tube, then no it's not. It's dripping off the metal piece that covers the idle dial.
I'll take it apart tomorrow when I have better lighting, just didn't have this issue a couple days ago.
Old April 21st, 2013, 09:37 PM   #5
fishdip
fishdip's Avatar
best way to rule out a leak from a fuel line is to un hook them your bike will run for a few min with out them hooked up and with just the gas in the carbs.
Old April 22nd, 2013, 08:24 PM   #6
Rollingmenace
Motorcycle(s): 96 Ninja 250EX , 87 CBR 1000, 86 TRX 260R, 86 KXT 250, 84 ATC 200X, 82 ATC 250R (w/CR480)
I could be wrong I haven't had mine apart in a while but isn't there a plastic T that feeds fuel to each carb I've seen the little o ring on the T fail and leak like that
Rollingmenace is offline   Reply With Quote
Old April 23rd, 2013, 06:16 AM   #7
cuong-nutz
cuong-nutz's Avatar
I Betcha it's the float bowl gasket leaking.
HalfFast Racing Team
Old April 23rd, 2013, 06:24 AM   #8
.........only happens when my bike is running..........
The float-valve doesn't close correctly while vibrating.
Either the valve is hardened or the float is rubbing against something.
...........I could be wrong, though.
Fuel/Oil leak, only when raining? tmf1423 2008 - 2012 Ninja 250R Tech Talk 3 March 25th, 2014 11:57 AM
Possible gas leak from carbs or petcock issue agentbad 1986 - 2007 Ninja 250R Tech Talk 7 December 13th, 2013 07:45 AM
mysterious fuel leak 10inja 2008 - 2012 Ninja 250R Tech Talk 1 December 2nd, 2013 05:04 AM
Help, fuel leak. Stangrider 2008 - 2012 Ninja 250R Tech Talk 3 June 24th, 2013 09:34 PM
Weather=fuel leak? 48newrider 1986 - 2007 Ninja 250R Tech Talk 5 March 13th, 2013 07:09 PM
