Old November 20th, 2018, 03:50 PM   #1
Kennylxix
Motorcycle(s): 92 Ninja 250
08+ Clutch Swap Complete
Just finished swapping the newer style clutch into my 93. This was done to correct the clackety clack noise from degraded cushion bushing things in the old clutch.
Swap was a complete bolt in. The trick I think is to get every single piece between (but not necessarily including ) the washer that sits between the basket and the input shaft bearing and the actuator arm that sits in the clutch cover. This includes needing the newer push rod.
There are a ton of little differences between the two clutches but I don't think anything was changed between the two model as far as the engine case or clutch cover are concerned.
I saw reports of needing to make a spacer to get the clutch to fully disengage but didn't run into that. I think the people experiencing that issue may have been using the old push (actually pull) rod. The original is a bit longer than the new one and would cause problems with actuation.
To recap all I did was swap the entire assembly between the input bearing washer and the clutch cover cam arm thing. Everything aligned perfectly and the clutch is smooth and quiet.
Of course your experience may be different.
Kennylxix is offline   Reply With Quote
Old November 20th, 2018, 03:51 PM   #2
Kennylxix
Oh I also found a bunch of the old bushing material in my oil strainer so it's definitely a good idea to get in there and clean it out.
Old November 20th, 2018, 04:12 PM   #3
Ceeloo Yello
Motorcycle(s): 250
Congrats buddy.
Old November 20th, 2018, 05:25 PM   #4
Kennylxix
Thanks! I also wanted to mention that my clutch feel was and still is really wierd with engagement happening at the very end of lever travel and not very smoothly. (Yes everything is lubricated and adjusted)
Turns out that the little "fingers" on the actuator cam lever thing are really badly worn where they contact the puller rod. This is causing the feel to be really weird and engagement to not be right. I already ordered a replacement.
Old December 3rd, 2018, 02:41 PM   #5
Ceeloo Yello
Motorcycle(s): 250
So the clutch arm just pushes into the clutch cover? No retaining clip or anything?
Old December 3rd, 2018, 02:46 PM   #6
Kennylxix
Correct. The puller rod itself holds the clutch cam arm thing in.
I actually replaced my worn one without taking the cover off. I just disconnected the clutch cable, rotated the arm counter clockwise until it disengaged with the puller rod then pulled it straight out. The replacement went right in and reengaged with the rod (im sure it's possible for the rod to get out of alignment after removing the cam arm piece but it worked fine for me.
Old December 3rd, 2018, 03:39 PM   #7
greg737
Motorcycle(s): -
Great project report! Thanks for returning to post your thoughts on the experience.
As I mentioned on your earlier forum thread I'm going to do this mod in late December or early January, hoping my swap goes as well as yours did.
I've got the parts standing by, waiting for the busy holiday season to end.
Old December 3rd, 2018, 03:45 PM   #8
Kennylxix
Yeah as long as you get every single piece between the washer behind the clutch and the clutch arm you should be fine.
Old December 3rd, 2018, 04:15 PM   #9
Ceeloo Yello
Motorcycle(s): 250
Thanx, me three gonna try this getting most of the parts from ebay.
Old December 4th, 2018, 02:50 PM   #10
Ceeloo Yello
Motorcycle(s): 250
Oh and did you need to use any special tools like the clutch tool to hold the basket while undoing the nut?
Old December 18th, 2018, 10:08 PM   #11
Kennylxix
Sorry just saw this. No. I used my impact wrench to both remove and reinstall the nut. I don't recommend using an impact to install the nut. I'm a mechanic with a pretty good feel for these kinds of things and only used the impact because it's my own bike. If it had been a customers I would have bought the correct tool.
The basket holder tool isn't too expensive and is definitely the correct way to remove.and reinstall the nut.
Old December 18th, 2018, 10:35 PM   #12
greg737
Motorcycle(s): -
I was planning to put together a (slightly better) version of the make-it-yourself clutch basket holder demonstrated in this youtube video:
https://www.youtube.com/watch?v=gQVhscwyGZs
Old December 19th, 2018, 01:35 PM   #13
Ceeloo Yello
Motorcycle(s): 250
Thanks Ken and Greg, seems to be a shortage of clutch baskets on ebay at the moment
Old December 19th, 2018, 04:04 PM   #14
Kennylxix
Seems like a reasonable way to make a tool.
Ceeloo - I'm sure more will show up
Old June 11th, 2020, 02:22 PM   #15
Ceeloo Yello
Motorcycle(s): 250
Amazing how much used clutch baskets are going for on ebay now.
