Old February 21st, 2016, 07:01 PM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
Ripped a hole in frame while removing kickstand mount
How screwed am i? From what I can tell all of the welds behind the frame are intact, the area doesn't feel weakened at all. Can I leave it? Slap a small piece of angle iron and JB weld? Get small piece of metal welded over top?
daverdfw is offline   Reply With Quote
Old February 21st, 2016, 07:04 PM   #2
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Never seen that... lol
I'd get it welded up properly. Call it a day after lol
Old February 21st, 2016, 07:07 PM   #3
daverdfw
my guess Is i should have cut just a tad lower, I got it right on the weld, just bad positioning on my part.
Old February 21st, 2016, 07:09 PM   #4
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Please, for the love of all that is holy, do NOT JB weld that. JB weld is for small holes and I won't even use it for that. There are much better putty's on the market.
Call a buddy with a welder or find a shop with a welder and have a piece welded in there and painted. Properly done, it will be strong and just fine.
Goin' fast on slow bikes!
Old February 21st, 2016, 07:10 PM   #5
daverdfw
the JB weld was kinda a joke
Old February 21st, 2016, 07:12 PM   #6
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Wellll......I had hoped so but past experience has taught me to never assume......
I've had people seriously consider that as an option.
Old February 21st, 2016, 07:15 PM   #7
daverdfw
I just sent an email to a local shop. Hoping they can fix it. I dont think its a major issue but wanna get it done right. Track day is in 2 weeks
Old February 21st, 2016, 07:17 PM   #8
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
It's not a hugely structural part of the frame....that said, there's nothing better than having it done right. Good on ya!
The biggest issue I see with that is now the inside of the frame, that is not painted, is exposed to water and other nasties that could cause internal rust you can't see.
Old February 21st, 2016, 07:18 PM   #9
daverdfw
there is actually a small hole already drilled toward the back of that area. It must be a drain hole.
I will see what I get quoted to weld it. I can always find a way to kinda cover it to protect it.
Old February 21st, 2016, 07:21 PM   #10
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Well, whaddaya know! I'm gonna have to go check mine now. I never noticed a hole there before.
Old February 21st, 2016, 07:21 PM   #11
daverdfw
let me try and get a pic for ya hang on
Old February 21st, 2016, 07:24 PM   #12
daverdfw
Old February 21st, 2016, 07:25 PM   #13
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I think you're spot on that's a drain hole.
Never noticed it before.
Old February 21st, 2016, 07:31 PM   #14
daverdfw
the entire area is still welded solid. I tried to tap it to see if it was weakened but I didnt notice anything obvious.
Old February 22nd, 2016, 11:49 AM   #15
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Have a welder grind it down nicely and weld a plate onto it! It can be done, trust me!
Old February 22nd, 2016, 12:00 PM   #16
HoneyBadgerRy
HoneyBadgerRy's Avatar
I saw someone cut a peice of popcan, rivet it to the top of their piston, and shmear some JB weld on it for good measure... And then it worked.
Old February 22nd, 2016, 12:38 PM   #17
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Define "worked".
Old February 22nd, 2016, 12:45 PM   #18
HoneyBadgerRy
Define "worked".
The engine ran until he sold it.
Old February 22nd, 2016, 12:58 PM   #19
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
I was just looking at how I was going to remove the bracket yesterday and I was thinking about how I don't want to leave any unneeded material.
If I get too enthusiastic with the cutoff wheel, I fortunately have a TIG welder sitting about 6 feet away!
tgold is offline   Reply With Quote
Old February 22nd, 2016, 02:32 PM   #20
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I don't.....I'm not....my brain hurts.
Old February 22nd, 2016, 05:47 PM   #21
daverdfw
I started cutting where you can see the line of the bend on the bracket, do it lower that I did to avoid this. If i went like 1/4 inch lower I would have missed the weld. Just bad luck/ inexperience on my part. Waiting for a quote from local bike shop to get this thing fixed. I think I could ride it anyway, but no reason to halfass it. It shouldnt be a lot to fix that small of a hole.
Old February 22nd, 2016, 06:11 PM   #22
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Come by my house, I will weld that **** up for free.
My Cafe Racer Build
My intro post
Old February 22nd, 2016, 06:11 PM   #23
daverdfw
you are a bit of a drive from TX !
Old February 22nd, 2016, 06:12 PM   #24
crazymadbastard
Sometimes free is not so cheap.
My Cafe Racer Build
My intro post
Old February 23rd, 2016, 11:02 AM   #25
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
Remind me never to buy anything from you (guilt by association).
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old February 23rd, 2016, 11:10 AM   #26
HoneyBadgerRy
I had no part in it, told him not to try it, and would have no part in scamming someone ever. When I sell something, I make sure that the buyer knows exactly what they are buying. Sleeping at night is worth more than the few thousand dollars I can make by selling people junk.
Old February 23rd, 2016, 12:29 PM   #27
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Drill some holes above the cut and below the cut and zip tie it up. It provides strength but also flexibility.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old February 24th, 2016, 08:21 PM   #28
daverdfw
really??
Old February 25th, 2016, 12:07 AM   #29
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
looks like you need a new chain, and lube it more often.
TEAM ALFALFA
www.apexassassins.com
Old February 25th, 2016, 05:08 AM   #30
Yamahawk
Chaplain
Yamahawk's Avatar
Motorcycle(s): 75 RD350 race bike, 82 XZ550RJ Vision, 81 XV920RH, 89 VTR250 Interceptor race bike, 06 Concours, 86 EX250E1
I would find someone you know with a MIG welder. It would be a five minute fix with a MIG welder to seal that small of area, without adding ANY plate or extra metal Keep laying small horizontal beads, top and bottom until they meet and you're done. Just my 2 cents... Being a retired pipe welder...
God chose what the world thinks foolish to shame the wise,what the world thinks as weak to shame the strong,what is despised in the world,what is nothing,to set aside what is regarded as something
Yamahawk is offline   Reply With Quote
Old February 25th, 2016, 11:05 AM   #31
Trailerboy531
really??
"Nobody ever lies on the internet" - Abraham Lincoln
CVMA #531
Old February 25th, 2016, 11:09 AM   #32
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Some times it's just easy to fall asleep:
Spoiler for topic:
It might just be the [you] tag
Old February 25th, 2016, 11:17 AM   #33
daverdfw
yeah i bought this bike in November and the bike sat outside. I think the chain isnt too old 3500 miles. I will try and clean it and see if I can get it back in better shape.
Old February 25th, 2016, 11:51 AM   #34
To repair that area, I would use a wire brush to remove the paint and clean the area, then make a patch from similar gauge sheetmetal, then MIG weld it in place.
You could possibly run numerous beads (as suggested) to close it up, but I'd probably make a patch myself. You could also gas weld it if you didn't have access to a MIG, but I would definitely close it up.
Old February 25th, 2016, 12:07 PM   #35
daverdfw
I found a shop I am going to take it to and get it looked it. I don't wanna half-ass it
Old February 25th, 2016, 12:28 PM   #36
Yamahawk
Chaplain
Yamahawk's Avatar
... fix it slow, or fix it fast... but never fix it half-fast :O
the fellow above that recommended a patch is correct, as you do need to clean and wire brush the area for any weld to be sound. It doesn't look like the area is even an inch wide, so however you decide to have it fixed, it would be worth doing it right.
Old February 26th, 2016, 12:27 PM   #37
daverdfw
Took it to the shop today, mechanic told me I can ride it fine, but should get it welded. Will schedule to get it welded after track day next weekend. Will post up pics after its done.
Old February 27th, 2016, 12:12 PM   #38
crazymadbastard
i lolz
My Cafe Racer Build
My intro post
Old February 27th, 2016, 12:13 PM   #39
crazymadbastard
go to a muffler shop they can weld it cheap.
My Cafe Racer Build
My intro post
Does this kickstand mount look guilty ock1 !%@*#$%!)@#&!%@ I crashed! 2 October 23rd, 2012 11:42 PM
Relocating or modifying the kickstand mount? StevieMac Ninjettes At Speed 3 August 4th, 2012 01:11 AM
How many racers have cut off the 2008+ kickstand mount? samw Ninjettes At Speed 39 April 2nd, 2012 06:05 AM
