Old September 15th, 2010, 10:41 PM   #1
Domagoj
good and bad tire - or good and bad riding?
The reason im asking is because i am not really sure. Ninja is my first bike, and i had stock ircs for about 4000 miles. I used them on dry and wet, and havent slipped. I even did some track time, and i had no issues.
Then i switched to BT-090. They were supposed to be awesome. So after the initial excitement, i realized that nothing really changed. Dry and wet, some track time, and the bike is not slipping. Another 4000 miles, the front seems a bit odd, rear is almost gone in the center and sides are more or less intact, plus that never used edge because of the bigger size.
Anyway, after some miles i am a bit better then i was at the start, i learned some important stuff, (like look where you want to be, dont cut the throttle, dont be stiff with your hands, dont grab the brakes mid turn,...) and this is what has (at least how i see it) improved my overall control and feel of the bike. I dont think it was the tires.
Well, to be honest, i did slip, but only if i hit a pothole, or ride over the bloody lines on the road while its wet. Both Ircs and Bridgestones lost it in those situations, the difference is that now i dont panic and kill the gas.
So what is it that i am supposed to "feel" when i replace the tire again?
Old September 16th, 2010, 12:42 AM   #2
if you don't feel a difference, stick with the IRCs and eventually you'll find out.
Old September 16th, 2010, 04:49 AM   #3
dubojr1
dubojr1's Avatar
Old September 16th, 2010, 06:29 AM   #4
demp
grab the brakes hard in the rain... with IRC tires and see what happens to the rear
I remember having to come to a quick stop on an 80kph road when it had just started pouring, I didn't think the back end was ever going to stop swinging back and forth.. LOL
Old September 16th, 2010, 09:48 AM   #5
Rosie
Rosie's Avatar
Motorcycle(s): 2007 Blue Ninja 250R
Even if you grab your brakes on dry surface!
I once did that for an emergency stop and my back tire wouldn't stop swinging.. I was able to control it but I'm really thinking the stock tires are not all that great..
Rosie is offline   Reply With Quote
Old September 16th, 2010, 09:50 AM   #6
demp
Yeah, was scary as hell when I did that... cause it got all dark real fast, starts pouring, and the bike starts skiiing side to side like im carving the side of a mountain XD
Old September 16th, 2010, 10:01 AM   #7
Rosie
Rosie's Avatar
LOL, that's the same feeling I had! I remember thinking, this can't be right.. are the tires supposed to swing like that?? Luckily the front tire held well so I was able to control it but man.. was that weird! Need to invest on better tires I guess
Old September 16th, 2010, 11:34 AM   #8
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
For the most part, I'd say that a good number of street riders don't take their tires anywhere near their performance limits, so most tires will feel the same. There will be the obvious bad ones, whos performance limits are significantly lower than a 'higher end' tire...especially under wet/less than ideal riding conditions...and the smaller quirks of each tire (ie: quicker turn in, longer tread life, etc), but for the most part, I doubt there will be a significant change from tire to tire.
Track riding is a different story, though.
Old September 17th, 2010, 04:26 AM   #9
Domagoj
I suppose i should go back to ircs now, to see... I threw them away. And have absolutely no idea where to buy them again.
Well then, wait for the next tire change and see what comes out of it all, not much else to do.
Old September 17th, 2010, 04:30 AM   #10
demp
You really don't want IRC tires!
They're like riding on wood. They will last forever, if you can keep the bike upright on them I was lucky, had to replace them due to nails
Old September 17th, 2010, 06:37 AM   #11
Flashmonkey
Haha those IRC tires are pretty damn low end. You can get Bridgestone's for a decent price and they're far superior.
Old September 17th, 2010, 07:30 AM   #12
HKr1
IC2(SW)
HKr1's Avatar
Confidence in having new tires!
But like others mentioned, if your not out riding the lower end tires....no real sense buying super sticky race ones.
Spidi XP-3 Boots (Good OR Bad?) RandomPhantom Motorcycle Gear 26 August 11th, 2013 08:14 PM
Weather it's good or bad. KELPHYN Pictures 0 September 26th, 2010 11:46 PM
Engine braking...good or bad? ChaosFromAbove 2008 - 2012 Ninja 250R Tech Talk 4 June 28th, 2010 07:54 AM
Woodcraft rearsets, the good and bad whylee 2008 - 2012 Ninja 250R Tech Talk 7 January 10th, 2010 08:52 PM
Rear sprocket, good or bad? Verus Cidere 1986 - 2007 Ninja 250R Tech Talk 31 August 4th, 2009 05:44 PM
