Old November 30th, 2014, 12:39 AM   #1
MrAtom
MOTM - July '15
Doubling up on armor... Is this a bad idea?
I've lost a few pounds since I've bought my jacket, and now the armor is loose in it and it kinda moves around (New Icon Overlord Textile, if you're wondering). To remedy this, I've considered buying another set of armor to keep the armor pressed a little more firmly against my body, and to keep it from moving around. As a bonus, I'd have double armor. While I'd love to do this with D3O, I'm broke. So, I looked at the crappiest armor I could find: http://www.ebay.com/itm/301334080250 It says CE rated, but I'm skeptical. I wouldn't trust it by itself as much as my D3O (and even then, I take it with a grain of salt), but that combined with the D30 armor in the jacket should provide better protection than just D3O, right? I don't think this would be that bad of an idea, but I'm kind of a dumbass and could use all the second opinions I can get. Thanks for reading
Old November 30th, 2014, 01:25 AM   #2
maybe just put a big hoody on under it?
Old November 30th, 2014, 01:58 AM   #3
MrAtom
MOTM - July '15
I like that idea. I could do that until I gain weight again (vegan metabolism is a strange thing indeed). If summer rolls around and I'm still this thin, I'll try the armor thing. Unless someone else has a decent argument against it concerning safety.
Old November 30th, 2014, 06:08 AM   #4
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Gain more weight?
Seriously, if you can still move and you are comfortable I don't see why you can't. Unless, it puts you in an awkward position causing a safety issue.
Old November 30th, 2014, 12:21 PM   #5
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
I'd think the biggest issue would be range of motion. Armor is bulky and doesn't move with your body the way muscle/fat does.
Another big issue would be heat. You're adding a lot of insulation.
Simpler to just go get a jacket that fits.
Old November 30th, 2014, 12:29 PM   #6
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
^^^^ Hit the weight room!!!
Seriously though, more is not necessarily better than properly fitted safety gear. Also I don't think stacking armor would give a good enough fit to be as good as as single set properly fitted. Applying more padding underneath is a better interim solution in my opinion.
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old November 30th, 2014, 12:32 PM   #7
MrAtom
MOTM - July '15
Range of motion is definitely something to consider. Heat, I'm always freezing no matter what. And, while its simpler to get one that fits, the central driving factor behind this idea is that I'm broke. I think for $17, that crappy armor is worth a try.
Old November 30th, 2014, 02:41 PM   #8
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Also important is that the pads stay where they should: the elbow pads should not move around if you were to fall.
You could always cut piece(s) of foam to put between the pad and the jacket.
Old November 30th, 2014, 04:17 PM   #9
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
In some cases, yes. Having two back protectors in my leather jacket just possibly saved me from a much worse broken back.
I've said many many times since November 8 how glad I am I had on 2 back protectors that day.
Postwhores are COOL! ~Allyson
Old November 30th, 2014, 05:14 PM   #10
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
highly depends on comfort and mobility if that is a good idea or not.
TEAM ALFALFA
www.apexassassins.com
Old November 30th, 2014, 05:28 PM   #11
I've heard that the second one can cause enough friction to ruin both...
Old November 30th, 2014, 05:59 PM   #12
MrAtom
MOTM - July '15
How?
Old December 1st, 2014, 03:32 PM   #13
Old December 1st, 2014, 05:42 PM   #14
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
That's condoms dodo
Last futzed with by JohnnyBravo; December 1st, 2014 at 05:43 PM. Reason: Stupid work makin me tardy to the party :(
Old December 1st, 2014, 05:43 PM   #15
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
only use 2 bags when she is ugly, and avoid plastic.
TEAM ALFALFA
Old December 1st, 2014, 05:46 PM   #16
JohnnyBravo
I wondered who was gonna bring up that double bagger too
[visordown.com] - Why looking sideways at 140mph is a bad idea Ninjette Newsbot Motorcycling News 0 May 1st, 2014 03:00 AM
K&N air filter=Bad idea Gmtec2 1986 - 2007 Ninja 250R Tech Talk 24 April 15th, 2013 07:51 PM
Probably a bad idea, but... bagtf3 1986 - 2007 Ninja 250R Tech Talk 3 March 3rd, 2013 07:25 PM
Running ninjette with no muffler, bad idea?? venmichaels 2008 - 2012 Ninja 250R Tech Talk 18 October 13th, 2011 04:07 PM
Tell me why this is a bad idea DBentley415 General Motorcycling Discussion 13 February 19th, 2011 09:00 PM
