Old September 19th, 2016, 10:21 AM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
K&N Air Filter Installation
It seems pretty straightforward, but any tips on how to get the original brackets out of the airbox? Directions say to break them, but there's really not a lot of room to get a lot of torque built up to snap them in half.
I'm thinking about using a Dremel and sticking a rag down in the airbox to cover up the carb intakes. Any suggestions?
Cra1g is offline   Reply With Quote
Old September 19th, 2016, 12:02 PM   #2
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
wat. No breaking required when I put my filter in... Just fit right where the OEM one was.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old September 19th, 2016, 12:21 PM   #3
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Is yours a Pre Gen though? They have different airboxes.....
Goin' fast on slow bikes!
Old September 19th, 2016, 12:40 PM   #4
Ghostt
Ghostt's Avatar
The best bet is to remove the airbox, it's work, but worth it in the long run, don't want to leave any small pieces that might get sucked in, etc....
violente et ignorantia
ZX-2R BLOG
Old September 21st, 2016, 07:49 AM   #5
Cra1g
Cra1g's Avatar
Alright, I installed the new filter. Was a little snug getting in the airbox and was a bear trying to remove it, but I guess that's aftermarket for ya ¯\_(ツ)_/¯
Anyway, I ended up bending the air filter ever so slightly while trying to fit it over the snorkels, since that was a bit of a bear as well. Will that be an issue?
Old September 21st, 2016, 04:51 PM   #6
Ghostt
Ghostt's Avatar
As long as the filter doesn't have a hole, or a bad bend I wouldn't worry about it, helps to use some lube on the filter/snorkel to allow it to slide on easier.
ZX-2R BLOG
Old September 21st, 2016, 05:12 PM   #7
Cra1g
Cra1g's Avatar
Just has a couple of kinks in it. Thanks for the lube tip--can't believe I didn't think of that.
Old September 23rd, 2016, 03:30 PM   #8
Trailerboy531
Your poor girlfriend..
CVMA #531
Old September 23rd, 2016, 06:52 PM   #9
Ghostt
Ghostt's Avatar
ZX-2R BLOG
Ninja 300 K&N Air Filter How To Install Tutorial & Quick Review Video SON1C 2013 - 2017 Ninja 300 Tech Talk 12 June 27th, 2014 07:15 PM
K&N air filter to stock air box Graugaard 2008 - 2012 Ninja 250R Tech Talk 29 July 28th, 2012 06:33 AM
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su Ninjette Newsbot Motorcycling News 0 June 11th, 2012 06:00 PM
Anyone have a K&N Air Filter? Machine1 2008 - 2012 Ninja 250R Tech Talk 6 June 6th, 2012 02:09 PM
