Old March 6th, 2013, 08:29 AM   #121
/merged
Old March 6th, 2013, 10:25 AM   #122
psych0hans
psych0hans's Avatar
If I didn't mind buying a smaller bike, I'd buy this in a heartbeat.
Old March 6th, 2013, 01:14 PM   #123
have you seen the honda VTR250? it looks freaking badass. and its a v twin 250! a real vtwin!
http://www.visordown.com/motorcycle-...pan/22329.html
Old March 6th, 2013, 02:32 PM   #124
I know right? And it has a real frame too!! Not the little flexible one on the Ninja.
Dumb question: that's a trellis frame right? Looks like what's on Dukitteh's.
Old March 6th, 2013, 02:52 PM   #125
tube trellis. and its not necessarily "less flexible". all frames flex some. its just flexible in different ways. the diamond neck tube frame on the 250 is an engine supported bottom and has what is essentially an A arm from the rear subframe up to the neck. so it doesn't flex a whole lot forward and back or up and down but flexes a lot side to side. good attributes for a street bike where you're primarily hitting things straight up and down like speed bumps or potholes. perimeter frames, whether they are made with boxed aluminum (common for todays sport bikes due to weight) or steel tube trellis, are designed to have better support laterally. most newer perimeter frames use the engine as the bottom support as well as an internal lateral brace. but some older frames (most of the perimeter frames made with boxed steel sheet, which is much softer and easier to deform) use down-tubes to support the bottom of the neck instead of the relatively brittle engine casings of the time. many of the downtubes on steel box frames were also bolted to the sides of the bottom of the engine for extra lateral support. anyway, because of the design of the perimeter frame, it allows more vertical flex of the neck, but much less lateral flex. you'll notice the forward mount on the gas tank for perimeter frames is always made to handle at least an inch or so of frame flex.
tl-dr: there are tons of variables, and what kind of flex you want in a frame changes dramatically depending on use.
Old March 6th, 2013, 07:11 PM   #126
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
Alex.s uses wall of text!
It's super effective!
Old Lemon feints!
Old Lemon is offline   Reply With Quote
Old March 6th, 2013, 07:28 PM   #127
sk1l1ne
sk1l1ne's Avatar
Motorcycle(s): 2008 ninja 250 2009 cbr600rr (rip)
since you keep up with the visordown site have you also seen where aprilia and triumph may be coming out with 250s?
only question is will they be shipped out to the US
http://www.visordown.com/motorcycle-...tle/22447.html
sk1l1ne is offline   Reply With Quote
Old March 6th, 2013, 07:45 PM   #128
aprilia and triumph? you might as well buy a ducati and a ktm while you're at it, mr. moneybags! :P
Old March 6th, 2013, 07:47 PM   #129
*please make a triple, please make a triple, please make a triple*
Mr motorcycle loans = temporary Mr moneybags right?
Old March 6th, 2013, 08:58 PM   #130
psych0hans
psych0hans's Avatar
Aprillia and triumph are both planning small capacity bikes for india. Aprillia will be a single and triumph will be a twin...
Old March 7th, 2013, 04:23 PM   #131
sk1l1ne
sk1l1ne's Avatar
i wish moneybags!
i depend on 0% financing for big purchases.
Old March 8th, 2013, 04:30 AM   #132
Aufitt
The A Team
Aufitt's Avatar
Motorcycle(s): Z50, CB125, RZ500, MC22, R3.
Aufitt is offline   Reply With Quote
Old March 12th, 2013, 09:54 PM   #133
DreamN
Beer Me!
DreamN's Avatar
Motorcycle(s): '13 Ninja 300 Car(s): '09 Cube, '93 240SX (Coupe & 'Vert)
^ do want!
DreamN is offline   Reply With Quote
Old March 12th, 2013, 10:00 PM   #134
the more i look at the yamaha the more i want one... perimeter box aluminum frame and swingarm... should handle better than the ninja after suspension mods and on slicks... might be a ninja killer
Old March 12th, 2013, 10:21 PM   #135
lgk
i would buy it.
March Madness - 2015 ninjette.org bracket Alex Off-Topic 31 April 12th, 2015 01:41 PM
March Madness - 2014 ninjette.org bracket Alex Off-Topic 59 March 15th, 2015 03:55 PM
[motorcycle.com] - 2014 EICMA: 2015 Yamaha YZF-R1 and YZF-R1M Preview Ninjette Newsbot General Motorcycling Discussion 20 November 6th, 2014 07:03 PM
March Madness - 2013 ninjette.org bracket Alex Off-Topic 159 March 16th, 2014 02:07 PM
[roadracingworld.com] - Yamaha YZF-R1 And YZF-R6 Coming Back In "Variety Of New And E Ninjette Newsbot Motorcycling News 0 September 12th, 2012 05:20 PM
