Old May 25th, 2013, 02:50 PM   #1
ChaoSS
Motorcycle(s): 2012 red 250 ninja
Dropped something in the motor
So, if, hypothetically, one were to drop the feeler gauge down into the engine next to the cam chain, and not be able to find it, what's the next step? Pulling the clutch cover? Does that give access to the crankshaft where I'm guessing it fell? Is there anything to it other than disconnecting the clutch cable and pulling the cover off?
ChaoSS is offline   Reply With Quote
Old May 25th, 2013, 02:59 PM   #2
cuong-nutz
cuong-nutz's Avatar
Pull the clutch cover of you get lucky use a magnetic pick-up tool and fish for it.
HalfFast Racing Team
Old May 25th, 2013, 03:33 PM   #3
ChaoSS
Ok I got it out.
Guess it's too much to ask for my local dealer to carry a gasket for the thing, so now I get to try to do it with some DIY gasket maker sealant crap.
Old May 25th, 2013, 03:35 PM   #4
cuong-nutz
cuong-nutz's Avatar
Most moto dealers don't carry crap in stock. Only think in stock is oil filter, filter, and spark plugs.
Old May 25th, 2013, 05:51 PM   #5
Originally Posted by ChaoSS View Post
........so now I get to try to do it with some DIY gasket maker sealant crap.
Nooooooooooooooooo!!!!!!!!!!!!!!
http://www.ninjette.org/forums/showt...=127820&page=2
http://www.dansmc.com/gaskets.htm
Any paper based material like manila folder will work.
If the gauge is a package of blades, it may be stuck between the chain and well and lower sprocket and opening the clutch compartment may not help much (the clutch basket is covering much of it).
If you end up removing the cam shafts, return each cam cap (or top of the bearing) to its original position and torque those bolts as specified.
Old May 25th, 2013, 10:31 PM   #6
ChaoSS
I didn't remove the cam shafts. I did get the gauge out already. I did already use gasket maker. If it doesn't work, I redo it when I can get a new gasket.
Now my new problem is that my new chain i bought from Motorcyclesuperstore turns out to be a clip type. It didn't say on the page, but the comments specifically said press type, and here I have a clip type. So now I have to figure out whether to use it or return it or whatever.
Old May 25th, 2013, 11:13 PM   #7
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
A lot of moto dealers and parts places have master links, you may be able to get a rivet type there. Just call.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old May 25th, 2013, 11:52 PM   #8
ChaoSS
Yeah, I'm going to call motorcycle superstore in the morning and see if they can make good on it and send me the appropriate link, if not I'll see what cycle gear can do for me. I had hoped to have this thing done over the weekend, but oh well. I have another bike to ride for now.
Old May 26th, 2013, 08:46 AM   #9
ChaoSS
Well, I guess the lesson learned here is never buy from Motorcycle Superstore. Ever. After sending me the wrong chain they tell me my only options are to return the chain and buy a different one (but they can't tell me what I need to order to get the correct one) or to buy another master link from them.
So I guess I call around and see if anyone sells the correct master link, or just deal with the clip one, maybe it isn't too bad?
Old May 26th, 2013, 08:54 AM   #10
...........Now my new problem is that my new chain i bought from Motorcyclesuperstore turns out to be a clip type. It didn't say on the page, but the comments specifically said press type, and here I have a clip type. So now I have to figure out whether to use it or return it or whatever.
Not the end of the world.
Some solutions here, being the best the one shown in post #27:
http://www.ninjette.org/forums/showt...in+safety+wire
Old May 26th, 2013, 10:05 AM   #11
ChaoSS
Yeah, I do like that solution, I don't understand the concept of safety wiring the clip on, seems like the teeth on the sprocket would end up tearing up the safety wire. I was thinking a little JB Weld on the clip, but if I use a clip it might be nice to be able to remove it.
Thanks for the link, btw, I saw that when it was written, but couldn't seem to find it when I was looking for it yesterday.
Old May 26th, 2013, 05:16 PM   #12
What brand is it? I have a spare gold RK brand 520 X-ring rivet type master link I can mail you if needed. I got a spare one, assuming that my chain wouldn't come with one. Gold was because it's easier to spot on a silver chain. But then the chain came with a rivet type master link so I never used it.
Old May 27th, 2013, 07:05 AM   #13
ChaoSS
It is a DID chain, but thank you. I think that I'm going to install it, safety wire it, and hope for the best. I need to put tires on the bike soon, and it will be easier to pull the rear wheel with a clip type I guess. I might buy a new rivet type when I put it back on with the new tires, we'll see.
Old May 27th, 2013, 04:57 PM   #14
ChaoSS
Ok, so, stupid quesetion, but when I took the rear wheel off, the brake fell off, and I don't know that I'm putting it back together correctly. It seems right, but is the whole caliper assembly supposed to swivel like that? Like, when you are going forward it has a stop, but nothing to prevent it from moving backwards when it is going in reverse and you hit the brakes
Old May 27th, 2013, 05:01 PM   #15
ChaoSS
Never mind, figured out that I'm an idiot.
After I got the thing aligned and everything.
Old May 27th, 2013, 05:33 PM   #16
Trailerboy531
yeahhhhh make sure that the caliper is being held inline using the axle through the hole on the mount...
CVMA #531
Old May 27th, 2013, 06:35 PM   #17
try changing rear wheel on the side of the road with no stands (literally... not even a kick stand.)
Old May 27th, 2013, 06:41 PM   #18
Trailerboy531
So....when you say "changing" rear wheel.... Did you patch a flat or happen to have a spare wheel hidden deep in your cavities?
CVMA #531
Old May 27th, 2013, 06:50 PM   #19
ChaoSS
No that wasn't the problem, the problem was I somehow managed to miss the fact that there is a slot that the caliper slides into to prevent it from rotating around with the wheel....
I noticed it. After I had gotten everything else put on, and finally gotten it aligned properly. And this is the first time I had ever gotten it aligned truly properly, with the string method, instead of "aw shucks, looks about right" so it took me a little bit.
But it's ok, I got it figured out.
This is what happens when I take stuff apart without paying attention to it and have to put it together again. I usually try to follow the direction, but the directions for removing the rear wheel said something about removing the shock mounts, and that just seemed wholly unnecessary.
Old May 27th, 2013, 07:46 PM   #20
........This is what happens when I take stuff apart without paying attention to it and have to put it together again......
That happens to everyone.
Taking digital pictures during the disassemble process helps much.
[roadracingworld.com] - MPT Industries Named "Official Motor Oil" Of New Jersey Motor Ninjette Newsbot Motorcycling News 0 January 19th, 2015 10:40 AM
Dropped Baby Dropped Baby Dropped... TBC !%@*#$%!)@#&!%@ I crashed! 7 March 12th, 2013 08:37 PM
[hell for leather] - Motor cop injured at memorial for motor cop killed in head on co Ninjette Newsbot Motorcycling News 0 June 7th, 2011 12:40 PM
[topix.net] - Motor cop killed in head-on collision with motor cop Ninjette Newsbot Motorcycling News 0 May 28th, 2011 02:30 AM
[hell for leather] - Motor cop killed in head-on collision with motor cop Ninjette Newsbot Motorcycling News 0 May 27th, 2011 02:20 PM
