Old November 28th, 2018, 02:33 PM   #1
Alex Wagner
Motorcycle(s): ninja 300
Sprocket ratio
Hey wanted to ask how do you all feel about changing the front sprocket to 13t (instead of 14t) or changing the rear sprocket to 46t (instead of 42t).
I want to change it to gain more toque for the track because i don't really get to the top speed at the track and i feel that i need more power coming out of turns/corners.
I would like to hear some recommendations about the subject .
Thanks :"D
Alex Wagner is offline   Reply With Quote
Old November 28th, 2018, 03:22 PM   #2
Plug your info into the calculator here - https://www.gearingcommander.com/ - and you will see the effect of gearing changes.
Old November 28th, 2018, 03:55 PM   #3
jrshooter
could not break 100 mph in stock gearing, on our front straight.
added teeth to the rear and now 100 is doable
Old November 29th, 2018, 06:16 AM   #4
I've found that at the track, the shift points are as important as the overall ratio. Whatever you do, avoid things like having to shift mid-turn, for example.
Old November 29th, 2018, 01:26 PM   #5
yeah, I lowered gear-ratios slightly compared to stock and added +22% more power in order to redline top-gear at track ~105mph
13.5:1 compression ratio kits Swann 2008 - 2012 Ninja 250R Tech Talk 46 October 9th, 2020 04:43 PM
crash to injury ratio alex.s !%@*#$%!)@#&!%@ I crashed! 55 January 19th, 2014 09:59 AM
Gear Ratio illrational 2008 - 2012 Ninja 250R Tech Talk 2 August 19th, 2010 09:47 AM
