Go Back   ninjette.org > General > Cargo Space
Old July 7th, 2011, 01:29 PM   #1
NathanF
NathanF's Avatar
Motorcycle(s): 2009 V-Strom 650 ABS
Anyone Tried the Twisted Throttle Alu-rack Top Rack?
Someone posted a link to this in another thread, and I was curious if anyone has used it. http://www.twistedthrottle.com/trade...view/6805/704/
I've got to say, it looks really nice. Probably the least obtrusive rack I've ever seen, with no trunk on it's barely noticeable and follows the lines nicely.
NathanF is offline   Reply With Quote
Old July 7th, 2011, 02:27 PM   #2
bluepoof
bluepoof's Avatar
Motorcycle(s): 2007 Ninja 250, 2002 Yamaha XT225
I don't have one on my Ninjette but I had one on my old Z750S. It was very well made and looked great.
www.bluepoof.com
bluepoof is offline   Reply With Quote
Old July 7th, 2011, 02:43 PM   #3
ichibunkid.206
ichibunkid.206's Avatar
Hey bluepoof,
Are these racks made to be permanently mounted to the bikes... meaning it more hassle than it worth to put em on and take em off only when I want to use them?
ATGATT
Quote Wild Hogs - Woody: "May be I don't want to wear a helmet, Maybe I don't want anything between me and the road" Bobby: "You will if your head falls on it"
ichibunkid.206 is offline   Reply With Quote
Old July 7th, 2011, 02:49 PM   #4
bob706
bob706's Avatar
Looks like it wouldn't clear a cowl
Old July 7th, 2011, 03:42 PM   #5
bluepoof
bluepoof's Avatar
Originally Posted by ichibunkid.206 View Post
Hey bluepoof,
That's right. They're meant to be permanently attached.
www.bluepoof.com
Old July 7th, 2011, 03:42 PM   #6
setasai
setasai's Avatar
Hey bluepoof,
The undertail mount requires you to get into the passenger seat and the foot peg mounts require you to take off both pegs. Very secure I would imagine but not something you would want to be removing often. I know because I'm using those same undertail mounts. Major headache.
You're probably right but I think the designers of this bracket intended on keeping it as close to the center of the bike as possible. Adding so much weight so high up and far back can cause handling changes that you arent expecting. If you had to, I suppose you could do some dremeling to get the cowl to just barely slip under.
Old July 8th, 2011, 03:17 PM   #7
KELPHYN
KELPHYN's Avatar
Looks good, but it still amazes me that none of the aftermarket luggage companies haven't come out a simple plate system that replaces the passenger seat, so one can attach a top case. That is pretty much much what every sportbike owner would like. Simple, quick, none intrussive and no brackets.
Old July 8th, 2011, 11:12 PM   #8
setasai
setasai's Avatar
Might be a liability thing if the passenger seat pops off. It's the one thing I'm concerned with when people talk about using the passenger seat as the mounting point. Dont get me wrong, I think it's the perfect way, just need another form of reinforcement so the locking mechanism isnt the only thing holding it on.
Old July 10th, 2011, 08:55 PM   #9
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
That's why I drilled a hole and put a bolt through from the undertail into the trunk... very solid.
slolane is offline   Reply With Quote
Old July 10th, 2011, 09:40 PM   #10
KELPHYN
KELPHYN's Avatar
I currently use a corteck tailbag and a duffle bag attached to the top of that. Which I mount to the bike only using the passenger seat and have never had a problem. And besides the seat latch isn't that much different than the systems they use for quick-lock side luggage. they don't have a problem with liability issues there. I will probably find an extra passenger seat and do my own. It would just be nice to have a metal base than a plastic, but I don't have a computerized 3-d CNC machine.
Old July 10th, 2011, 10:07 PM   #11
setasai
setasai's Avatar
It doesnt happen often but it happens. There have been some reports of people with seat cowls that have flown off while riding. I'd imagine the seat cowl is mounted on very similarly to a passenger seat so using that locking mechanism would run a similar risk.
I'm not saying it's for sure but I would not be happy to be that 1 in a 1000 that have that happen to my topcase while riding.
Yes, slolane, I know you bolted it. Wise decision otherwise. Althought since you have the sidecases mounted to the same apparatus, I'm sure you'd be more than safe.
Old July 10th, 2011, 11:22 PM   #12
NathanF
NathanF's Avatar
Agreed. I wouldn't trust it without a bolt - no way, no how.
Old July 11th, 2011, 07:13 AM   #13
slolane
Motorcyclist
slolane's Avatar
Yes, it's not going anywhere now with the sidecases and additional brackets.
Before the sidecases I did a bolt through the stock undertail, through the bikes under seat storage and into the aftermarket trunk which held really well. I used washers, lock washers and a wing nut on top for easy and fast on/off... took 2 minutes to do and cost $1.
Old July 12th, 2011, 08:39 AM   #14
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
It's actually slightly different between the two. The stock seat, as most of us know, has a plastic underpan which has a slot in it where the metal portion of the bike's trunk slides into. The other end being the notched locking rod. On a cowl, it still has a notched locking rod, but the other end is only a couple rods that push into a couple of grommets on that same bracket that the stock seat slots onto.
I haven't been around long enough to read of anyone's cowl flying off, but I would suspect it has more to do with their installation or faulty/weak cowl hardware than the mounting points on the bike.
I just installed a Fastpack tail bag on my bike this morning. It looks great and I will have enough room for the normal stuff I carry. I can definitely stuff my DSLR, lenses, and other stuff in there for our group rides. I won't need my backpack for many trips anymore The nice thing is that it's strapped to the rear seat, so I can remove it anytime I want.
The www.ModMy250.com guy
Old July 13th, 2011, 10:20 AM   #15
drdoug99
drdoug99's Avatar
Motorcycle(s): 2010 Ninja 250R Special Edition
Here's something that's basically what you are talking about:
FastRack Sportbike Luggage Rack
http://www.thecycleguys.com/
drdoug99 is offline   Reply With Quote
Old July 13th, 2011, 02:22 PM   #16
setasai
setasai's Avatar
Except something preferably less ugly.
Old July 13th, 2011, 02:27 PM   #17
drdoug99
drdoug99's Avatar
Yeah I agree....i got the cycle guys fast pack for a little extra storage, it collapses down and blends in pretty good, but it doesn't look that great when I have something in it.
Almost got this fast rack instead but I didn't like how it would look by itself like that either. There's always a compromise I suppose.
Old July 13th, 2011, 02:36 PM   #18
setasai
setasai's Avatar
The thing about the fast rack is that it's basically just a piece of metal strapped to your passenger seat. You could just as well skip that and strap whatever you want to the passenger seat. That's what I still have on my bike in addition to the sidecases now. Works great. I've also realized that if you carry one of those collapsable duffle bags in the trunk, you could open it up and strap it to the passenger seat pretty easily and looks a little better than the fast pack. Fast pack is a neat idea but I think it's look and execution could probably be better and definitely cheaper.
Old July 26th, 2011, 06:32 AM   #19
grandelatte
Go Pack Go!
grandelatte's Avatar
Motorcycle(s): 09 250R, 07 XL1200L
Installed it last night.
09 Ninja 250R (commuter)
07 XL1200L (weekend fun)
02 SV650S (totaled by an idiot cager) & others
grandelatte is offline   Reply With Quote
Old July 26th, 2011, 07:06 AM   #20
bob706
bob706's Avatar
Looks great but now that I see closer pic, a seat cowl definetly wouldn't fit. Nice grab bar for a passenger though
Old July 26th, 2011, 10:31 AM   #21
setasai
setasai's Avatar
Can you take a few more pictures of the mounts at the bottom so I can see how it's mounted on? As many angles as possible would be greatly appreciated.
Old July 26th, 2011, 12:04 PM   #22
grandelatte
Go Pack Go!
do you mean at the bottom of the rear seat or at the passenger pegs? did you also look at their instruction online?
http://www.twistedthrottle.com/filem...download/3184/
Old July 26th, 2011, 03:12 PM   #23
slolane
Motorcyclist
slolane's Avatar
Looks great Jim!!
Old July 26th, 2011, 03:32 PM   #24
setasai
setasai's Avatar
Thanks for the link. I did not get a chance to look at it before.
Old July 26th, 2011, 08:25 PM   #25
grandelatte
Go Pack Go!
I forgot to tell you one thing. The rack came with a nice 200 page Twisted Throttle catalog. In there, it shows that Alu-rack has adapter plates for many popular Topcases, like Givi and Coocase. This might come handy for some of you who already have top case(s).
Old May 12th, 2012, 02:50 PM   #26
Bill E Bob
Bill E Bob's Avatar
Motorcycle(s): ninja 250 '08, '09', '11, ...
I don't see how to add pictures in a reply. I added this rack to my bike last week. It is a great little extension. Now I'll be able to tie my tent and underpad to something when I go camping. I recently put a large cooler on there and a passenger and away we went. So how do I add pictures? I see where it lets me indicate a url but I want to get them off my pc. bill e bob
Bill E Bob is offline   Reply With Quote
Old May 12th, 2012, 02:52 PM   #27
How do I load pictures on to this site?
Old May 13th, 2012, 08:32 PM   #28
Bill E Bob
Bill E Bob's Avatar
I've added this rack to my 2011 ninja. I'm still learning how to put up pix so here goes for the third time. I was using Firefox browser, now using IE 8.
I used the paper clip and chose to upload 4 pix.
Old May 13th, 2012, 08:58 PM   #29
cuong-nutz
cuong-nutz's Avatar
Awesome! Looks like I'll have to add this to the to-do list!
HalfFast Racing Team
Old May 14th, 2012, 06:19 AM   #30
exploring/carolina
exploring/carolina's Avatar
Installed the Twisted Throttle trunk mount & bolted a Pelican 1200 case directly to the mount.
Works great!
Last futzed with by exploring/carolina; May 14th, 2012 at 07:47 AM.
exploring/carolina is offline   Reply With Quote
Old May 15th, 2012, 03:33 AM   #31
TheTopher
TheTopher's Avatar
Motorcycle(s): 2007 EX250F
Works great!
That actually looks really good.
I may have to steal your idea!
TheTopher is offline   Reply With Quote
Old May 15th, 2012, 05:26 AM   #32
Bill E Bob
Bill E Bob's Avatar
Exp/Carolina: That setup looks like it belongs. I'm still, experimenting to find a box that fits the bike. The soft cooler is the most functional so far, but when it's empty, the bungees scrunch it down and it looks uncool. The tent and sleeping bag look much better on there, but I'm not ready to hit the road yet.
Old May 15th, 2012, 06:26 AM   #33
exploring/carolina
The Pelican case is tough & small. It's large enough to keep tools & everything need to repair/inflate a tubeless tire with some other items.
It's also easy using a cargo net to secure rain gear, bed rolls, ect. in front of the box on the rear seat, so you can still get in the box without removing the stuff secured with the cargo net
Thanks Guys!
Old June 10th, 2012, 06:26 PM   #34
sky20nyc
I installed the alu-rack on my ninjette as well as the monokey adapter so I could use a Givi 46L. First day after the install, I went for a ride on the highway, encountered some bumpy roads, and my givi flew towards the center divider (luckily traffic was light and no one was hit).
I contacted twisted throttle, told them what happened, and showed them what was left of the quick release bolts. Only the bottom portion was left, the top appeared to have been cut cleanly off.
With no difficulties or arguments, Twisted Throttle replaces the adapter plate and the GIVI (even though I hadn't purchased the givi from them).
It's been about a month, I've had no problems with my new alu-rack or givi. In fact, I barely use my car as the GIVI provides all the storage I need for day to day living. If only I lived someplace where it didn't snow .
sky20nyc is offline   Reply With Quote
Old June 10th, 2012, 07:09 PM   #35
Bill E Bob
Bill E Bob's Avatar
alumErack
Hi Sky20: Wow that's a scary story. I'm glad it turned out ok. Is the broken Givi usable or fixable?
I really like my rack. Even when I don't have anything tied to it, it makes the bike look bigger. I sometimes strap a cooler on there with bungies, or my backpack.
billEbob
Old September 18th, 2012, 06:26 AM   #36
Old Guy on a '08
Chris
Old Guy on a '08's Avatar
Motorcycle(s): BLACK!!! '08 250R
Question Alu-rack needs plate for side cases
The Alu-rack is sweet but there needs to be something to mount side cases on the NewGen This needs to be addressed by the aftermarket, smething that would be easily removed would be the ideal but so long as it mounts Givi Case like te 35's so they easily taken on/off would be okay.
Does anyone make such a rack?
Some roads are too good to waste on four wheels!
Riding in a car is like watching a movie...
Riding on a motorcycle is like being in one....
Old Guy on a '08 is offline   Reply With Quote
Old September 18th, 2012, 09:03 AM   #37
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Their headquarters is about 5 miles from my house. Cool place. Get in touch with them, maybe they will build it if the demand is there.
Old September 18th, 2012, 09:31 AM   #38
Old Guy on a '08
Chris
You don't happen to have their contact information handy, do you??? Never mind, I found it after a litte bit of extra searching...
When you say near you, your talking about Twisted Thorttle . SW-Motto Tech actually makes them, they're in the UK (I think). Anyway I sent them an email.
Old September 18th, 2012, 07:17 PM   #39
Yeah TT. They do in house design for their products. Met one of the owners or higher ups at a track day. Cool company.
Old September 20th, 2012, 09:39 PM   #40
Old Guy on a '08
Chris
Got an email back from Twisted Throtle, authorized distributor or Mototech.
There are NO PLANS to produce aside case mount for this rack.
Have any of you looked at the thread over on the Ninjette Wiki Page about Storage/Luggage
http://www.ninjette.org/wiki/Givi_Rack
Corbin seat and Twisted Throttle rear rack F/S wardie Motorcycle-related 6 June 30th, 2013 02:01 PM
Twisted Throttle Alu- Rack Toprack & Garage Pro Motorcycle Travel Trunk vman1313 Cargo Space 29 June 19th, 2013 12:07 PM
Installed Twisted Throttle Alu-Rack Guoseph 1986 - 2007 Ninja 250R Farkles 7 October 26th, 2011 04:09 PM
[twisted throttle] - BMW F800S with Coocase V36 topcase and F800ST rear luggage rack Ninjette Newsbot Motorcycling News 0 September 22nd, 2011 01:40 PM
Alu-rack with top case (Ninja 250ST) grandelatte 2008 - 2012 Ninja 250R Farkles 7 July 27th, 2011 05:54 AM
