Old December 7th, 2015, 10:44 AM   #1
HoneyBadgerRy
HoneyBadgerRy's Avatar
Starter Jet
I took my carbs off for winter storage, but decided to put them back on for a quick ride around the block, when I did the bike wouldn't start (odd because they worked perfectly fine a month ago, and I just cleaned them a month and a half ago), anyway, I tore them down and cleaned them, one starter jet sprays carb cleaner out the side of a shaft into the fuel bowl area, the other doesn't spray anywhere (even after soaking in carb cleaner over night and 100 psi), is it clogged, or is the other broke?
Old December 7th, 2015, 10:54 AM   #2
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Not sure what you mean by a starter jet.
Can you print a carburator schematic, circle in red the spots you are referring to, take a picture with your phone or camera and post it here?
Something is getting lost in the translation!
But my first guess is you may not have hooked up the vacuum hoses correctly.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old December 7th, 2015, 10:58 AM   #3
HoneyBadgerRy
This is a cvk40, but it still shows what I'm talking about.
Old December 7th, 2015, 11:17 AM   #4
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
HA! PROOF that I know nuthin!
But; I'm sticking with vacuum hoses!
And; deferring to @ducatiman
Old December 7th, 2015, 11:22 AM   #5
HoneyBadgerRy
I can assure you, its not vacuum hoses.
Old December 7th, 2015, 11:41 AM   #6
Ensure the intake/airbox boots are on both sides properly, especially the airbox side as they can be a pain in arse to see all the way around.
Good luck, hope it something simple.
Old December 7th, 2015, 11:45 AM   #7
HoneyBadgerRy
The air boots are properly seated and secured, and I am running a K&N R-0990 also properly seated and secured.
Old December 7th, 2015, 12:05 PM   #8
Never hear it called that either.
I'm assuming it's what we usually call the Enrichener Pick-up.
Old December 7th, 2015, 12:31 PM   #9
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
Is this your carb?
Old December 7th, 2015, 12:42 PM   #10
HoneyBadgerRy
Yeah, I have the stock CVK-30's that come on a 2005 ninja Ex250-F
Old December 7th, 2015, 02:40 PM   #11
HoneyBadgerRy
This is my carb and it shows where I'm spraying in and where it comes out.
Old December 7th, 2015, 02:51 PM   #12
Ghostt
Ghostt's Avatar
I would think you have one hellva blockage, Might need a deep cleaning heated ultrasonic, but I'm interested in @ducatiman opinion.
violente et ignorantia
ZX-2R BLOG
Old December 7th, 2015, 03:00 PM   #13
HoneyBadgerRy
It might also not suppose to flow, causing the fluid to not go into the fuel inrichment circuit correctly. If someone could tare down their carbs and check it would be great. Also @ducatiman might be able to just tell me.
Old December 7th, 2015, 03:06 PM   #14
I have my pregen carbs out, lemme go check... ETA 5 mins.
EDIT: Both sides of mine are plugged. Bike ran fine before carbs came off.
Hope that helps...
Old December 7th, 2015, 03:13 PM   #15
Ghostt
Ghostt's Avatar
send him a PM.
ZX-2R BLOG
Old December 7th, 2015, 05:06 PM   #16
HoneyBadgerRy
The jet was plugged, it should be fixed, putting the carbs back on the bike.
Old December 7th, 2015, 05:20 PM   #17
HoneyBadgerRy
When it turns over it almost tries to start, jetting seems to be off. It always was a cold blooded bastard, I'll try something else later.
Old December 7th, 2015, 06:18 PM   #18
ducatiman
ducatiman's Avatar
starter jets, enrichener jets, choke jets...whatever you want to call them
both carbs have identical starter fuel paths and should be clear..... using a guitar string of .015" (if memory serves me correct), the long "jet" (actually a pressed in tube) is about 1.5" long...the string should be clear to "bottom" ..where the orifice turns and culminates up at the choke plunger(s)
the starter/enrichener/choke fuel path is only active when the plungers are pulled open, greatly enhancing cold starting.
I consider checking and clearing the enrichener circuit (the entire pathway) standard carb clean procedure
Old December 7th, 2015, 06:24 PM   #19
ducatiman
ducatiman's Avatar
if you're confident you've cleared the starter "jet", but bike is still reluctant to start on choke (keep throttle plates closed while choking, btw) it is conceivable the 2nd half of your enrichment circuit needs clearing as well
Old December 9th, 2015, 09:03 AM   #20
HoneyBadgerRy
Literally let the bike sit over night with the external fuel tank (jug) on, came back the next night turned the key, hit the start button, and she is running like a champ, warmed up faster than ever, and idled better than ever. Apparently, last time I cleaned and rebuilt my carbs I didn't do it well enough (Sorry Ninjette).
Old December 9th, 2015, 09:33 AM   #21
Ghostt
Ghostt's Avatar
No worries, glad you got it all sorted out.
ZX-2R BLOG
Old May 15th, 2019, 11:48 AM   #22
Xrrider280
Motorcycle(s): XR250r NX650
Hey guys, sorry to resurrect this ancient thread but I'm at a loss here. I am having the same issues as Honey and Ive scoured the web up and down...but to my question. My starter jet, starter jet tube also has an orifice toward the base of the tube that cleaner sprays through when i shoot it into the jet. i guess the question that was never answered was is this normal or should it be plugged. I have been cooking in the ultrasonic all day and blasting air through all the passageways so if there was a plug in there i have no way of knowing.
Xrrider280 is offline   Reply With Quote
Old May 15th, 2019, 12:36 PM   #23
ducatiman
ducatiman's Avatar
perfectly normal, thats called the secondary starter jet (pickup, whatever you want to call it) and should be open
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old May 15th, 2019, 12:42 PM   #24
Xrrider280
Thank you very much
Old May 15th, 2019, 03:49 PM   #25
HoneyBadgerRy
It's all normal. My problem was solved by a good old carb deep clean.
This email reminded me of my bike back home though, poor thing sitting in the garage without a drop of gas in her for probably over 2.5 years. But my KTM 625 SMC down here in SC is alot of fun too.
Starter Relay/Starter Problem Time Mage 1986 - 2007 Ninja 250R Tech Talk 13 July 13th, 2012 05:02 AM
