Old December 14th, 2017, 06:42 PM   #1
EffaMoulton
EffaMoulton's Avatar
Motorcycle(s): 2010 Ninja 250r SE
Looking for cheap farkle suggestions!
I would like some cheap ($50) “farkle” suggestions for my bike, thanks in advance!
File Type: jpg 7F34873F-79E2-43EA-B2CD-247879912B57.jpg (143.0 KB, 9 views)
EffaMoulton is offline   Reply With Quote
Old December 14th, 2017, 07:16 PM   #2
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
https://www.ninjette.org/forums/showthread.php?t=300352
https://www.ninjette.org/forums/showthread.php?t=301683
https://www.ninjette.org/forums/showthread.php?t=298242
"trying not to get old"
Old December 14th, 2017, 07:30 PM   #3
EffaMoulton
Thanks, if I did get the cheap slip-on do you think I’d HAVE to rejet my bike so it didn’t run too lean or do you think I’d be fine?
Old December 14th, 2017, 08:35 PM   #4
You don't HAVE to, but it would be helpful as these bikes are lean from the factory. Since you will have a bit of budget let from your $50 after the slip on, perhaps a few shims on your carb needles will richen it up a bit for you along with other benefits.
Grand total for 4 shims (small washers)... $0.36
Old December 14th, 2017, 09:03 PM   #5
The factory jetting on a newgen bike is both too lean AND too rich. Lean in low/mid-range and rich in high-end. Easiest to address each range individually:
1. idle & low-end - unscrew pilot-screws 1/4-1/2 turn more than factory setting
2. midrange - shim needles 1-4mm, 1mm at a time. This is the variable depending upon which slip-on you get.
3. high-end - get smaller main jet, two sizes down if you have factory exhaust. One size down with aftermarket exhaust
I've got 20% more high-end power than stock on my 2008. AFR is spot-on at 13.5:1 for maximum power in high-end (compared to stock 11.5-12.0:1). To do that, I went down to slightly smaller main jet with Tyga full-exhaust. Or just leave factory main-jet alone for 13.0:1 AFR in high-end. This is real tried and true mods done by pretty much all racers on newgens. I can dig out dyno-charts and magazine-articles that showed this is path to enlightenment.
EDIT - > REFERENCES
Racing on the Cheap - scroll down to "The Nuts and Bolts" section, note: "close to perfect" is with full AreaP exhaust and factory jetting.
Racing Order - Dyno testing
Dyno testing - lean mid-range only - thinned needle to correct.
Last futzed with by DannoXYZ; December 15th, 2017 at 03:56 PM.
Old December 15th, 2017, 03:13 AM   #6
maverick9611
MOTM - Feb '18
i have free uni filter for airbox. you just pay shipping
Old December 15th, 2017, 03:18 AM   #7
maverick9611
MOTM - Feb '18
https://www.ninjette.org/forums/showthread.php?t=307345.
this over your $50 budget but you a northerner.
Old December 15th, 2017, 03:33 AM   #8
maverick9611
MOTM - Feb '18
https://www.ninjette.org/forums/showthread.php?t=307767
Old December 15th, 2017, 03:53 AM   #9
maverick9611
MOTM - Feb '18
https://www.aliexpress.com/item/Blac...StoreLevelAB=0
Old December 15th, 2017, 06:05 AM   #10
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Originally Posted by maverick9611 View Post
this site offers a large selection of farkles, takes about 3-4 weeks to get them. I picked up: Levers, Pre-drilled oil cap, pre-load adjusters, and a pre-drilled oil drain bolt. all ~ $52.
TEAM ALFALFA
www.apexassassins.com
Old December 15th, 2017, 07:17 AM   #11
How about some rear spools? I have about 4 different sets in different colours. Kinda like earrings!
Last futzed with by DannoXYZ; December 15th, 2017 at 08:37 AM.
Old December 15th, 2017, 09:33 AM   #12
redonninrf
Motorcycle(s): 2008 Ninja 250R, 2017 Triumph Thruxton 1200 Classic (not the 'R')
Rowan & Martin had a whole family of Farkles but they might take offense at being called cheap.
redonninrf is offline   Reply With Quote
Old December 15th, 2017, 10:36 AM   #13
EffaMoulton
Thanks for the info!
Old December 15th, 2017, 10:38 AM   #14
EffaMoulton
EDIT - > REFERENCES
Thanks for the detail, I’ll have to do a little bit more research before I tackle the carbs.
Old December 15th, 2017, 03:49 PM   #15
How about some colourful brake levers?
Old December 15th, 2017, 04:42 PM   #16
EffaMoulton
Good idea, maybe I’ll paint mine! Off topic of farkles but I’m probably going to be making my own rear stand, anyone want to see the processe?
Old December 15th, 2017, 05:30 PM   #17
Yeah, I may be building some stands too.
Old December 15th, 2017, 11:49 PM   #18
Kevin1956
Kevin1956's Avatar
The best fifty buck farkle you can buy is a small tank bag such as one of the Joe Rocket Manta models.
Kevin1956 is offline   Reply With Quote
Old December 16th, 2017, 02:58 AM   #19
maverick9611
MOTM - Feb '18
i got is this one but it's $67.99
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old December 18th, 2017, 09:13 AM   #20
EffaMoulton
I think I’m going to buy some green metallic spray paint and paint my clutch and brake levers. Anything else a should paint, that wouldn’t look stupid?
Old December 18th, 2017, 05:44 PM   #21
Wheels
Swingarm
Old December 18th, 2017, 06:09 PM   #22
EffaMoulton
Wheels
Swingarm
Might try painting the wheels... thanks for the suggestion.
Old December 18th, 2017, 06:38 PM   #23
Maybe green swingarm and white wheels?
Old December 18th, 2017, 07:00 PM   #24
EffaMoulton
Depends on how bored I get this winter haha.
Old April 16th, 2018, 09:42 AM   #25
t-cab12
Needs a riding buddy.
Motorcycle(s): 2008 Ninja 250, 1986 Honda Elite 80
any paint updates? pics of anything?
Don't hide 'em. Ride 'em.
t-cab12 is offline   Reply With Quote
Old April 16th, 2018, 12:36 PM   #26
maverick9611
MOTM - Feb '18
look in new gen farks, i have tons of stuff. latest is rear hugger.
my farkle mrbanksta23 1986 - 2007 Ninja 250R Farkles 19 February 24th, 2014 11:48 PM
farkle? what is that alex.s 2008 - 2012 Ninja 250R Farkles 6 November 28th, 2012 02:02 PM
Time for me to Farkle! What to do? SSG54 2008 - 2012 Ninja 250R Farkles 17 October 24th, 2012 03:04 PM
Farkle sites??? ninjette250 2008 - 2012 Ninja 250R Farkles 2 May 5th, 2011 11:31 AM
