Old February 25th, 2010, 04:58 PM   #121
Roostre
Motorcycle(s): Ninja 250,KTM 690 Enduro R, KTM300XC, XB12X Buell, 1966 Hummer 175
I run 85 because the altitude here is about 5000 ft above sea level... but this is what the bike says on the inside of the fairing:
Maybe on a hot dry day near the coast...if it started pinging! (This does have California emissions for some reason.)
Roostre is offline   Reply With Quote
Old February 25th, 2010, 05:10 PM   #122
It's a misleading sticker, as the US does not use RON. We use RON+MON/2. 91 RON works out to roughly 87 RON+MON/2, as MON is typically about 7 - 10 points less. Look at the Octane number details on any pump, and somewhere in the fine print it will show that RON+MON/2 formula. It's not an exact science, and the particular fuel blends matter, but that sticker should not be read to mean that our bikes, pre-gen or current-gen, require premium gas here in the US.
Old February 25th, 2010, 05:17 PM   #123
Roostre
Nice explanation!
I did not know that.
So actually in the US we could run 81- 83 octane and be fine!! Wow.
Old February 25th, 2010, 10:05 PM   #124
pinkard129
pinkard129's Avatar
Motorcycle(s): 04' ninja matte black and naked
i run 93 in mine because of the high compression, i figured running anything lower would cause pre-detonation. i may be thinking old school tho
pinkard129 is offline   Reply With Quote
Old February 25th, 2010, 10:20 PM   #125
Keenan84
Keenan84's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r Special Edition
The compression isnt actually high. Your actually just wasting cash because 87 octane wont cause pre-detonation. Infact 93 octane is slowing down ignition and your probably losing a slight amount of power.
Keenan84 is offline   Reply With Quote
Old March 9th, 2010, 08:55 PM   #126
foxpaws
Motorcycle(s): 10 kawi ninja 250
this seems like the right thread for this question: how does altitude change fuel requirements? if i'm on a road trip, how do i choose what to feed the beastie with?
foxpaws is offline   Reply With Quote
Old March 9th, 2010, 09:13 PM   #127
High altitude lowers the required octane, so while 87 will work anywhere, at high altitudes if something like 85 or even 83 were available, it would likely work fine. Since in most cases 87 is the minimum anyway, it'll be fine.
Old March 9th, 2010, 11:46 PM   #128
pedaltothemetal
pedaltothemetal's Avatar
Motorcycle(s): Plasma Blue 2008 Ninja 250R, 2006 Honda Ruckus 180cc swap, 1967 BMW R60US, 2008 Ninja ZX-14se
Increase in carbon deposits in the combustion chamber increases compression ratio. If you do get ping because of this, then you should use higher octane.
These engines run at very high rpms, and as long as you don't lug the engine under load you should be ok on 87 octane.
Personally I have been using 91 cause just in case I get a batch of bad gas!
SCAR
ARC
SCSB
pedaltothemetal is offline   Reply With Quote
Old March 10th, 2010, 07:52 AM   #129
mrlmd
mrlmd's Avatar
I'm sorry, but this is wrong, from the first sentence to the last, and makes absolutely no sense. And why does using 91 just in case you get a batch of bad gas help? Why is that better? You still don't understand what octane rating means and what it does. Not only are you wasting your money, you are robbing your engine of power and also going against the recommendation of the engine manufacturer. Do you really think you know better than them?
People have the mistaken idea that the higher the octane rating, the better or more powerful the gas is, and that is just not correct. So do what you want, use your own logic to justify your actions, but you are not helping yourself or your bike in any way.
Old March 10th, 2010, 11:50 AM   #130
pedaltothemetal
Bad gas just means lower octane than advertized cause some unscrupulous dealers buy less quality gas with additives missing so they can make a few more pennies per gallon. Makes the engine run bad.
In my camaro running regular will cause the engine to retard if the knock sensor detects it. This decreases performance. I have always been a car guy and so with my ninjette treat it just like a high performance engine!
You go by the book and I just go by my experience and we both are very happy!
SCAR
ARC
SCSB
Old May 25th, 2010, 12:10 PM   #131
Old May 25th, 2010, 12:36 PM   #132
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Bad gas can be from contaminants in the tank or the truck delivering the gas.
Old May 25th, 2010, 12:47 PM   #133
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
LOL not even my gixxer gets 91 octane.
Here's a question for everyone. If the jerk before you used 87 octane gas, then you come puttering in and opt for 91....how much 87 gas (already in the hose out of the pump) gets into your tank before the 91 starts flowing in? That oughta get a few butts puckered
Old May 25th, 2010, 01:23 PM   #134
QuarterBoreNinja
Motorcycle(s): Why do you care?
87 in both the Ninjettes as recommended, no issues whatsoever, there's no sense in running a higher octane unless you experience problems with 87...
QuarterBoreNinja is offline   Reply With Quote
Old May 25th, 2010, 01:27 PM   #135
Snake
Snake's Avatar
That's a very good way of looking at it. I never thought of the gas left in the hose.
Old May 25th, 2010, 01:35 PM   #136
jonthechron
Motorcycle(s): magHitVE
I've done the test, in both my bike and my car. I've tried 87-89-91-94-95, I seem to get the best results and I feel like 89 is right for me, I'm at like 100 ft above sea level. Does this make any sense?
Old May 25th, 2010, 01:36 PM   #137
no
Old May 25th, 2010, 01:46 PM   #138
patw
patw's Avatar
Motorcycle(s): 2009 Ninja 250 SE
I tried some Shell V-Power this weekend, and I noticed the bike running a lot smoother (less hesitations, more pull, smoother idle, better fuel economy). I normally just gas up at the Pioneer 1 block from my house.
Now the story would end here as a random anecdote, but the science is terrible so I'll refute it:
- The temp has gone up almost 10-15C this weekend, warmer ambient could easily explain it.
- I did my chain maintenance and lubed the axles on the wheels. It doesn't explain the engine changes, but it always makes the bike feel smoother.
- Shell gas could have some chemical differences that the bike is better engineered to handle (ethanol ratios?).
- Pioneer is typically cheaper than shell around here, it's possible there might be more particulate in the fuel (pure speculation). Shell's regular gas might work as well (or better) than the v-power.
- The bike is a 2009 with 13k km on it, I'm not sure the injector cleaner (does it even work on carbs?) they include in v-power would have much effect, unless my existing gas was somehow causing problems.
I believe I spent $1.00 extra on my fill up to speculate on the internet. The only thing I can say for sure is v-power entertained me for a bit
2013 CRF250L
1985 GL1200 Interstate
patw is offline   Reply With Quote
Old May 25th, 2010, 01:56 PM   #139
Flashmonkey
This was mentioned on another forum that I frequent and thought it would be appropriate to mention this here.
This doesn't even account for the amount of ethanol certain companies put into their gas additive package that effectively lowers the octane rating further.
Old May 25th, 2010, 02:56 PM   #140
It's a common worry on car and bike forums, but there's not much validity to it. There is < 1/4 gallon of fuel, at most, in the portion of the pump that would remain from the prior customer. Even a small bike tank where someone fills up 3 gallons, the worst case would be 1/12 * 87 octane and 11/12 * 91 octane, which for all intents and purposes would result in 91 octane in your tank. Keep in mind that fuel companies often overshoot the octane number as it can drop over time and it is required to meet certain standards when tested later at the end of the line (at the gas station). Unless someone fills up 1/2 gallon at a time, it's just not a worry.
Ethanol is actually one of the most common ways to *raise* the octane level. The high ethanol content gas means that much less of other additives and treatments are necessary to meet the octane rating requirements. Ethanol has less available power in it by weight compared to standard gasoline, but its octane rating is quite high.
Old May 25th, 2010, 03:39 PM   #141
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
Vp u 4.2
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old May 25th, 2010, 03:52 PM   #142
Snake
Snake's Avatar
Originally Posted by ztrack157 View Post
Vp u 4.2
Old May 25th, 2010, 03:55 PM   #143
ztrack157
The Sportisi Master
ztrack157's Avatar
Race fuel $66 for 5 gallons 102 octane leaded and oxygenated
Old May 25th, 2010, 03:58 PM   #144
Snake
Snake's Avatar
^^^ Ah ok.
Old May 25th, 2010, 04:20 PM   #145
oooo... will that make a stock ninja 250 as fast as a ss600?
Old May 25th, 2010, 04:39 PM   #146
GeorgiaHooligan
GeorgiaHooligan's Avatar
I run 93 because it burns cleaner and its easier on engine parts. And with great gas mileage like this, why not spend a few extra pennies. Use it while you can, before you know it all the oil will be in the ocean.......
GeorgiaHooligan is offline   Reply With Quote
Old May 25th, 2010, 04:53 PM   #147
ztrack157
The Sportisi Master
ztrack157's Avatar
Nope. But whoever said my bike was stock. 33+hp isn't bad for a track/ race bike
Old May 25th, 2010, 04:59 PM   #148
that is entirely false and the reason this thread was started.... to dispel those misconceptions about higher octane fuels.
Old May 25th, 2010, 05:03 PM   #149
Thrak
Motorcycle(s): Lots
False and False...
Thrak is offline   Reply With Quote
Old May 25th, 2010, 05:17 PM   #150
rceezy
Lean Me
rceezy's Avatar
I use 87 because I'm cheap. There, I said it!!! And... maybe because that's what the fam said to use.
rceezy is offline   Reply With Quote
Old May 25th, 2010, 05:57 PM   #151
ztrack157
The Sportisi Master
ztrack157's Avatar
Originally Posted by Thrak View Post
False and False...
Agreed with Dwayne and Kelly. If If I did not have the ignition advanced to where it was I would run 87 octane because it performs the best with the stock set up.
Old May 25th, 2010, 07:29 PM   #152
Flashmonkey
Right...right...sorry. Ethanol has less energy than gasoline...that's why it sucks...not because it lowers octane.
Insert facepalm here
Old May 25th, 2010, 08:40 PM   #153
blackburn RR
Black Ninjas
blackburn RR's Avatar
Motorcycle(s): Kawasaki Ninja zx150RR, 250R
Red face
sorry, this Q really caught me off guard,
are you saying that in your country the fuel of different grades are coming off from the same pump??
It is much easier to stop smoking than to recover from stroke.
blackburn RR is offline   Reply With Quote
Old May 25th, 2010, 08:42 PM   #154
yes
Old May 25th, 2010, 08:49 PM   #155
Old May 26th, 2010, 12:23 AM   #156
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
Well actually the oxygenated racing fuels as ZTrack mentioned WILL increase horsepower all things being equal (oxygenated fuels increase O2 content), but as has been mentioned over and over and over again, octane has no correlation to power. And here in the Midwest since ethanol is so prevalent 89 octane fuel costs less then 87 octane (because ethanol is the additive used to raise octane in that case). That's the only reason why I use 89 octane whereas anywhere else in this country I'd use 87 ((RON+MON)/2).
VeX is offline   Reply With Quote
Old May 26th, 2010, 05:41 AM   #157
Flashmonkey
Every now and then you'll come across a pump with a separate nozzle for "premium" fuel....but for the most part Alex and Kelly are right.
Even rarer still is when you come across the old style pump...where you have to flip down the little thingy instead of pressing the buttons. I love seeing people struggle with those ones.
Old May 26th, 2010, 09:25 AM   #158
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
This?
Old May 26th, 2010, 09:37 AM   #159
Flashmonkey
^^Woah...that's even older than I was talking about. Stuff like that doesn't survive up here with our insane climate changes.
I was talking about these ones:
And even THOSE are pretty new....circa late 90's I'd say. Finding one of those around Toronto is like stumbling onto dinosaur bones
Old May 26th, 2010, 10:55 AM   #160
Neoki
Motorcycle(s): '09 Ninja 250R Black
87, cause thats what i was told
Neoki is offline   Reply With Quote
[topix.net] - Officials stunned as 94-year-old uses his funeral money to run for parl Ninjette Newsbot Motorcycling News 0 December 13th, 2012 08:40 AM
[topix.net] - Run with Nuns hits the streets to raise money for children Ninjette Newsbot Motorcycling News 0 October 23rd, 2011 06:40 PM
take the money and run.. greatwhiteninja Off-Topic 4 August 4th, 2011 01:49 PM
[crash.net - WSBK] - Haslam: We'll give twins run for their money Ninjette Newsbot Motorcycling News 0 April 8th, 2010 05:00 AM
[crash.net - WSBK] - Haslam: We'll the twins a run for their money! Ninjette Newsbot Motorcycling News 0 April 8th, 2010 03:30 AM
