Old January 15th, 2018, 04:48 PM   #41
Originally Posted by Jonieibarra View Post
The key turns and all the lights and the odometer lights up is it really the battery?
1. Measure voltage of battery with everything off
2. Measure voltage of battery while cranking
These two pieces of data tells a lot!
Old January 15th, 2018, 04:49 PM   #42
Yes, the load before you hit the "start" button is small. A nearly discharged battery can handle that small load, but not the high current requirement of the starter motor.
Old January 15th, 2018, 04:51 PM   #43
Jonieibarra
Motorcycle(s): 99 yamaha r6
So charge it. If it doesent start then how to i drian the bowls?
Jonieibarra is offline   Reply With Quote
Old January 15th, 2018, 04:55 PM   #44
You need to take one step at a time. If it doesn't start, you'll need to make a voltage measurement at the battery terminals while cranking to see if the problem is still the battery. Sometimes batteries fail and charging doesn't help. If after charging, the battery can hold something around 11.5 to 12.0 volts during cranking, then you can move on to the next possible cause of the non-start. If the battery voltage still drops excessively, you'll need to replace the battery and see where you stand.
Old January 20th, 2018, 02:34 PM   #45
Ram Jet
Ram Jet's Avatar
Originally Posted by jkv45 View Post
That may mean a bit of work to get it going.
If you didn't add stabilizer and run it enough to get it into the carbs, or drain the floatbowls (best), then you probably have a tank of bad gas.
Left sitting long enough in the carbs, the gas will evaporate and leave a film of "varnish" in the bowl and jets. If it's bad enough you'll need to remove and completely disassemble the carbs to remove it.
Start by charging the battery and draining the floatbowls. The gas that sits there loses volatility and goes bad the quickest - making starting difficult.
Draining the tank completely and filling with fresh gas and stabilizer is a good next step. A full tank of stabilized ethanol-free gas will last a long time, but draining the floatbowls while it's in storage is always the best imo.
I just took a 30 mile ride on my 07 250. On 11/14/2017 I put about 2oz. of Stabil and about 4oz of gas line antifreeze in the tank and filled it. It's 42 degrees out and after cranking a-bit to fill the float bowls she fired right up. WHEW!!! I had to choke it a-bit until she warmed up. She ran fine thank God. It was good to get a few miles in during mid winter.
Bill
- - -Bike Wont Start - - - Triple R 2008 - 2012 Ninja 250R Tech Talk 1 July 31st, 2014 06:54 AM
Bike has been sitting for 9 months and won't start FerociousNINJA 2008 - 2012 Ninja 250R Tech Talk 11 February 8th, 2012 05:39 PM
Bike wont start, please help? zev42 2008 - 2012 Ninja 250R Tech Talk 11 November 9th, 2010 01:02 PM
Should I have my bike shipped to me in AZ to avoid sitting through a NY Winter? pucktoplay1 General Motorcycling Discussion 14 September 8th, 2010 06:49 AM
uhh, bike wont start. ajaygraci 2008 - 2012 Ninja 250R Tech Talk 37 June 24th, 2009 06:39 PM
