July 4th, 2011, 08:43 AM | #81 | |
July 4th, 2011, 12:50 PM | #82 | |
Got any links to ones for sale? |
July 4th, 2011, 12:56 PM | #83 |
To protect your motorcycle against the elements I suggest:
Last futzed with by ducducgooseit; July 4th, 2011 at 02:33 PM. |
July 4th, 2011, 02:33 PM | #84 |
I use a 1/2 cover at work. No melting problems as it doesn't touch the pipe....
The best thing though, is I can roll it up tight enough to fit in the rear seat cowl
July 4th, 2011, 02:47 PM | #85 |
For me, at home isn't a problem because my bike has a spot in the garage. I know other guys that get their bikes under cover one way or another including putting it in the living room.
A lot of stores around here allow bikers to park under the covered porches directly in front of the store, but unfortunately, many do not and I end up in the main parking lot with no shade. That's when a little mini-cover would be nice. |
July 4th, 2011, 03:34 PM | #87 |
Ok. So. I'll try to be helpful. My Google search of CoverMax Motorcycle Half Covers came up with:
Is that helpful? |
July 4th, 2011, 03:44 PM | #88 |
Any products good for refreshing plastic parts with UV damage (like the stock blinkers)? I found a rag with a light coat of WD40 is better than nothing, but think there has to be a better solution.....
July 4th, 2011, 04:11 PM | #89 |
Light UV damage? If you have a power drill, time, and some spare cash go to Autozone or Pepboys and get either a Meguiar's or Mother's Headlight Restoration kit. Follow instructions and your clear plastic will be in far better shape. WD-40 helps only very temporarily because the lubricate fills the UV damaged voids. When the WD-40 completely dries the UV damaged surface will still be in place and the clear will not be as transparent as the restoration kits would have achieved.
Note that the polishing the lens does remove some of the lens - not much - but some. Its useful only 3 or 4 times on the same lens. There are some other products that can clean and return to excellent condition clear acrylic or poly-plastics but they cost more than a new lens cover would and the correct application is a matter of practice. |
July 4th, 2011, 04:18 PM | #90 |
If you are going to try to remove UV damage from high gloss or very smooth plastic that is not clear, try Meguiar's #17 and Meguiar's #10 in that order. Each must be applied with a very clean cloth - I recommend 100% cotton - and each must be completely polished off. Elbow grease is required for #17 to do its job.
These will polish the UV damage away. If the original surface is matte do not use these - they will remove the damage AND remove the matte surface treatment of the plastic. |
July 4th, 2011, 04:26 PM | #91 |
I was only talking about the black plastic housings, but that is good info to have, because the clear plastic inevitably will start to go at some point too.
July 4th, 2011, 05:19 PM | #92 | |
July 4th, 2011, 05:31 PM | #93 |
Norwegian dude
Join Date: Aug 2010 Motorcycle(s): Ducati 748 Posts: 120
I have the original Kawasaki outdoor cover in silver, don't have a pic of it, but here is the pic from their site, you get the picture
July 17th, 2011, 06:02 PM | #94 |
Join Date: Jan 2009 Motorcycle(s): 2011 black ninja 250r Posts: 67
Got a Paul Jr Designs(American Chopper) waterproof cover at walmart for $39.99 fits perfect .
July 18th, 2011, 05:17 PM | #95 |
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R SE (Green) Previous bikes R1, Daytona 675, GSXR600, Pre-Gen 250R Posts: 330
In the garage with my wife's queen sized silk sheet over her.
August 4th, 2011, 07:42 PM | #96 |
Join Date: May 2011 Motorcycle(s): 2010 Red Ninja 250r Posts: 69
Best motorcycle cover for 2010 250r
Hey guys. Looking for another cover for my bike since I lost mine and would like to see what the best cover out there would be for my bike for the best value. I am also thinking that I want something that will also be fine for the winter as well, and shouldn't be that much different since it will be in a shed during the winter. It will be outside though under the cover so I'd like a good cover for a good price.
I had the one from coverace and it was nice but started to fade and let small amounts of water through after a while and that kind of defeats the purpose of having a cover I'd say. Do you guys have any recommendations for me? Can you please include links as well. Thanks! |
August 4th, 2011, 08:09 PM | #97 |
n00b
Join Date: Jul 2011 Motorcycle(s): Blue 2010 Ninja 250 Posts: 581
I bought the "Trackside" deluxe cover from cycle gear, it was like 70 bucks I think after the military discount and it has worked great. I park the car under a car cover but the sprinklers hit it from the side sometimes and the cover has worked perfectly at keeping the water away. It's pretty form fitting, has a hole to prevent condensation from forming, and it has a strap at the bottom to tighten it up and lock it shut with a cable lock. Good cover I'd say, a lil pricey, but it was the only one I could find that had what I needed...waterproof, tough, lockable, and form fitting
August 4th, 2011, 09:08 PM | #98 |
I use a nelson rigg deluxe all season cover. I like it. Feels pretty sturdy and fits nicely so that the wind wont blow it off. I think the size I have is a medium but i'm not 100% sure.
http://www.motorcycle-superstore.com...son-Cover.aspx |
November 20th, 2011, 07:27 PM | #99 |
Join Date: Oct 2011 Motorcycle(s): 2007 EX250F Posts: 70
Storage covers
Been thinking of getting one for my bike while it was in storage, I don't know too much about them and unfortunately every time I try googling "bike cover" I get a bunch of results about covers for all the mechanical bits and pieces.
So I'm just curious, do you guys even bother coverings your bikes? Are those 1 size fits all covers good enough or does somebody make a cover specifically for the EX250 that works better? Any particular one you guys would recommend? Thanks! |
November 20th, 2011, 07:40 PM | #100 |
/merged a few "motorcycle cover" threads into a one more mongo one. There should be a whole bunch of pics and links within this thread to give folks ideas on covers.
November 20th, 2011, 07:47 PM | #101 |
March 28th, 2012, 03:08 PM | #102 |
UPDATE: The Bilt motorcycle covers did not last a year outside. The sun and rain had faded the fabric to where it was brittle and easily torn. I patched up the tears with tape and it's still holding up for the most part.
March 28th, 2012, 04:38 PM | #103 |
Join Date: Aug 2010 Motorcycle(s): 2013 Ninja 300 ABS Posts: 270
I have the limited edition Ultra Gard breast cancer pink/charcoal bike cover. It has the breast cancer ribbon on the bottom.
Size: Medium Price: $39.99 I've had it boxed up for a while and finally it started raining pretty hard here in L.A. I took it out of the box and It's held up pretty well against the rain and wind.
"You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck." |
March 29th, 2012, 10:35 PM | #104 |
Join Date: Oct 2011 Motorcycle(s): 2009 CBR600rr Posts: A lot.
Awesome Bike Cover... for $12
Pick it up at your local Walmart for about $12. It's quite thick, it's weatherproof, and the entire inside is lined with a soft material. You'd be hard pressed to find a 'motorcycle' cover that's this thick and weatherproof for less than $50, and it'll probably only have a soft lining by the windscreen. Walmart has 65" ones for slightly cheaper, but they are thin, flimsy and not nearly as good as this 68" one. Make sure you grab the 68" pictured. Here are the pics of the cover on my bike: Here is a picture of the inside soft lining. The entire cover is lined with this, not just certain sections: Last futzed with by saxnbass; March 30th, 2012 at 09:30 AM. |
March 29th, 2012, 10:36 PM | #105 |
interesting theory. I'm interested in how well it attaches and how well it holds up
March 29th, 2012, 10:47 PM | #107 |
Snug enough to handle NW Ohio winds?
March 29th, 2012, 11:01 PM | #108 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
Good of you to share this bro...I'll definitely look into it. My current cover, albeit advertised as 'water proof', gets soaked through and through. Only thing it has going for it is a hook that you can pass through a hole in the cover making it extremely secure. Anyway, thanks again, I'll see how this'll hold up.
March 29th, 2012, 11:01 PM | #109 |
Chris, I'll let you decide that when I post pics tomorrow.
Alex, it's very nice. You'll see by the pics tomorrow. Water on this thing just beads up and rolls off. Someone else who uses this to cover their bike said it rained for 2 days and the bike underneath was completely dry. |
March 30th, 2012, 05:05 AM | #110 |
Looks worth a try.. hell I already spent $20 on a MC cover, that is very thin and wouldn't hold up to more than a sprinkle for it's 'waterproofing' Plus it's so loose at bottom it lets way too much air in.. a few times it almost blew off, it's 1 little hook barely keeps it on.
March 30th, 2012, 05:17 AM | #111 |
Looks like a good find - thanks.
March 30th, 2012, 05:43 AM | #112 |
Heat resistant? Most people are in no hurry to cover their grill, so it doesn't really have to have it.
Most motorcycle cover brands offer e "dust cover" and a "deluxe cover" with heat resistance as the main distinguishing difference. |
March 30th, 2012, 06:06 AM | #113 |
subb'd for pics.
People will probably be wondering what kind of grill has two giant wheels.
March 30th, 2012, 06:42 AM | #114 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
That's thinking outside the box ! Nice tip
March 30th, 2012, 07:09 AM | #115 |
Name: I'm a ninja!
Join Date: Jul 2011 Motorcycle(s): 2009 Ninja 250 Posts: 453
HAHA that is pretty smart thinking!! I bought a cheap one for $15 including shipping off of ebay last year and I've never had problems with rain coming through it. It was just a generic gray bike cover. For the little hole on the bottom of the cover, I use yarn to tie the two ends together. It has worked fine for the 30mph gusts of wind we have had this past Jan. I will definitely recommend that to my friends and if I need another one I will look into it myself. Nice find saxnbass!!
March 30th, 2012, 09:32 AM | #117 |
When I covered the bike last night, I got home after about a 50 mile ride, so the bike was toasty hot. I went inside, got out of my riding gear, put the dog on a leash, grabbed the cover and went outside to cover it up. It was parked for all of about 5, maybe 10 minutes before I threw the cover on it. No damage or anything to the cover. The picture of the inside lining is actually the part that covers the exhaust, as you can see it's just fine.
March 30th, 2012, 10:50 AM | #118 |
How well do the velcro strips keep it tied down?
March 30th, 2012, 11:14 AM | #119 |
Name: I'm a ninja!
that actually is funny looking since it doesn't go all the way down and hide the wheels. If it works well then it would be worth it.
March 30th, 2012, 11:30 AM | #120 |
I didn't use the velcro straps as it fits my bike pretty nicely as is, but I did use them just to see. It brings the bottom up a bit more so more of the wheel is exposed, but it does tighten up the front and back very snuggly; I can't see it going anywhere with it tightened up like that.
About it not hiding the wheels all the way, not sure why that'd be a big deal anyways. Plus, for $12, I really can't complain in any way. I'd have to spend $75+ to get a comparable motorcycle specific cover, IMO. |
Tire recommendation. | Gregg_VA | 2008 - 2012 Ninja 250R Tech Talk | 26 | January 17th, 2014 01:47 PM |
dealership recommendation on parts | t0sh | 1986 - 2007 Ninja 250R Tech Talk | 11 | June 18th, 2013 07:43 AM |
Glove recommendation | hirubhaiambani | Motorcycle Gear | 11 | August 28th, 2012 04:52 PM |
need recommendation on feeler gauges | CThunder-blue | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 6th, 2011 11:27 AM |
Why is Kawi's break in recommendation... | wild-bill | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 8th, 2010 06:44 AM |
