Old January 2nd, 2019, 09:26 AM   #1
Guaire
Air Box Mod
A friend of mine told me about his air box on the EX250. It makes removing and installing the carbs, much easier.
https://www.youtube.com/watch?v=iP56OJg6M4I&t=51s
Cheers,
Bill
Old January 2nd, 2019, 12:31 PM   #2
Cool idea!
Hmmm, maybe I should make video. I can get carbs on & off without any problems on both pre-gen and new-gen bikes...
Old January 2nd, 2019, 12:40 PM   #3
ducatiman
ducatiman's Avatar
IMHO...a good mod, non-invasive (provided you don't bastardize the integrity of the airbox itself) invisible and only you know whats been done and why its been done.
I did similar to my older, carbed Ducati..carbs out 5-10 minutes tops....no longer requiring battery and some ignition components to be disturbed.
On your 250's...I'd submit to go for it!
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old January 2nd, 2019, 01:12 PM   #4
Guaire
Here's the vid from the man who told me about the mod. He has an extensive library on his channel.
https://www.youtube.com/watch?v=s86bimD4ft0
Every manual shows how to pull the carbs. I like this as it just makes it easier.
I bought this '04 after it was left outside, a non runner. I removed most of the tupperware, seat, tank, air box, battery box and I had both halves of the rear fender off. My buddy came by to drop off tires, when he told me how to mod the box. If I didn't have so much of the bike apart, I might have thought about it, but it was too easy to not make carb work easier.
Bill
Old January 2nd, 2019, 01:40 PM   #5
ducatiman
ducatiman's Avatar
@Guaire would you share your experience with your Enfield Continental?
Reliable? Ease of service? Parts availability? Handling? Power? Any issues?
You know, the usual stuff.....if you don't want to go off topic on your thread...perhaps via forum PM. Either way you choose.
Thanks, Gordon
Custom Carb Service
Old January 2nd, 2019, 02:34 PM   #6
Guaire
DucatiMan - Glad you liked my little vid on the 250 air box.
I overhauled the carbs myself. If I knew how you could work them over, I might have not bothered with them myself. I just checked your links. Hopefully, they'll be ok.
Did you see the RE Continental GT in the background of the air box vid? Here's a GT air box mod,
https://www.youtube.com/watch?v=RAUPA27HeUk&t=80s
Here's what I just wrote in the forum classicmotorworks, the best RE forum:
The Fireball 3 has arrived.
The GT is already light: wheels, spokes, frame and suspension. Increasing the power is magnified on this bike with an excellent power to weight ratio. Power to weight is the Ace card. Putting the power of a 500 - 600 lb bike on a 400 lb bike, changes everything. You can't buy this experience at any dealership. [Of course you could if RE would adopt a factory version of the Fireball!]
Next step will be finishing and final set up. That means valve seats, guides, valves, springs, tappets, rocker arms and oiling spigots. The factory job is alright, unless you want to wipe out the reviewers mantra, 'needs power'. ACE fixed everything the factory didn't, so we can say, "POWER".
Later this week our set up mechanic/tech will start on his shift of the Fireball job.
A few years ago, when I was at his shop he helped me a lot. That is, the velocity stack was on the hook in the retail area. He told me the stock coil is a 'usual suspect'. ACE Motors will sell you and anyone, the same DynaTek coil set up as used on the Fireball GTs. Simply, "There's a sound to power. And it's LOUD!"
The Fireball is coming.
Guaire
Here's the URL:
https://forum.classicmotorworks.com/...20474.600.html
Two members to check out there postings:
ACE
Otto
Gimme a honk after you see the stuff.
Guaire
Last futzed with by Guaire; January 2nd, 2019 at 02:36 PM. Reason: change words
Old January 2nd, 2019, 02:42 PM   #7
Guaire
I realized the saddle bags covered the shocks.
Bill
Old January 2nd, 2019, 03:57 PM   #8
time for ... clear saddlebags?
air box mod Twigster 2008 - 2012 Ninja 250R Tech Talk 7 August 7th, 2016 03:36 PM
N4's Battery Box Mod n4mwd 1986 - 2007 Ninja 250R Tech Talk 5 April 19th, 2013 06:27 PM
K&N air filter to stock air box Graugaard 2008 - 2012 Ninja 250R Tech Talk 29 July 28th, 2012 06:33 AM
Air Box Mod and Rain Riding tito517 2008 - 2012 Ninja 250R Tech Talk 7 April 19th, 2011 10:32 AM
